RetroTechCollection:Citing sources
Revision as of 11:22, 30 September 2026 by Josh (talk | contribs) (Rewrite examples to match the wiki's real cite templates and parameters; remove nonexistent templates (cite datasheet, forum, measurement, safety) and invented example refs; show hosted-file citation style; sentence-case headings)
Citations let readers check the technical information on RetroTechCollection and credit the people who produced it. They are not strictly required for all content, but a cited claim is more credible and points readers to the source for further detail.
When to cite
Cite these wherever you can:
  • technical specifications: voltage levels, timing parameters, component values
  • safety procedures: high-voltage precautions, chemical handling, discharge procedures
  • repair procedures: diagnostic steps, calibration methods, troubleshooting flowcharts
  • historical information: release dates, production numbers, design changes
  • performance data: benchmark results, compatibility, operating parameters
Required
A citation is mandatory for:
  • direct quotes: any text copied word for word from a source
  • copyrighted excerpts used under fair use
  • controversial claims that might be disputed
  • safety-critical information: any procedure involving a hazard
How citations are written on this wiki
Put each citation in a <ref>...</ref> tag straight after the claim it supports, and add a references list at the foot of the page:
<references />
{{Reflist}} also works in place of <references />.
Manuals hosted on the wiki
Most repair pages cite service manuals and technical references that are already uploaded here. Write the citation as plain text: publisher, title in italics, the chapter, table or page used, and a link to the hosted file. Link the file with a leading colon ([[:File:...]]) so that the link does not embed the PDF.
Apple's voltage check uses test cable 077-0135 on the external floppy port.<ref name="ssplus">Apple Computer,
''Macintosh Plus'' Service Source, Adjustments, Voltage. Hosted as [[:File:Macintosh plus.pdf]].</ref>
Check Category:Service Manuals and Special:ListFiles before uploading a manual; the wiki may already have it. See Help:Uploading service manuals.
Named references
Give a reference a name when you cite the same source more than once. Define it in full once, then reuse it with a self-closing tag:
The +5 V supply is specified at ±3 %.<ref name="iie-ref">''Apple II Reference Manual – For //e Only'',
Apple Computer, Inc., 1982, Table 7-2. Hosted as [[:File:Apple IIe Reference Manual 1982.pdf]].</ref>
Later on the page:
<ref name="iie-ref" />
Defining the same name twice with different text produces a red cite error on the page.
Citation templates
The wiki has simple citation templates that print a formatted line of text. Wrap them in <ref> tags yourself. They accept only the parameters listed below and silently ignore any others, so a page number given as pages= to {{Cite manual}} is lost. Put the page or section after the template, inside the same ref.
Template Use for Parameters
{{Cite manual}} service manuals, technical references, datasheets title, author, publisher, date, version, url, access-date
{{Cite book}} published books title, author, publisher, date, isbn, page, url, access-date
{{Cite web}} web pages and forum threads title, author, publisher, date, url, access-date
{{Cite journal}} journal and conference papers title, author, journal, volume, issue, pages, date, doi, url, access-date
{{Cite magazine}} magazine articles title, author, magazine, issue, volume, date, pages, url, access-date
A web source:
<ref>{{Cite web
 |title=Macintosh Colo(u)r Classic
 |publisher=Recap-a-Mac
 |url=https://recapamac.com.au/macintosh-colour-classic/
 |access-date=2025-01-25
}}</ref>
A book, with the page number:
<ref>{{Cite book
 |title=Revolution in the Valley
 |author=Andy Hertzfeld
 |publisher=O'Reilly Media
 |date=2005
 |isbn=0596007191
 |page=156
}}</ref>
A manual cited by section:
<ref>{{Cite manual
 |title=Macintosh SE/30 Service Source
 |publisher=Apple Computer, Inc.
 |date=1990
}} Specifications chapter.</ref>
There are no templates for forum posts, datasheets or safety notices. Use {{Cite web}} for a forum thread and {{Cite manual}} for a datasheet.
Measurements and original research
There is no template for measurements. Give your own bench measurements in plain text, with the conditions: the machine and board revision, the test point, the load and the meter used. Original research native to the wiki, such as Sad Mac code decoding, bench measurements and 3D-printed replacement parts, needs no external citation, but say that it is original.
Source quality
Preferred sources
In order of preference:
  1. Official service manuals: the manufacturer's repair documentation
  2. Technical datasheets from the component manufacturer
  3. Engineering documentation: schematics, design notes, technical bulletins
  4. Published technical books by recognised authors
  5. Established technical websites with documented expertise and review
Acceptable sources
These may be used with appropriate context:
  • community forums, where several experienced users confirm the information
  • technical blogs by recognised experts
  • videos, when the same information is also documented in writing
  • personal experience, clearly marked as such and preferably with supporting documentation
Sources to avoid
These are generally not suitable:
  • social media posts, unless from an official manufacturer account
  • Wikipedia or other wikis: cite their sources instead
  • commercial listings: eBay, Amazon or other sales descriptions
  • unverified claims with no supporting documentation
  • speculation and rumour
See RetroTechCollection:Reliable technical sources for more detail.
Technical accuracy
When citing technical information:
  • Cross-check specifications against more than one source where you can.
  • Where sources disagree, say so and cite both.
  • Replace superseded data with the current figure.
  • Give the conditions: operating parameters, tolerances and limits.
Make sure the source actually says what you cite it for.
Special cases
Where the copyright holder is unknown, cite the document as fully as you can and state what is not known:
<ref>''Service Guide'', publisher unknown, c. 1985, p. 12.</ref>
Foreign-language sources
Give the original title followed by an English translation in brackets, and name the language:
<ref>Fujitsu, ''コンピュータ修理マニュアル'' (Computer Repair Manual), 1984, in Japanese, p. 30.</ref>
Multiple revisions
Name the revision you used, since figures often change between revisions. {{Cite manual}} takes a version parameter for this.
When including web links:
  • Prefer permanent or archived URLs.
  • Check that the link works before saving.
  • For unstable sources, add an archive.org link as well.
  • Say if the source needs registration or payment.
Common citation errors
Incomplete information
  • Missing dates: include the publication date or the date you accessed the page.
  • Vague titles: use the full title of the document.
  • No page numbers: give the page, table or section for any long document.
  • Broken links: check every URL before saving.
Over-citation
These do not need a citation:
  • common knowledge
  • basic specifications, such as standard voltages and connector types that are widely documented
  • simple procedures, such as basic cleaning steps
Under-citation
Always cite:
  • unusual or surprising specifications
  • safety procedures
  • claims that might be disputed
