Macintosh LC
Revision as of 12:43, 27 September 2026 by Josh (talk | contribs) (House rule: reword the remaining in-article correction narratives to describe the claim in circulation rather than the page's own edit history)
Macintosh LC
Macintosh LC
TypePersonal Computer
ReleasedOctober 15, 1990
DiscontinuedMarch 23, 1992
Intro priceUS$2,499
CPUMotorola 68020 @ 16 MHz
Memory2 MB RAM (expandable to 10 MB)
Storage40 MB or 80 MB SCSI HDD, 1.44 MB SuperDrive
Display512×384 (8-bit) or 640×480 (4-bit)
Sound8-bit monophonic sound input and output (Apple's figure)
Dimensions3.0" H × 12.2" W × 15.0" D (7.7 × 31.0 × 38.2 cm)
Weight8.8 lbs (4.0 kg)
OS / FirmwareSystem 6.0.7 – System 7.5.5
SuccessorMacintosh LC II
CodenameElsie
Model no.M0350
The Macintosh LC is a low-cost Macintosh personal computer released by Apple on October 15, 1990.[1] The name "LC" stands for "low-cost color," and the machine was designed to bring color Macintosh computing to education and home markets at a more affordable price point than the Macintosh II series.[2] The internal codename "Elsie" was a phonetic play on "LC."
The Macintosh LC uses a Motorola 68020 processor running at 16 MHz. However, the system has a significant bottleneck: the 68020's 32-bit data bus is connected through a 16-bit memory controller, effectively limiting memory bandwidth.[3] This design decision reduced costs but limited performance compared to full 32-bit implementations.
The Gestalt ID for the Macintosh LC is 19.
Memory and Storage
RAM Configuration
The LC shipped with 2 MB of RAM standard, expandable to 10 MB. Memory expansion uses two 30-pin SIMM slots, which must be populated in pairs using matching SIMMs. The machine uses 100ns or faster SIMMs.
2 MB of the total is on the board, so the two 30-pin slots are additional: 2 MB standard with the slots empty, and Apple's maximum of 10 MB is 2 MB on board plus two 4 MB SIMMs, 100 ns or faster.[4] Configuration tables that show the base 2 MB coming from a pair of 1 MB SIMMs cannot be right: that would leave no route to 10 MB.
The sound on the LC, LC II and LC III is monophonic in and out. Apple's own wording is a mono sound input and output port on a mini phono plug, and a monophonic 8-bit sound generator supplying the same signal to both channels of stereo equipment.[4] Stereo output arrives with the LC 475 and Quadra 605. A stereo input/output description on the earlier machines is wrong, and it matters when diagnosing a channel that sounds dead: on an LC, LC II or LC III both channels carry the same signal by design.
Video RAM
The LC includes 256 KB of VRAM standard, expandable to 512 KB with an optional VRAM SIMM. Video memory determines available color depth:
  • 256 KB VRAM: 512×384 at 8-bit (256 colors) or 640×480 at 4-bit (16 colors)
  • 512 KB VRAM: 512×384 at 8-bit or 640×480 at 8-bit
Storage Systems
Standard storage options included:
  • 40 MB or 80 MB internal SCSI hard drive
  • 1.4 MB Apple SuperDrive. Apple notes an optional second internal 1.4 MB floppy drive on the LC only; no other LC supports one[4]
  • This drive is direct drive and has no belt. Advice to check a drive belt on an Apple 3.5-inch mechanism has been removed from Macintosh Floppy Drive Maintenance for that reason
Input/Output and Expansion
Port Configuration
  • 1× Apple Desktop Bus (ADB) port
  • 1× External SCSI (DB-25)
  • 1× monophonic audio input (mini phono plug)
  • 1× monophonic audio output (mini phono plug)[4]
  • 2× Serial ports (Mini DIN-8)
  • 1× Video output (DA-15)
Expansion
The LC features a single LC Processor Direct Slot (LC PDS), a 96-pin expansion slot. This slot accepts LC-specific expansion cards including:
  • Ethernet adapters
  • Video capture cards
  • Apple IIe Card (for Apple II compatibility)
Design and Form Factor
The LC introduced Apple's "pizza box" form factor—a compact, horizontally-oriented case designed to fit under a monitor. The case measures 2.9 inches high, 12.2 inches wide, and 15.3 inches deep. This form factor was used throughout the LC line and influenced subsequent compact Macintosh designs.
For detailed maintenance practices including cleaning, PRAM battery management, and connector care, refer to the dedicated Macintosh LC General Maintenance page.
A comprehensive troubleshooting guide addressing common issues with the Macintosh LC is available on the Macintosh LC Troubleshooting page.
Capacitor Replacement
The Macintosh LC logic board contains 17 surface-mount electrolytic capacitors that commonly fail due to age. Detailed replacement guidelines can be found on the Macintosh LC Capacitor Replacement Guide page.
System Specifications
Macintosh LC Technical Specifications
Component Specification
CPU Motorola 68020 @ 16 MHz
FPU None (not supported)
Data Bus 32-bit (16-bit memory controller)
Address Bus 32-bit
System Bus 16 MHz
ROM 512 KB
RAM 2 MB (max 10 MB)
VRAM 256 KB, upgradable to 512 KB[4]
Maximum power 50 W, not including the monitor[4]
Line voltage 100–240 VAC, automatically configured; 47–63 Hz[4]
PRAM battery 3.6 V ½AA lithium; Apple: replace below 3.0 V. Neutralise leakage with bicarbonate of soda, not vinegar[4]
  1. ↑ Macintosh LC, Apple History—link(accessed 2026-02-09)
  2. ↑ Macintosh LC, Low End Mac—link(accessed 2026-02-09)
  3. ↑ Apple Macintosh LC Specs, EveryMac.com—link(accessed 2026-02-09)
  4. ↑ 4.0 4.1 4.2 4.3 4.4 4.5 4.6 4.7 Apple Computer, Macintosh LC Series/Quadra 605 Service Source (Macintosh LC Series/ Quadra 605 Service Source, File:Quadra_605.lc_series.pdf), Specifications chapter and Additional Procedures, Battery Replacement (below 3.0 volts, replace the battery). This volume has no Adjustments chapter, so Apple publishes no rail tolerance and no power-supply adjustment for any LC.
