Macintosh Performa 5200CD Troubleshooting
Troubleshooting is essential for diagnosing and resolving issues with your Macintosh Performa 5200CD. This guide covers the 5200CD and all related variants including the Performa 5200, 5210CD, 5215CD, 5220CD, and Power Macintosh 5200/75 LC.
- Verify the power cord is securely connected at both ends
- Test the wall outlet with another device
- Check for visible damage to the power cord
- Listen for any sounds when pressing the power button
- Check that the brightness control is not set to minimum
Target Voltage Levels:
- +5V: 4.85V โ 5.15V
- +12V: 11.9V โ 12.7V
| No response, no LED | Power cord, outlet, or fuse | Test outlet, inspect cord, check internal fuse |
| Ticking or clicking sound | Short circuit or failed capacitor | Inspect analog board for failed capacitors, check for shorts |
| Powers on briefly then dies | Power supply failure | Check capacitors in power supply section, verify voltage output |
| LED on but no startup | Logic board issue | Reseat RAM, check for corrosion, test with known-good RAM |
| Intermittent power | Bad solder joints | Reflow solder on analog board power connectors |
Power Supply Testing
- Disconnect all external devices except keyboard and mouse
- Remove internal expansion cards
- Test power supply voltages at the logic board connector
- If voltages are out of spec, inspect and replace failed capacitors
Chime but No Video
| Chime, no video, drive activity | CRT or analog board failure | Check CRT neck board, verify flyback operation |
| Chime, dim or faded display | Failing CRT or weak flyback | Test CRT, check flyback transformer output |
| Chime, scrambled colors | Video RAM or color shift issue | Known issue in early units โ may require logic board repair |
| Chime, display geometry problems | Deflection circuit failure | Check yoke connections, inspect analog board |
| Chime, horizontal or vertical line only | Deflection circuit failure | Inspect analog board, check yoke connector solder joints |
Flyback Transformer Check
The flyback transformer provides high voltage to the CRT. Symptoms of failure include:
- No high voltage (dark CRT, no static discharge)
- Clicking or arcing sounds
- Burning smell
Warning: The flyback and CRT retain lethal voltages even when unpowered. Discharge the CRT before any inspection.
| Random freezes | Known 5200 design flaw | Install Open Transport 1.2+, add SCSI terminator, check capacitors |
| Freeze with color shift | Logic board defect | Apple Repair Extension Program (if still available) or board-level repair |
| Freezes under heavy use | Overheating or power supply | Clean vents, check fan operation, verify PSU voltages |
| Freezes on network access | Network stability issue | Install Open Transport 1.2+, connect printer to modem port if no modem installed |
| Freeze after sleep | PRAM battery or software issue | Replace PRAM battery, reset PRAM, update system software |
Sad Mac Error Codes
See the Sad Mac Error Codes page for a complete reference.
| Code | Meaning | Action |
| 0000000F 00000001 | ROM checksum error | Replace or reseat ROM (logic board issue) |
| 0000000F 00000002 | Memory test failure | Reseat or replace RAM SIMMs |
| 0000000F 00000003 | Memory addressing error | Test SIMMs individually, check SIMM socket |
| 0000000F 0000000E | Data bus test failure | Logic board failure |
| 0000000F 0000000F | Address bus test failure | Logic board failure |
Floppy Drive Issues
| Disk not recognized | Dirty heads or worn drive | Clean heads with cleaning disk, test with known-good drive |
| Disk eject failures | Mechanical issue | Lubricate eject mechanism, check for debris |
| Read/write errors | Head alignment or media | Try different disks, clean heads, may need drive replacement |
| No eject on startup | Stuck mechanism | Manual paper clip eject, inspect mechanism |
CD-ROM Drive Issues
| CD not recognized | Dirty lens or failed drive | Clean lens with appropriate cleaner, test with known-good drive |
| Slow reading or skipping | Dirty or worn lens | Clean lens, check for media damage |
| Tray won't open | Mechanical failure | Manual eject with paper clip, check tray mechanism |
| Drive makes grinding sounds | Mechanical failure | Drive replacement likely needed |
Hard Drive Issues
| Drive not recognized | Cable, drive, or HD Setup version | Check IDE cable, try Drive Setup 1.0.3 or later |
| Clicking or grinding | Drive failure | Back up immediately if possible, replace drive |
| Slow performance | Outdated driver | Use FWB HD Toolkit or updated Apple driver |
| Boot failure, question mark | Corrupt system or drive failure | Boot from CD, run Disk First Aid, reinstall system |
Note: Apple HD SC Setup versions prior to System 7.5.2 may not recognize newer IDE drives. Use Drive Setup 1.0.3 or later.
SCSI Problems
| SCSI device not seen | Termination or ID conflict | Verify termination at end of chain, check unique SCSI IDs |
| System freeze with SCSI | Termination power issue | Add active terminator, SCSI devices must provide termination power |
| Intermittent SCSI errors | Cable quality or length | Use high-quality cables, keep total length under 6 meters |
Note: The Performa 5200 does not provide SCSI termination power. External devices or an active terminator must supply it.
Audio Problems
| No sound output | Volume setting or speaker failure | Check volume in Control Panel, test with headphones |
| Distorted sound | Failed capacitors or speaker | Inspect analog board capacitors, test speakers |
| 8-bit sound quality | Hardware revision | Check for capacitor C255 on logic board; if present, unit has 8-bit audio |
โ ๏ธ PRAM battery
The Performa 5200 uses a 3.6 V 1/2AA lithium PRAM battery that leaks and can burst, corroding the logic board. Remove it from any un-serviced unit and clean/repair any leakage before troubleshooting.[1]
โ ๏ธ Recap (logic board and PSU)
The Performa 5200 uses aluminium electrolytic capacitors on both the logic board and the power supply, and they leak with age. Recap and clean both boards as a first step; the large 2200 uF PSU filter capacitors in particular are a known failure point, giving a dead machine, failure to power on, or instability.[2]
All-in-one analog board and video
As an all-in-one with a built-in CRT, this machine has an analog board like the compact and Color Classic Macs. Vertical lines, a collapsed raster, dim or distorted video, or no video with the machine otherwise alive point to the analog board โ reflow cracked solder joints (deflection yoke and flyback area) and recap the analog board.[3]
Architecture note ("road apple")
The x200 family (5200/5300/6200/6300) is nicknamed the "road apple": to cut cost Apple put the 64-bit PowerPC 603 on a Quadra 605-derived board with a 25 MHz 32-bit memory bus and an 8-bit IDE controller, so the machine is much slower than its CPU suggests. This is a design limitation, not a fault โ do not chase it as a hardware failure.[4]
- โ 68kMLA โ Exploding Maxell PRAM Batteries. Source for the leaking/exploding 3.6 V lithium PRAM battery.
- โ Recap-a-Mac โ Power Macintosh 6100; Badcaps "Macintosh 6100 power supply"; and the Apple Performa/Power Macintosh 6400/6500 Service Source. Source for the logic-board and power-supply electrolytic failures (including the 2200 uF PSU capacitors) and the recap.
- โ 68kMLA โ Performa 6200 vertical lines. Source for the all-in-one analog-board video faults on the x200/x400 Performas.
- โ Low End Mac โ Performa 5200 and Power Mac 6200/Performa 6200; and 68kMLA "Performa/Power Mac 5200-6300 Issues" discussions. Source for the x200 road-apple architecture (Quadra 605-based 32-bit board with a 64-bit 603 CPU and 8-bit IDE) and its capacitor/PSU faults.
