Apple Lisa Troubleshooting
Troubleshooting is essential for diagnosing and resolving issues with your Apple Lisa. This guide covers the most common problems encountered with Lisa systems.
Preliminary Checks
- Verify power outlet is working
- Check that all cables are properly connected
- Ensure the power supply voltage selector (if present) is set correctly for your region
- Allow adequate time for capacitor discharge before internal work (24+ hours)
No Power / Dead System
| No response when power switched on | Failed RIFA safety capacitors | Inspect and replace RIFA capacitors in power supply |
| Clicking or ticking from power supply | Power supply overload or short | Check for shorts on motherboard; replace power supply capacitors |
| Trips circuit breaker | Shorted RIFA capacitor | Replace all RIFA safety capacitors immediately |
| Power supply smokes | RIFA capacitor failure | Disconnect immediately; replace all safety capacitors |
| Intermittent power | Failing electrolytic capacitors | Full power supply recap recommended |
| Powers on briefly then shuts off | Power supply protection circuit triggering | Check for shorts; verify output voltages |
RIFA Capacitor Failure
RIFA-brand safety capacitors are the most common cause of Lisa power problems:
- These capacitors absorb moisture over decades and fail catastrophically
- They may emit smoke, loud pops, or acrid smell when failing
- ALWAYS replace preventatively before powering on a long-stored Lisa
- Replace with modern X2-rated capacitors of equivalent value
Self-Test Error Codes
The Lisa displays error codes during its self-test sequence:
| Error Code | Component | Description |
| 10-19 | CPU Board | CPU board failure; check RAM, ROM, or processor |
| 20-29 | I/O Board | I/O board error; check IWM, serial ports, or ROM |
| 57 | Disk Controller | Disk controller failure on I/O or CPU board |
| 70-79 | Memory | Memory card error (icon shows affected slot: MEM1 or MEM2) |
| 80-89 | Storage | Hard drive or floppy drive error |
| 82 | Widget | Generic Widget drive failure |
Error 57 (Disk Controller)
- Reseat all socketed chips on the I/O board
- Check the IWM (Integrated Woz Machine) chip
- Verify I/O ROM is correct version (H/88 for Lisa 2/10)
- Inspect for cracked solder joints
Error 70 (Memory)
- The error icon shows which memory slot is affected (MEM1 or MEM2)
- Try each memory card individually
- Clean the edge connector contacts with isopropyl alcohol
- Individual RAM chip testing may be required
Error 82 (Widget)
- Generic Widget drive failure code
- Widget may require low-level format (no utility publicly available)
- Consider ProFile emulator (X/ProFile, IDEfile) as replacement
- Check Widget cable connections
Video Problems
| No display, system runs | CRT failure or analog board issue | Check CRT connections; test analog board |
| Horizontal line only | Vertical deflection failure | Check vertical output IC and capacitors on analog board |
| Vertical line only | Horizontal deflection failure | Check horizontal output transistor and flyback |
| Image shifted horizontally | H-position adjustment needed | Adjust horizontal position potentiometer |
| Garbled/checkered display | Memory or video RAM issue | Test with known-good memory cards |
| Bright flash/line at shutdown | Normal CRT behavior | CRT discharge is expected at power-off |
| Dim or faded display | CRT aging or brightness adjustment | Adjust brightness; CRT may need replacement |
CRT Adjustments
- Horizontal and vertical position/size controls are on the analog board
- Focus adjustment may be on the flyback transformer
- Always discharge CRT before making adjustments
Keyboard Problems
| No keys working | Keyboard cable disconnected | Check cable connection to I/O board |
| Most keys not working | Deteriorated foam pads | Replace capacitive foam and foil pads |
| Some keys work, others don't | Individual pad failure | Replace foam/foil on affected keys |
| Keyboard error on boot | Keyboard not detected | Check cable; verify keyboard controller chip |
Foam Pad Replacement
The Lisa keyboard uses capacitive foam pads that deteriorate with age:
- Purchase Lisa keyboard foam/foil replacement kit
- Each key requires a new foam pad and conductive foil
- This is the most common Lisa keyboard repair
Floppy Drive Problems
| Drive won't accept disk | Seized eject mechanism | Clean and lubricate mechanism with isopropyl alcohol |
| No disk spinning | Motor or motor controller failure | Check TA7259 motor IC; may require spindle repair |
| Read errors | Dirty heads or alignment | Clean heads; check for alignment issues |
| Intermittent reads | Failing capacitors near drive controller | Check/replace associated capacitors |
Floppy Emu Compatibility
- FloppyEmu can be used with Lisa systems
- Requires appropriate cable adapter
- External connection may require modification
Widget Drive Problems
The Widget (internal hard drive in Lisa 2/10) has known reliability issues:
| Widget not recognized | Cable connection or controller failure | Check cables; verify controller on I/O board |
| Error 82 on boot | Generic Widget failure | Drive may need replacement with ProFile emulator |
| Widget spins but won't boot | Corrupted data or head issues | Attempt boot from floppy; consider drive replacement |
| Clicking sounds from Widget | Head or mechanism failure | Drive likely requires replacement |
ProFile Emulator Options
Modern alternatives to the Widget drive:
- X/ProFile โ Drop-in Widget replacement using CompactFlash
- IDEfile โ ProFile emulator using IDE drives
- Both provide higher reliability than original Widget drives
โ ๏ธ The I/O-board battery pack โ remove it now
The Lisa keeps its real-time clock alive with a 4 ร AA NiCd pack strapped to the bottom-right of the I/O board. These packs leak corrosive electrolyte and are the single most destructive Lisa fault — when they let go they can destroy the I/O board and the motherboard, and in rare cases the CPU and RAM boards. Remove the battery pack from any Lisa immediately, and clean and repair any corrosion before powering up.[1]
Boot self-test and error codes
The Lisa boot ROM runs a self-test and, on a fault, shows a numeric error code and draws a cross (X) over the icon of the failing board. Useful codes:
- 40 โ CPU-board / MMU fault (a failed MMU register test loops endlessly; the CRT goes blank once warm).
- 57 โ disk-controller fault.
The card-based design makes diagnosis a matter of swapping the CPU, memory and I/O boards; almost everything is user-replaceable except the CRT and video board.[1]
A Lisa that runs for a few minutes and then switches off, or will not power on at all, has a failing power supply โ a known weak point that should be serviced/recapped.[1]
Twiggy drives (Lisa 1)
The Lisa 1 used two Apple "Twiggy" 5.25-inch 860 KB drives, which were unreliable; most Lisa 1s were upgraded to the Lisa 2 with a Sony 400 KB 3.5-inch drive. Twiggy read errors and disk-boot failures are why so few Lisa 1s survive — a Lisa 2 conversion or a modern floppy emulator is the usual path.[1]
- โ 1.0 1.1 1.2 1.3 The Apple Lisa FAQ; Lisa 2 repair journey, TinkerDifferent; Rejuvenating an Apple Lisa 2/10, Tezza's Classic Computers; and the Apple Lisa Do-It-Yourself Guide. Source for the I/O-board battery-pack leakage, the PSU failure, the Twiggy-drive unreliability, and the boot-ROM error codes (40 = CPU/MMU, 57 = disk controller).
