Macintosh Performa 5400 Troubleshooting
Troubleshooting is essential for diagnosing and resolving issues with your Macintosh Performa 5400 series computer. This guide covers the most common problems encountered with these all-in-one systems.
Preliminary Checks
- Verify power outlet is working
- Check that power cable is fully seated
- Ensure the power switch is in the ON position
- Test with a known-good keyboard (power-on issues)
- Remove all external devices except keyboard and mouse
No Power
| Completely dead, no fan | Power supply failure | Test outlet; check power cable; inspect PSU capacitors |
| Clicking or ticking sound | PSU overload or short | Disconnect drives; check for shorts on logic board |
| Fan spins briefly then stops | PSU crowbar circuit triggered | Check for shorts; test with minimal configuration |
| Power light on, no startup | Logic board failure | Check PRAM battery; reseat RAM; inspect for corrosion |
Power Supply Voltage Check
If the system powers on but behaves erratically, measure PSU voltages:
- +5V: Should read 4.85V โ 5.15V
- +12V: Should read 11.9V โ 12.7V
- +3.3V: Should read 3.2V โ 3.4V
No Video
| Startup chime, black screen | CRT failure; video RAM issue | Check CRT connections; listen for drive activity |
| Dim or faded display | Weak CRT; failing flyback | Adjust screen brightness pot; replace flyback if needed |
| Horizontal or vertical collapse | Deflection circuit failure | Check analog board capacitors; inspect yoke connections |
| Color fringing or rainbow effects | Degaussing needed; failing neck board | Use degauss function; check neck board solder joints |
| Geometric distortion | Capacitor failure | Recap analog board; check deflection adjustments |
Startup Issues
| Sad Mac icon | Hardware failure | Note error code; see Sad Mac Error Codes |
| Flashing question mark | No bootable system | Check hard drive; boot from CD; reinstall system |
| Chimes of death | RAM failure | Reseat RAM; test with known-good modules |
| Simasimac-like patterns | VRAM/logic board failure | Clean video RAM area; check for corrosion |
| Freezes during startup | Software corruption; hardware fault | Boot from CD; check extensions; test RAM |
Audio Problems
| No startup chime | Speaker failure; logic board issue | Test with headphones; check speaker connection |
| Distorted audio | Capacitor failure | Recap logic board audio section |
| Crackling or popping | Bad capacitors; loose connection | Recap; check speaker wire connections |
| Low volume | Failing capacitors | Recap logic board; check software volume settings |
CD-ROM Drive Issues
| Tray won't eject | Mechanical failure; belt worn | Manual eject with paper clip; replace drive |
| Disc not recognized | Dirty lens; laser failure | Clean lens with isopropyl; replace drive if needed |
| Slow read speeds | Dirty lens; drive aging | Clean lens; accept reduced performance or replace |
| Audio CDs work, data CDs don't | Laser calibration | Try cleaning; likely needs replacement |
Floppy Drive Issues
| Disc won't insert | Foreign object; mechanical jam | Inspect slot; check for stuck eject mechanism |
| Disc won't eject | Mechanical failure | Use manual eject hole; check eject motor |
| Read/write errors | Dirty heads; alignment issues | Clean heads; try new disk; replace drive |
| Drive not recognized | Cable issue; logic board fault | Reseat ribbon cable; test with known-good drive |
Hard Drive Issues
| Clicking sounds | Head failure | Back up immediately if possible; replace drive |
| Drive spins but not detected | Controller failure; cable issue | Check IDE cable; try drive in external enclosure |
| Slow performance | Fragmentation; failing drive | Run Disk First Aid; check SMART data; replace if failing |
| Intermittent failures | Cable issues; power problems | Reseat cables; check PSU voltages |
Networking Issues
| No network connection | Cable issue; driver problem | Check cable; verify TCP/IP settings |
| Intermittent connectivity | Failing Ethernet port | Try different cable; check for corrosion on port |
| Slow speeds | Network configuration | Verify 10Base-T compatibility; check hub/switch |
โ ๏ธ PRAM battery
The Performa 5400 uses a 3.6 V 1/2AA lithium PRAM battery that leaks and can burst, corroding the logic board. Remove it from any un-serviced unit and clean/repair any leakage before troubleshooting.[1]
โ ๏ธ Recap (logic board and PSU)
The Performa 5400 uses aluminium electrolytic capacitors on both the logic board and the power supply, and they leak with age. Recap and clean both boards as a first step; the large 2200 uF PSU filter capacitors in particular are a known failure point, giving a dead machine, failure to power on, or instability.[2]
All-in-one analog board and video
As an all-in-one with a built-in CRT, this machine has an analog board like the compact and Color Classic Macs. Vertical lines, a collapsed raster, dim or distorted video, or no video with the machine otherwise alive point to the analog board โ reflow cracked solder joints (deflection yoke and flyback area) and recap the analog board.[3]
- โ 68kMLA โ Exploding Maxell PRAM Batteries. Source for the leaking/exploding 3.6 V lithium PRAM battery.
- โ Recap-a-Mac โ Power Macintosh 6100; Badcaps "Macintosh 6100 power supply"; and the Apple Performa/Power Macintosh 6400/6500 Service Source. Source for the logic-board and power-supply electrolytic failures (including the 2200 uF PSU capacitors) and the recap.
- โ 68kMLA โ Performa 6200 vertical lines. Source for the all-in-one analog-board video faults on the x200/x400 Performas.
Surface-mount capacitor leakage
The Macintosh Performa 5400 logic board uses surface-mount electrolytic capacitors whose electrolyte turns corrosive with age and creeps across the board, eating through traces, pads and IC pins. Typical signatures are a machine that will not chime, chimes but shows no video, plays distorted or missing audio, or shows a garbled or checkerboard screen. Wash the affected area and replace every electrolytic with a tantalum or polymer part, then repair any lifted traces. The switch-mode power supply (ASTEC or TDK on the LC-family machines) holds its own electrolytics and fails the same way, so recap it alongside the board.[1]
PRAM battery
The Macintosh Performa 5400 backs up its clock and Parameter RAM from a 3.6 V ½AA lithium cell. These cells — red Maxell parts especially — leak or burst and corrode the board, so remove an aged one on sight. A flat cell can also stop a soft-power machine booting or disturb the video; left plugged in, trickle power preserves the settings, but a machine switched off at the wall with a dead cell loses them. Clean the area and fit a fresh 3.6 V cell.[2]
Analog board and CRT
As an all-in-one, the Macintosh Performa 5400 carries an analog/CRT board with a flyback and a high-voltage section. A clicking or ticking board, no raster, or a dead set with no CRT glow point there rather than to the logic board. Observe CRT discharge safety before working inside.
Boot chime and Sad Mac
Related Pages
- Macintosh Performa 5400CD
- Macintosh Performa 5400 General Maintenance
- Macintosh Performa 5400 Capacitor Replacement Guide
- Sad Mac Error Codes
- โ Mac84, Macintosh LC series power-supply recapping guide; the MacCaps capacitor reference; and iFixit. Source for surface-mount electrolytic leakage eating traces, pads and pins, the ASTEC/TDK LC power-supply cap failures, and Apple's use of tantalum (non-leaking) capacitors on the Quadra 700/900 logic boards.
- โ Warning! Exploding Maxell PRAM batteries, 68kMLA; and Mac Battery Leaks, MacDat. Source for the 3.6 V ½AA lithium PRAM cell, the Maxell leak/explosion board damage, and soft- versus hard-power PRAM retention.
