Macintosh 128K/512K Capacitor Replacement Guide
Revision as of 23:05, 4 April 2025 by Josh (talk | contribs)
Replacing electrolytic capacitors (recapping) in your Macintosh 128K and 512K is essential for long-term reliability. Over time, capacitors degrade, leading to voltage instability, display artifacts, and system failure. Proactively replacing these components ensures continued functionality and prevents potential board damage.
🔍 Capacitor Inspection
Before replacing capacitors, carefully inspect them for deterioration. Common failure symptoms include:
  • Bulging Tops – A properly functioning capacitor has a flat top. Swelling or doming indicates failure.
  • Leaking Electrolyte – Brown or white crust around capacitor leads signals internal leakage.
  • Corrosion – PCB staining or green residue near the base of a capacitor suggests corrosion.
If any of these symptoms are present, replacement is highly recommended.
📋 Macintosh 128K/512K Capacitor List
The Macintosh 128K and 512K analog board and logic board contain electrolytic capacitors that should be replaced proactively. Below are verified capacitor specifications for both boards.
🧯 Analog Board Capacitors
Macintosh 128K/512K Analog Board Capacitor Specifications
C1 3.9µF 35V 1x
C2 4700µF 16V 1x
C3 220µF 16V 2x
C5 47µF 10V 1x
C6 22µF 50V 2x
C10 33µF 16V 2x
C11 10µF 160V 1x
C12 22µF 50V 2x
C18 33µF 16V 2x
C24 2200µF 16V 4x
C27 2200µF 16V 1x
C28 1000µF 16V 1x
C30 2200µF 16V 1x
C31 220µF 16V 1x
C32 2200µF 16V 1x
C33 4700pF 250V 2x
C34 100µF 200V 4x
C35 100µF 200V 1x
C36 4700pF 250V 1x
C37 0.47µF 250V 1x
C38 100µF 200V 1x
C39 100µF 200V 1x
C42 470µF 10V 2x
C45 470µF 10V 1x
💾 Logic Board Capacitors
Macintosh 128K/512K Logic Board Capacitor Specifications
C1 1µF 50V 1x
C7 1µF 50V 1x
C9 1µF 50V 1x
C15 47µF 16V 1x
C21 1µF 50V 1x
C24 220µF 10V 1x
C27 1µF 50V 1x
C31 1µF 50V 1x
C32 1µF 50V 1x
C33 1µF 50V 1x
C34 1µF 50V 1x
> Note: Capacitor numbering may vary slightly between early 128K and 512K revisions. Always verify location and values against your specific board version before ordering replacements.
🛠️ Capacitor Replacement Procedure
Proper capacitor replacement requires care and the right tools. Follow these steps:
  1. Discharge CRT – Fully discharge the CRT before opening the system to avoid electric shock.
  2. Disassembly – Carefully remove the analog board and/or logic board, noting cable connections.
  3. Desoldering – Use a solder pump or wick to remove capacitors without lifting traces.
  4. Install Replacements – Insert new capacitors with correct polarity (+ and – markings).
  5. Soldering – Apply clean, shiny joints and trim excess leads.
  6. Final Inspection – Confirm all joints are clean and test for shorts using a multimeter.
  • Temperature-controlled soldering iron (fine tip)
  • Desoldering braid or solder sucker
  • Multimeter (continuity and voltage testing)
  • Isopropyl alcohol and ESD brush (for board cleaning)
  • Safety glasses and insulated gloves
⚙️ Voltage Adjustment Post-Recap
After recapping, test voltages at the floppy or logic board connector using a multimeter:
  • +5V Rail: 4.85V – 5.15V
  • +12V Rail: 11.9V – 12.7V
Adjust if necessary using the analog board’s trimmer potentiometer (R56).
💡 Additional Tips
  • Power up the Macintosh periodically to preserve capacitor function.
  • Always use high-quality capacitors from trusted brands.
  • If full recapping isn't feasible, replace in matching sets or sections.
  • Recycle old capacitors at an electronics waste facility.
Capacitor Replacement Guides
