Macintosh Plus Capacitor Replacement Guide
The Macintosh Plus logic board rarely needs recapping: its electrolytics are axial and radial through-hole parts, not the surface-mount capacitors that leak on later Macintoshes, and Recap-a-Mac says most Plus problems start on the analog board.[1] That board, which Apple calls the power/sweep board, holds the mains switch-mode supply and the CRT sweep circuits. Apple's service manuals for the Plus are module-level and give no component values; the values below come from the parts lists in Larry Pina's Macintosh Repair & Upgrade Secrets, checked against Console5's capacitor-kit lists, which are community lists read from boards.[2][3]
Safety
[edit | edit source]The power/sweep board is connected to the mains and the CRT holds a high-voltage charge after power-off. Unplug the machine and discharge the CRT before touching the board, the anode lead or the CRT socket board; see CRT Discharge Procedure. The 200 V electrolytics (C35 and C36 on the U.S. board) hold the rectified mains, about 170 V on a 120 V supply: measure across them before touching that side.[2][4] Apple warns not to wear a grounding wrist strap until the CRT is discharged.[3] |
Visual inspection
[edit | edit source]- A healthy electrolytic has a flat top. A bulging top, or bulging at the base, means the part has failed. On C1 the base is often buried in hot glue.[4]
- Brown or white crust at the leads is leaked electrolyte; look for corrosion or discoloured board under and around the part.
- The RIFA metallised-paper safety capacitors crack and blacken with age.[1]
See Capacitor Failure Symptoms.
Logic board
[edit | edit source]The Plus logic board, 820-0174, has six electrolytics.[5]
| Reference | Capacitance | Voltage |
| C5 | 33 µF | 16 V |
| C6 | 33 µF | 16 V |
| C7 | 33 µF | 16 V |
| C12 | 33 µF | 16 V |
| C13 | 33 µF | 16 V |
| C14 | 1 µF | 50 V |
Console5's community list gives the designators. Recap-a-Mac's photographic guide, made from an 820-0174-D board, marks the same six positions on the silkscreen: 33 µF 16 V at C5, C6, C7, C12 and C13 and 1 µF 50 V at C14.[5][1] The 128K and 512K logic board, 630-0101, has a different set: C5 and C20 at 33 µF 16 V and C22 at 4.7 µF 35 V.[6]
The logic board carries no battery. The 4.5 V PRAM battery sits in the compartment on the back of the case, in a holder on the power/sweep board, and reaches the logic board through pin 11 of J4.[3][4]
Power/sweep board
[edit | edit source]The 128K, 512K and Plus have no separate power supply: the one board behind the CRT carries the mains input, the switch-mode supply, the horizontal and vertical sweep and the video amplifier.[4] Apple sold it in two versions, 661-0462 for 110 V and 661-76214 for 220 V; the 128K/512K Service Source lists 661-76214 as the power/sweep board for those machines.[3][7] Apple's 1994 Module Identification manual also lists 661-0461, the 110 V board with a beige power switch instead of a platinum one, and says 661-0461 and 661-0462 replaced the earlier 661-76153.[8] Pina publishes separate parts lists for the U.S. and International boards, and the two use the same designators for different parts. Console5's list for board 630-0102 matches Pina's U.S. list position for position, and its list for 630-0108 matches his International list; Mac84 describes 630-0102 as the US/120 V board.[2][9][10][11] Read the 630- number on your board before using either table.
U.S. board (630-0102)
[edit | edit source]| Reference | Capacitance | Voltage | Rated temperature | Type (Pina) |
| C1 | 3.9 µF | 25 V (35 V alternative) | 85 °C | Non-polar, HF; see below |
| C2 | 4700 µF | 16 V | 85 °C | Radial |
| C3 | 220 µF | 16 V | 105 °C | Radial |
| C5 | 47 µF | 10 V | 85 °C | Axial |
| C6 | 22 µF | 50 V | 85 °C | Axial |
| C9 | 10 µF | 160 V | 85 °C | Axial |
| C11 | 33 µF | 16 V | 85 °C | Radial |
| C13 | 33 µF | 16 V | 85 °C | Radial |
| C14 | 22 µF | 50 V | 85 °C | Radial |
| C24 | 2200 µF | 10 V or 16 V | 85 °C | Radial |
| C25 | 1000 µF | 16 V | 105 °C | Radial |
| C26 | 1000 µF | 16 V | 105 °C | Radial |
| C29 | 2200 µF | 10 V | 105 °C | Radial |
| C30 | 220 µF | 16 V | 105 °C | Radial |
| C31 | 1000 µF | 16 V | 105 °C | Radial |
| C33 | 4700 pF | 250 V | - | RIFA safety capacitor |
| C35 | 100 µF | 200 V | 85 °C | Radial |
| C36 | 100 µF | 200 V | 85 °C | Radial |
| C37 | 4700 pF | 250 V | - | RIFA safety capacitor |
| C38 | 0.1 µF | 250 V | - | RIFA safety capacitor |
| C39 | 470 µF | 10 V | 85 °C | Radial |
| C43 | 470 µF | 10 V | 85 °C | Radial |
Values, voltages and temperatures are Pina's originals; he also lists acceptable 25 V parts for C25, C26 and C31, and 16 V parts for C24 and C29.[2] Console5's kit list has the same values, gives C38 as 275 V, and notes that C3 and C30 are 25 V on some revisions and that early boards have a series resistor on the negative lead of C6. Console5 says C33 and C37 can stay where they are ceramic discs; RIFA parts in those positions should be replaced.[9] The board Mac84 photographed, from a Macintosh 512K, had higher-rated parts fitted at C1 (50 V), C24 and C29 (16 V) and C25, C26 and C31 (35 V).[11] Fit the rating on your own board or higher.
Thomas Lee names C24-C26 and C29-C31 as weak spots: with no fan they run too hot, which shortens their life. He names rectifiers CR20 and CR21 as the other weak spots on this side of the supply.[4]
International board (630-0108)
[edit | edit source]| Reference | Capacitance | Voltage | Type (Pina) |
| C1 | 3.9 µF | 25 V (35 V alternative) | Non-polar, HF; see below |
| C2 | 4700 µF | 16 V | Radial |
| C3 | 220 µF | 16 V | Radial, 105 °C |
| C5 | 47 µF | 10 V | Axial |
| C6 | 22 µF | 50 V | Axial |
| C10 | 33 µF | 16 V | Radial |
| C11 | 10 µF | 160 V | Radial |
| C12 | 22 µF | 50 V | Axial |
| C18 | 33 µF | 16 V | Axial |
| C24 | 2200 µF | 16 V | Radial, 105 °C |
| C27 | 2200 µF | 10 V | Radial, 105 °C |
| C28 | 1000 µF | 16 V | Radial, 105 °C |
| C30 | 2200 µF | 10 V | Radial, 105 °C |
| C31 | 220 µF | 16 V | Radial, 105 °C |
| C32 | 2200 µF | 16 V | Radial, 105 °C |
| C33 | 4700 pF | 250 V | RIFA safety capacitor |
| C34 | 100 µF | 200 V | Radial |
| C35 | 100 µF | 200 V | Radial |
| C36 | 4700 pF | 250 V | RIFA safety capacitor |
| C37 | 0.47 µF | 250 V | RIFA safety capacitor |
| C38 | 100 µF | 200 V | Radial |
| C39 | 100 µF | 200 V | Radial |
| C42 | 470 µF | 10 V | Radial |
| C45 | 470 µF | 10 V | Radial |
Pina lists 16 V alternatives for C27 and C30, and Console5 notes that later builds used 16 V there. Console5 notes that C33 and C36 may be ceramic discs on some builds, and that C37 is sometimes a RIFA part.[2][10] On this board C9 is a 0.22 µF 100 V film capacitor, not an electrolytic.[2]
C1
[edit | edit source]C1 is in the horizontal sweep circuit and carries large high-frequency currents. It is a non-polar part. Pina's lists give 3.9 µF non-polar electrolytics at 25 V or 35 V as original, and accept a 4.0 µF axial, a 3.9 µF 100 V non-polar electrolytic, or 3.9 µF metallised polyester or polypropylene film at 100 V or 250 V.[2] In The Dead Mac Scrolls he recommends the 100 V part to stop the fault recurring.[12] Lee finds 3.9 µF or 4.7 µF fitted, depending on model and date, and describes the original type as unsuitable: its ESR rises as it warms, which heats it further. He recommends a non-polar, low-ESR part rated at 50 V or more, or four or five 1 µF 50 V ceramic disc capacitors in parallel.[4] Console5 notes that later boards may have a 3.3 µF 50 V part or an axial film capacitor here.[9]
Pina describes the failure in stages: poor horizontal linearity (things on the left wider than on the right), then bright diagonal lines a few minutes after switch-on with the picture darkening, or a bright vertical line, and finally smoke. Switch off at the first sign.[12]
Before recapping: common non-capacitor faults
[edit | edit source]Recap-a-Mac's triage for a Plus:[1]
- Completely dead, no chime: almost certainly the analog board. Check the RIFA capacitors for cracking or blackening, the fuse, cracked solder joints (especially at the connectors), the resistors along the bottom of the board and the diodes, then recap.
- Chimes, but the screen is black: check the brightness control on the bottom front of the case, then look for cracked joints at the connectors.
- Boots, but the picture flickers or wobbles, or the machine restarts at random: cracked joints at the connectors, then check and adjust the output voltage; if both are good, recap.
Lee calls cracked solder joints at the yoke connector J1 the most common fault on the analog board. They cause an intermittent, wobbly, missing or narrow raster, or a single vertical line down the centre, and slapping the side of the case often makes the symptom come and go. Resolder all four J1 pins with fresh solder while the connector halves are still mated, or the heat will distort the plastic.[4] Lee's pinout of the three analog board connectors, viewed from the component side:[4]
| Pin | J1 (yoke) | J4 (to logic board) | J2 (to CRT socket board) |
| 1 | Vertical yoke high | Video | G1 bias |
| 2 | Vertical yoke low | - | Not connected |
| 3 | Ground | Horizontal sync | Focus |
| 4 | Horizontal yoke | Sound | - |
| 5 | Vertical sync | Brightness | |
| 6 | +5 V | Ground | |
| 7 | Ground | Ground | |
| 8 | −12 V | CRT +12 V | |
| 9 | Ground | CRT cathode | |
| 10 | +12 V | ||
| 11 | +4.5 V battery |
Replacement procedure
[edit | edit source]- Unplug the machine, remove the case and discharge the CRT; see CRT Discharge Procedure.
- Measure across the 200 V capacitors to confirm they are discharged.
- Photograph the board, recording the polarity of every electrolytic.
- Remove each part cleanly with desoldering braid or a pump. Do not lever a part out on one molten lead.
- Clean the pads and check for corrosion or lifted tracks.
- Fit the new parts with the negative stripe matching the original. C1 is non-polar.
- Inspect the joints under magnification for bridges and cold joints.
- Check each rail for shorts before applying power.
- Set the voltages as below.
Tools are listed on Recommended Tools.
Voltage adjustment
[edit | edit source]Apple requires the voltages to be checked whenever the logic board or the power/sweep board is replaced.[3]
- Set the meter to the 20 V DC range and connect Apple's voltage test cable, part 077-0135, to the external drive port. Keep the insulating hoods on the plugs not in use: shorting them together damages the computer.
- Connect the black lead to the chassis and the orange lead to the meter. Switch on and set the voltage control on the power/sweep board for +12 V between 11.90 V and 12.75 V.
- Switch off, change to the red lead, switch on and set +5 V between 4.85 V and 5.15 V.
- Repeat both checks. If both cannot be brought into tolerance together, replace the board.
Source: Apple's Macintosh Plus Service Source.[3] Apple's 1987 Technical Procedures for the Macintosh and Macintosh Plus give a tighter +12 V window, 11.90-12.3 V, adjusted to 12.3 V, and take the readings with no peripherals attached and the internal drive not running.[13]
Without the test cable, Lee measures at the external floppy connector: +5 V on pin 6, +12 V on pins 7 and 8, −12 V on pin 5, with ground on the threaded standoffs either side. He sets +5 V to 5.00 V and then checks that +12 V is still between 11.9 V and 12.75 V, cold and warm.[4]
The control is R56, just above the speaker. It is the supply's only voltage adjustment: the regulator senses the +12 V output through R35, R56 and R38, and the other outputs follow it through the transformer turns ratios, so +5 V and +12 V move together.[4] If +5 V is low because of resistance in the J4 connector, turning R56 up to compensate drives +12 V over its limit. Lee's first step for a Plus that bongs, resets and bongs again is to clean the J4 contacts, which he says fixes nine cases in ten, and he gives the same cause for most failures to get both rails into range at once.[4] Viewed from the side covered by the cardboard insulator, turning R56 clockwise lowers the output.[4]
The "whup-whup-whup" noise
[edit | edit source]If the +12 V rail rises about 15 % over specification, a 12 A crowbar SCR, Q8, short-circuits it and forces the supply into current limiting. The supply keeps trying to recover, which makes a rhythmic "whup-whup-whup" sound. To rule out a misadjusted R56, turn it fully clockwise (viewed from the insulator side) for the lowest setting; if the noise continues, the fault is elsewhere.[4]
Module part numbers
[edit | edit source]From Apple's exploded view for the Macintosh Plus:[3]
- Power/sweep board: 661-0462 (110 V), 661-76214 (220 V)
- Logic board: 661-0525
- CRT and yoke assembly: 076-0103; CRT socket cable 590-0160
- Front bezel: 810-0379 (810-0385 platinum)
- Rear housing: 630-5211 (630-5235 platinum)
Choosing replacements
[edit | edit source]- Match or exceed the voltage rating on the part you remove; where sources differ, the higher rating is safe.
- Use 105 °C parts where Pina's list specifies them (C3, C25, C26, C29, C30 and C31 on the U.S. board).[2]
- Fit only a non-polar part at C1.
- Replace RIFA metallised-paper safety capacitors; ceramic discs in the same positions can stay.[9]
[edit | edit source]- Macintosh Repair & Upgrade Secrets: Appendix C, U.S. analog board parts list (p. 327); Appendix D, International analog board (p. 335).[2]
- The Dead Mac Scrolls[12]
- Macintosh Plus Service Source[3]
- Apple Technical Procedures: Macintosh and Macintosh Plus (1987)[13]
[edit | edit source]- Macintosh Plus
- Macintosh Plus Troubleshooting
- Macintosh Plus General Maintenance
- Macintosh 128K/512K Capacitor Replacement Guide
- Capacitor Failure Symptoms
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 Macintosh Plus, Recap-a-Mac—link(accessed 2026-09-30) Logic board rarely needs recapping; most problems on the analog board; no analog board guide (240 V region); fault triage; photographic logic board guide.
- ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 Larry Pina, Macintosh Repair & Upgrade Secrets (Hayden Books, 1990), ISBN 0-672-48452-8, File:Macintosh Repair & Upgrade Secrets.pdf; see Macintosh Repair & Upgrade Secrets. Appendix C, "Parts List - Macintosh Analog Board - U.S. Version", capacitors pp. 327-328; Appendix D, "Parts List - Macintosh Analog Board - International Version", capacitors pp. 335-336. Each entry gives capacitance, working voltage, working temperature, type and original manufacturer, with acceptable substitutes.
- ↑ 3.0 3.1 3.2 3.3 3.4 3.5 3.6 3.7 Apple Computer, Macintosh Plus Service Source, File:Macintosh Plus.pdf; see Macintosh Plus Service Source. Memory p. 7 (PRAM battery); Take Apart, cover and battery compartment pp. 27-28, power/sweep board pp. 29-32 (CRT discharge, wrist strap warning, battery moved to the exchange board); Adjustments, Voltage pp. 51-57; Exploded View p. 69. Module-level: no component values.
- ↑ 4.00 4.01 4.02 4.03 4.04 4.05 4.06 4.07 4.08 4.09 4.10 4.11 4.12 Thomas H. Lee, Classic Mac Repair Notes, rev. 31 May 2007 (©2000 Thomas H. Lee, all rights reserved; not hosted here), archive.org. Section 4.1, pp. 3-4 (J1 solder joints, C1); 4.2, pp. 5-6 (R56, J4 contacts, CR20/CR21 and C24-C26/C29-C31 running hot); 5.1, p. 8 (voltage adjustment, external floppy connector pins, R56 direction); 7.4, pp. 19-23 (170 V raw supply, regulator loop through R35, R56 and R38, R56 above the speaker, 90% of out-of-range cases from J4 contacts, crowbar Q8); 8.0, Figure 16, p. 23 (connectors).
- ↑ 5.0 5.1 Macintosh Plus, Console5 TechWiki—link(accessed 2026-09-30) Logic board 820-0174 capacitor list. Secondary source.
- ↑ Macintosh 128K, Console5 TechWiki—link(accessed 2026-09-30) Logic board 630-0101: C5 and C20 33 µF 16 V, C22 4.7 µF 35 V. Secondary source.
- ↑ Apple Computer, Macintosh 128K/512K Service Source, File:Macintosh 128k.512k.pdf; see Macintosh 128K/512K Service Source. Exploded View (last page): power/sweep board 661-76214.
- ↑ Apple Computer, Module Identification (072-8124, June 1994), Power Supplies, sections 3.1.1 "Macintosh Power Supply (110 V)" and 3.1.2 "Macintosh Power Sweep Board (220 V)" (PDF pp. 195-196). See Apple Service Module Identification Manual (1994).
- ↑ 9.0 9.1 9.2 9.3 Mac Analog Board: 630-0102, Console5 TechWiki—link(accessed 2026-09-30) Capacitor kit list with revision notes. Secondary source.
- ↑ 10.0 10.1 Mac Analog Board: 630-0108, Console5 TechWiki—link(accessed 2026-09-30) Capacitor kit list with revision notes. Secondary source.
- ↑ 11.0 11.1 Macintosh 128K / 512K / Plus Analog Board Recapping Guide (model 630-0102) US / 120V, Mac84—link(accessed 2026-09-30) Original capacitors photographed on a Macintosh 512K board. Secondary source.
- ↑ 12.0 12.1 12.2 Larry Pina, The Dead Mac Scrolls (Peachpit Press, 1992), File:The Dead Mac Scrolls 1992.pdf. "Early Macs" chapter, pp. 44-46 (C1: poor linearity, diagonal lines, vertical line, smoke; 100 V replacement).
- ↑ 13.0 13.1 Apple Computer, Apple Technical Procedures: Macintosh and Macintosh Plus, pages rev. Feb 87 to Jun 87, File:Apple Technical Procedures Macintosh and Macintosh Plus 1987.pdf. Section 5, Power/Sweep Voltage Adjustment, pp. 5.2-5.3 (PDF pp. 65-66).
