Commodore PET 4000 Series
| Commodore PET 4032 with the 12-inch monitor | |
| Manufacturer | Commodore Business Machines |
| Type | Personal computer |
| Released | 1980[1] |
| CPU | MOS Technology 6502 at 1 MHz |
| Memory | 16 KB or 32 KB dynamic RAM, by model |
| Storage | IEEE-488 disk drives; two external cassette ports |
| Display | Built-in 9-inch or 12-inch monochrome CRT, 40 × 25 text |
| Sound | Piezo transducer MT1 on 12-inch models |
| Power | Internal linear supply: transformer, 23,000 µF filter capacitor, 1.6 A slow-blow fuse |
| OS / Firmware | Commodore BASIC 4.0 |
| Predecessor | Commodore PET 2001 |
| Successor | CBM 8000 series |
| Model no. | 4016, 4032 |
The Commodore PET 4000 Series was introduced in 1980, replacing the PET 2001 and 3000 machines, and brought Commodore BASIC 4.0 with its disk commands.[1] It is built on the universal dynamic PET board, a different design from the static board in the original Commodore PET 2001, with different rails, regulators and crystal.
Commodore's PET 4000 Series Technical Manual, P/N 990438, is hosted here and is the source for the hardware figures below.[2]
Architecture and processor
The CPU is a MOS Technology 6502 at 1 MHz. The crystal Y1 is 16 MHz on this board, against 8 MHz on the PET 2001, which is a quick way to tell the two board generations apart.[2]
Commodore BASIC 4.0 adds disk commands such as DLOAD, DSAVE, CATALOG and SCRATCH.[1]
Power and rails
The supply chassis contains no regulator. Commodore's Power Supply Assy drawing 8032051 lists a transformer, one filter capacitor, a fuse, a fuse holder and a rocker switch.[2]
| Ref | Part | Commodore part no. |
| T1 | Transformer, on the universal power chassis 8032043-02 | 320902-01 |
| C1 | Filter capacitor, 23,000 µF | 900102-01 |
| F1 | Fuse, 125 V slow-blow, 1.6 A | 903557-04 |
| XF1, SW1 | Fuse holder and rocker switch | 903611-03, 904507-01 |
| Dynamic PET power harness | 320289-01 |
C1 stores real energy. Bleed it through a resistor before working near the chassis. Mains is present at the switch, fuse and transformer primary whenever the machine is plugged in.
The regulation is on the logic board:[2]
| Ref | Device | Output | Commodore part no. |
| VR1 | 7905, TO-220 | −5 V, 1.5 A | 901527-03 |
| VR2 | 7812, TO-3 | +12 V, 1 A | 901528-04 |
| VR4 | LM323 | +5 V | 901528-01 |
| VR5, VR6 | 7.5 V zener diodes | 900941-01 |
The +5 V regulator is an LM323, not a 7805. In the board photo below, VR2 and VR4 are the two TO-3 cans on the heatsink along the top edge.
The −5 V rail is a real difference from the PET 2001, whose static board has no −5 V regulator. Check all three rails, +5 V, +12 V and −5 V, on this board.
Rectification on the board is by bridges CR2 and CR4 (4 A, 50 V) and diodes CR1, CR5 and CR7 (1N4005), with CR3 a 1N5402.[2]
Storage and I/O
There is no internal cassette deck on a 4000-series machine. Storage is:
- IEEE-488 (GPIB) disk drives and printers
- Two cassette ports for external Datassettes
- The user port and the memory expansion connector
Video and sound
The display is character-based, 40 columns by 25 rows, on a built-in 9-inch or 12-inch monochrome CRT. The technical manual has waveform sets for both displays: drawing 321450 for the 12-inch and 321447 for the 9-inch.[2]
The board has a piezo transducer, MT1 (Commodore part 907300-02).[2] André Fachat notes that the 12-inch models have the beeper and, from BASIC 4, "chirp" at reset; a 12-inch machine that stays silent at reset points at the beeper signal or the VIA.[3]
Electrolytics on the logic board
Commodore's list for the universal dynamic PET board gives these electrolytics and tantalums; the rest of the C1-C97 range is ceramics and mica.[2]
| Ref | Value | Type | Commodore part no. |
| C1, C16, C17, C23, C24 | 10 µF 25 V | Low-leakage electrolytic | 900109-03 |
| C2 | 470 µF 16 V | Electrolytic | 900100-44 |
| C5 | 4700 µF 25 V | Electrolytic | 900100-45 |
| C7, C11 | 47 µF 16 V | Electrolytic | 900101-37 |
| C6, C51 | 1 µF 35 V | Tantalum | 900402-13 |
Commodore lists C1, C16, C17, C23 and C24 as low-leakage electrolytics, with a reference to note 4 on the drawing; fit low-leakage parts there. Fit tantalums at C6 and C51.
Logic board
| Logic board |
Common faults
- Boot failures: ROM or dynamic RAM, or a rail that is out. Check +5 V, +12 V and −5 V before condemning a chip.
- A machine that shows nothing may still be running. On this board the CPU has to program the CRT controller (UB13) before there is any picture,[2] so a blank screen does not separate a dead CPU from a dead video path the way garbage does on a PET 2001.[3]
- Keyboard: worn contacts and debris in the full-travel switches.
For fault-finding see Commodore PET 4000 Series Troubleshooting Guide; for routine care see Commodore PET 4000 Series Maintenance Guide.
Documentation hosted here
- Commodore PET 4000 Series Technical Manual: Commodore's drawing set, P/N 990438
- Commodore PET 2001 Service Documentation: the earlier static board
Gallery
Side view of a PET 4032
A PET 4032 with the top lifted
- Commodore PET 4000 Series Maintenance Guide
- Commodore PET 4000 Series Troubleshooting Guide
- CRT Discharge Procedure
- ↑ 1.0 1.1 1.2 Commodore PET—link(accessed 2026-10-01) Section on the 4000 series: launched in 1980 with BASIC 4.0.
- ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 Commodore Business Machines, PET 4000 Series Technical Manual, P/N 990438, for models 4016 and 4032, hosted at Commodore PET 4000 Series Technical Manual. Drawing 8032090 Rev H, "PCB ASSY - UNIV. DYNAMIC PET" (PDF pp. 3-7): capacitors by reference designator and Commodore part number; voltage regulators VR1 (7905, -5 V 1.5 A, 901527-03, TO-220), VR2 (7812, +12 V 1 A, 901528-04, TO-3) and VR4 (LM323, 901528-01); 7.5 V zeners VR5 and VR6; 16 MHz crystal Y1; piezo transducer MT1 (907300-02). Drawing 8032051, "Power Supply Assy" (PDF p. 39): transformer, 23,000 µF capacitor, fuse 125 V slow-blow 1.6 A, fuse holder and rocker switch.
- ↑ 3.0 3.1 André Fachat, PET repairs—link(accessed 2026-10-01)
