IBM PC XT Troubleshooting Guide
The IBM Personal Computer XT (5160) with IBM's BIOS reports faults through beeps and on-screen messages from its power-on self test (POST). The IBM PC (5150) Troubleshooting Guide covers the 5150, which differs in its switches, board versions and supply.
The POST is a confidence test only. No 201 error does not prove the RAM good, no 301 does not prove the keyboard good, and no 601 does not prove the floppy subsystem good.[1]
Before you start
- The XT is slow to start. IBM gives 13 to 90 seconds for a complete POST, depending on the options fitted; minuszerodegrees.net says it can take minutes before an error message appears.[2][3]
- The POST writes no codes a POST card can read.[3]
- After switching off, wait at least one second before switching on again, or the supply may not regenerate power good.[4]
- Check SW1 against what is fitted. Switch 1 must be off (on makes the POST loop); switch 2 is off when an 8087 is fitted and on when it is not; 3 and 4 set the system board memory; 5 and 6 the display; 7 and 8 the number of diskette drives.[5][6]
Normal power-on sequence
IBM describes a good start as follows:[2]
- A cursor appears after about four seconds.
- The memory size appears in the top left corner and counts up in 64 KB steps while the memory is tested (the 5150 does not show this).
- One short beep when the POST completes.
- The machine boots from diskette or fixed disk, or shows the Cassette BASIC screen if there is nothing to boot.
Minimum diagnostic configuration
For a machine that appears dead, minuszerodegrees.net reduces it to the system board, power supply and speaker, with no cards, no keyboard and no drives connected, and SW1 switches 5 and 6 both off (monochrome). About five seconds after switching on, a working board gives one long and two short beeps, because the POST cannot find the monochrome adapter the switches ask for.[7] P8 and P9 can be forced on the wrong way round, so check them.[7]
If there are no beeps:
- If the fan does not turn, or turns only for a moment, either the supply is faulty or the board has a short that shuts it down. Switch off, unplug P8, switch on again. If the fan now runs, look for a short on the board: C56 on +12 V first, then the +5 V tantalums (see IBM PC XT Capacitor Replacement Guide).[7][8]
- If the fan keeps turning, that proves only part of the supply. Measure the rails with P8 and P9 still connected to the board.[7]
| Connector pin | Wire | Signal | Expected |
| P9 pins 4, 5, 6 | Red | +5 V | +4.8 to +5.25 V |
| P9 pin 3 | White | −5 V | −4.6 to −5.5 V |
| P8 pin 3 | Yellow | +12 V | +11.5 to +12.6 V |
| P8 pin 4 | Blue | −12 V | −10.9 to −13.2 V |
| P8 pin 1 | Orange | Power good | 2.4 to 5.2 V |
Limits from IBM's service manual p. 4-3;[2] pin functions and wire colours from minuszerodegrees.net.[7] If all four rails are in limits but power good is below 2.4 V, the supply is faulty.[7]
IBM's dead machine checks add: disconnect all external cables, remove the 8087 if fitted, unplug the drive power connectors one at a time (a failing drive logic board can load the supply down), check the supply voltages at the board, and check the board's resistance.[2]
With the supply and voltages good and still no beeps, the clock and reset can be checked at any expansion slot. CLK on pin B20 is 4.77 MHz with a 33 % duty cycle; OSC on B30 is 14.31818 MHz with a 50 % duty cycle; RESET DRV on B2 is active high, so it should be high at power-on and low once the board is running. B1, B10 and B31 are ground.[4] minuszerodegrees.net also suggests a diagnostic ROM in socket U18 in place of the BIOS, preferring Ruud's diagnostic ROM to the Supersoft/Landmark ROM on the 5160.[1]
POST beeps and messages
| Beeps or message | Meaning and likely causes |
| Nothing: no display, no beep, no diskette access after two minutes | Many causes. Rule out an 11/08/82 BIOS with a CGA card and SW1 set for MDA, then use the minimum diagnostic configuration. |
| Flashing cursor only, no beeps | With the 11/08/82 BIOS, an MDA card with SW1 set for CGA. Also seen with a badly seated MDA card. |
| Flashing cursor, no RAM count, then an attempt to boot from A: | An MDA card with SW1 set for EGA; with the 05/09/86 BIOS, also a CGA card with SW1 set for EGA. |
| 1 short beep | POST passed. |
| 2 short beeps | Accompanies an on-screen xx01 error and "ERROR. (RESUME = F1 KEY)". |
| 1 long + 2 short | SW1 set for MDA or CGA and the card is missing or faulty; or a board fault makes the POST think an MDA or CGA is fitted when SW1 is set for EGA/VGA; or a video card's own ROM found a fault. |
| 1 long + 3 short | The ROM on an IBM EGA card found a fault in the card. |
| Continuous tone | Not produced by the POST. Faulty system board, a card interfering with the board, or a faulty supply; power good being present does not prove the supply. |
| 101 | 8259 interrupt controller, 8253 timer or 8237 DMA controller, or their support logic. |
| 201, e.g. "30000 10 201" | RAM. See Memory errors. |
| 301 or "xx 301" | Keyboard. A preceding byte identifies a stuck key. Otherwise: no keyboard, an AT keyboard, a broken cable conductor, a bad joint on the DIN socket, or the board's keyboard circuit. |
| 601 | Diskette subsystem. See Diskette faults. |
| 1701 | Produced by the fixed disk controller's own ROM, not the system board. Covers controller, cables, drive, configuration and power. |
| 1801 | The POST found a 5161 extender card and could not talk to the expansion unit: cable, power, receiver card, extender card, or the 5161 not switched on first. An accelerator card in slot 8 can also cause it. |
| C8000 ROM, CA000 ROM, D0000 ROM | An adapter's ROM at that address is faulty, corrupt or badly seated. C8000 is usually a fixed disk controller; CA000 is often a third-party floppy controller. |
| F6000 ROM | 08/16/82 and 11/08/82 BIOS only: U19 missing, faulty or badly seated. The machine still boots; only Cassette BASIC is lost. |
| F8000, FA000 or FC000 ROM | 1982 BIOS only: part of U18 is corrupt or badly seated. |
| PARITY CHECK 1 | Parity error in system board RAM: a chip, a badly seated chip, refresh or parity logic, or a filter capacitor near the RAM. |
| PARITY CHECK 2 | Parity error in RAM on an expansion card. |
| PARITY CHECK with no number | Not produced by the IBM BIOS; the Parity_Boot virus shows it. |
Source: minuszerodegrees.net.[1] On the 1986 BIOS, the POST checks U18 and U19 first and halts the processor without any message or beep if either is bad.[1]
Memory errors
The number before "201" locates the failing chip. IBM's service manual gives the decoding for each board:[2]
- On the 64/256 KB board (5160, 5155 and XT/370) the code has four characters. The first character, 0 to 3, is the bank on the system board; the last two give the failing bit (00 is the parity chip, then 01, 02, 04, 08, 10, 20, 40, 80 for bits 0 to 7). IBM's example, 3040 201, is bank 3, bit 6.
- On the 256/640 KB board the code has seven characters. The first character is the bank; the sixth and seventh give the bit. IBM's example, 3C000 40 201, is bank 3, bit 6.
IBM treats a first character of 0 to 3 as a system board failure. IBM also warns that a chip fitted the wrong way round can give a memory error, a lock-up or a blank screen.[2]
The 5160's POST sizes memory by writing to the start of each 64 KB block and stops at the first block that does not read back. A failed data chip therefore often shows as less memory counted, with no 201: minuszerodegrees.net pulled a chip from bank 3 of a 256 KB board and the machine counted 192 KB.[9] A failed chip in bank 0 leaves the board apparently dead.[9]
On a 256/640 KB board that counts only 256 KB, check jumper E-2; it must be fitted for 256 KB chips in banks 0 and 1.[2]
IBM's method for a memory fault the diagnostics do not catch: reduce the memory one bank at a time with the switches until the error stops. The last bank removed is the failing one; then restore the switches and swap chips in that bank until the error goes.[2]
Power supply faults
- The supply shuts all outputs down on a DC overcurrent or overvoltage and stays down while the fault is there. The fan may still turn.[4][3]
- It also shuts down if underloaded. A working system board alone is usually enough load.[3] To measure a supply on its own, IBM loads P9 pins 1 and 6 with 1.5 ohm, 25 W.[2]
- Turning off the red switch does not remove mains voltage from everything inside the supply.[10]
- Limits and sense levels are in the maintenance guide.
Fixed disk faults
- For a 1701 error, reseat the 34-pin control and 20-pin data cables at both ends and the adapter in its slot, check +12 V at the drive (IBM's limits at the drive power connector are +11.5 to +12.6 V, and +4.8 to +5.2 V on +5 V), and check that the drive type is one the controller supports.[1][2][11]
- The 10 MB cable (P/N 8529271) plugs into the adapter with the trace wires facing up, away from the system board; the 20 MB cable (P/N 6480086) with the trace wire facing down.[2]
- The 10/20 MB adapter has a drive-type switch block for drives C and D; IBM's settings for types 1, 2, 13 and 16 are on p. 6-4 of the service manual. Type 1 is the IBM 10 MB drive.[5]
- IBM treats a 10 MB drive as good if CHKDSK's total disk space less bytes in bad sectors is at least 10,240,000 bytes, and a 20 MB drive at 20,480,000 bytes.[2]
- A replacement fixed disk or diskette drive needs the terminating resistor if the drive it replaces had one; the last drive on each cable must be terminated.[2]
Diskette faults
Causes of 601 listed by minuszerodegrees.net include a faulty or badly seated adapter, a dirty slot, SW1 7 and 8 set for more drives than are fitted (1986 BIOS), the wrong cable or a cable fitted wrongly, a missing or faulty drive, the drive select jumper, and termination.[1]
- Check the signal cable for shorts between adjacent pins with the meter on ohms ×1K; IBM expects infinity.[2]
- On IBM Type 2 drives whose file control card is stamped 010 on its left edge, read/write errors are fixed by removing capacitor C39.[2]
- Do not clean the heads by hand; Tandon's manual forbids it.[12] Belt, speed and rail lubrication on the Tandon drives are in the maintenance guide.
Keyboard faults
For a 301 error, IBM's checks at the keyboard connector on the system board are:[2]
| Pin | Signal | Level |
| 1 | Keyboard clock | +5 V |
| 2 | Keyboard data | +5 V |
| 3 | Keyboard reset (not used by the keyboard) | |
| 4 | Ground | 0 V |
| 5 | +5 V | +5 V |
The XT needs a PC/XT-protocol keyboard; an AT-only keyboard gives 301.[1] The keyboard interface is discrete logic on the board, with no controller chip.[3]
Expansion card faults
- A card in slot 8 must return the card-selected signal. IBM's Asynchronous Communications Adapter does so with jumper J13 fitted; a card that does not will not be recognised there.[2] An accelerator card in slot 8 can cause 1801.[9]
- The async adapter (P/N 8529150) must be set for RS-232C, not current loop, when the diagnostics are run, or they report 1101 errors.[2]
- IBM notes that diagnostics do not necessarily fail with two cards on one interrupt level even though the operator keeps getting errors; list the cards by level and remove one of any pair that share a level.[2]
- IBM reserved C0000 to C7FFF for video ROMs, and XT fixed disk controllers usually put their ROM at C8000. Microsoft's article Q63588 says a few VGA ROMs extend past C8000.[9]
- Some 16-bit cards sold as working in an 8-bit slot mean an 8-bit slot in an AT, or need reconfiguring for 8-bit use.[9]
- For communications faults on a machine with a Display Station Emulation Adapter, IBM checks the DMA chip at U28. If it is an AMD 8237 or 9517, a 74LS32 must be fitted at U90 or the spare position; boards without it are to be replaced (ECA005).[2]
Known problems
- If the POST keeps restarting with no error, SW1 switch 1 is on.[9][5]
- With the 01/10/86 and 05/09/86 BIOS, some third-party floppy controllers read 1.44 MB diskettes but cannot boot from them.[13]
- IBM does not support the 5161 Expansion Unit on models 088, 089, 267, 268, 277 and 278.[14]
- Early boards are wired for Mostek MK38000-series mask ROMs in U18 and U19. A 27256 or 27C256 EPROM usually works there, but not always.[9]
- Replacing the 8088 with a V20 sometimes causes problems.[9]
- A POST card shows nothing useful on a 5160.[3]
- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 IBM 5160 – POST – Some errors (on-screen, or otherwise), minuszerodegrees.net. Meanings and causes of the POST beeps and messages, the continuous tone, 1701, 1801, the ROM messages and PARITY CHECK 1 and 2, the SW1 video-setting symptoms, and the note that the 1986 BIOS halts without any output if U18 or U19 fails its early check.
- ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 2.10 2.11 2.12 2.13 2.14 2.15 2.16 2.17 2.18 2.19 IBM, Personal Computer Family Service Information Manual, SA38-0037-00, First Edition, January 1989, hosted as File:IBM Personal Computer Family Service Information Manual SA38-0037-00.pdf. Chapter 4, "5150/5160-Based System Diagnostics": POST sequence and timing, dead machine tips and connector voltage limits (p. 4-3); dummy load (p. 4-4); memory error-code decoding (pp. 4-5 to 4-7); E-2 jumper, mislabelled boards and interrupt conflicts (p. 4-7); keyboard connector voltages (p. 4-8); Type 2 diskette drive C39 and terminators (p. 4-9); drive signal cable and power checks (p. 4-11); CHKDSK capacity check (p. 4-12); fixed disk cable orientation, slot 8 and 1101 errors (p. 4-13); DSEA and down-level system boards, ECA005 (p. 4-14).
- ↑ 3.0 3.1 3.2 3.3 3.4 3.5 IBM 5160 – Basics, for 5160 beginners, minuszerodegrees.net.
- ↑ 4.0 4.1 4.2 IBM, Personal Computer XT and Portable Personal Computer Technical Reference, part 6280089, March 1986, hosted as File:IBM PC XT 5155 5160 Technical Reference Mar86.pdf. I/O channel pin assignments (p. 1-17) and signal descriptions for CLK, OSC and RESET DRV (pp. 1-21 to 1-23); SW1 bit map (p. 1-27); power supply outputs, sense levels and power good (pp. 3-3 to 3-5).
- ↑ 5.0 5.1 5.2 IBM, Personal Computer Family Service Information Manual, SA38-0037-00 (1989), chapter 6, "5160 PC XT", p. 6-3 (SW1 functions and math coprocessor setting) and p. 6-4 (display, diskette and fixed disk adapter switch settings).
- ↑ IBM 5160 – Motherboard Switch/Jumper Settings, minuszerodegrees.net. On/off combinations for each SW1 setting.
- ↑ 7.0 7.1 7.2 7.3 7.4 7.5 IBM 5150/5155/5160 – Minimum Diagnostic Configuration, minuszerodegrees.net, and the pages it leads to: no beeps, fan not turning and fan turning.
- ↑ Short-circuit on the +12 volt line of an IBM 5150/5155/5160 motherboard, minuszerodegrees.net.
- ↑ 9.0 9.1 9.2 9.3 9.4 9.5 9.6 9.7 IBM 5160 – Known Problems/Issues, minuszerodegrees.net. The RAM sizing flaw, shorted tantalums, bank 0 failure, looping POST, slot 8, 16-bit ISA cards, the C8000 ROM conflict, MK38000 ROM sockets, the V20, and the 1986 BIOS notes.
- ↑ IBM 5160 – Power Supply Unit, minuszerodegrees.net.
- ↑ IBM Fixed Disk Adapter, minuszerodegrees.net. Controller versions and the drive geometries each supports.
- ↑ Tandon, TM100-1 / TM100-2 48 TPI Operating and Service Manuals (1983), p. 6-1, hosted as File:Tandon TM100-1 TM100-2 48TPI Operating and Service Manuals 1983.pdf.
- ↑ IBM 5160 – BIOS Revisions, minuszerodegrees.net.
- ↑ IBM, Personal Computer Family Service Information Manual, SA38-0037-00 (1989), chapter 7, p. 7-1.
- IBM PC XT (5160)
- IBM PC XT Maintenance Guide
- IBM PC XT Capacitor Replacement Guide
- IBM PC (5150) Troubleshooting Guide
- IBM Fixed Disk Adapter
- Floppy Drive Repair
