Macintosh 128K/512K Capacitor Replacement Guide
Replacing electrolytic capacitors (recapping) in your Macintosh 128K and 512K is essential for long-term reliability. Over time, capacitors degrade, leading to voltage instability, display artifacts, and system failure. Proactively replacing these components ensures continued functionality and prevents potential board damage.
Capacitor Inspection
Before replacing capacitors, carefully inspect them for deterioration. Common failure symptoms include:
- Bulging Tops – A properly functioning capacitor has a flat top. Swelling or doming indicates failure.
- Leaking Electrolyte – Brown or white crust around capacitor leads signals internal leakage.
- Corrosion – PCB staining or green residue near the base of a capacitor suggests corrosion.
If any of these symptoms are present, replacement is highly recommended.
Macintosh 128K/512K Capacitor List
The Macintosh 128K and 512K analog board and logic board contain electrolytic capacitors that should be replaced proactively. Below are verified capacitor specifications for both boards.
Analog Board Capacitors
| C1 | 3.9µF | 35V | 1x |
| C2 | 4700µF | 16V | 1x |
| C3 | 220µF | 16V | 2x |
| C5 | 47µF | 10V | 1x |
| C6 | 22µF | 50V | 2x |
| C10 | 33µF | 16V | 2x |
| C11 | 10µF | 160V | 1x |
| C12 | 22µF | 50V | 2x |
| C18 | 33µF | 16V | 2x |
| C24 | 2200µF | 16V | 4x |
| C27 | 2200µF | 16V | 1x |
| C28 | 1000µF | 16V | 1x |
| C30 | 2200µF | 16V | 1x |
| C31 | 220µF | 16V | 1x |
| C32 | 2200µF | 16V | 1x |
| C33 | 4700pF | 250V | 2x |
| C34 | 100µF | 200V | 4x |
| C35 | 100µF | 200V | 1x |
| C36 | 4700pF | 250V | 1x |
| C37 | 0.47µF | 250V | 1x |
| C38 | 100µF | 200V | 1x |
| C39 | 100µF | 200V | 1x |
| C42 | 470µF | 10V | 2x |
| C45 | 470µF | 10V | 1x |
Logic Board Capacitors
| C1 | 1µF | 50V | 1x |
| C7 | 1µF | 50V | 1x |
| C9 | 1µF | 50V | 1x |
| C15 | 47µF | 16V | 1x |
| C21 | 1µF | 50V | 1x |
| C24 | 220µF | 10V | 1x |
| C27 | 1µF | 50V | 1x |
| C31 | 1µF | 50V | 1x |
| C32 | 1µF | 50V | 1x |
| C33 | 1µF | 50V | 1x |
| C34 | 1µF | 50V | 1x |
> Note: Capacitor numbering may vary slightly between early 128K and 512K revisions. Always verify location and values against your specific board version before ordering replacements.
Proper capacitor replacement requires care and the right tools. Follow these steps:
- Discharge CRT – Fully discharge the CRT before opening the system to avoid electric shock.
- Disassembly – Carefully remove the analog board and/or logic board, noting cable connections.
- Desoldering – Use a solder pump or wick to remove capacitors without lifting traces.
- Install Replacements – Insert new capacitors with correct polarity (+ and – markings).
- Soldering – Apply clean, shiny joints and trim excess leads.
- Final Inspection – Confirm all joints are clean and test for shorts using a multimeter.
Recommended Tools
- Desoldering braid or solder sucker
- Multimeter (continuity and voltage testing)
- Isopropyl alcohol and ESD brush (for board cleaning)
- Safety glasses and insulated gloves
Voltage Adjustment Post-Recap
After recapping, test voltages at the floppy or logic board connector using a multimeter:
- +5V Rail: 4.85V – 5.15V
- +12V Rail: 11.9V – 12.7V
Adjust if necessary using the analog board’s trimmer potentiometer (R56).
Additional Tips
- Power up the Macintosh periodically to preserve capacitor function.
- Always use high-quality capacitors from trusted brands.
- If full recapping isn't feasible, replace in matching sets or sections.
- Recycle old capacitors at an electronics waste facility.
