Macintosh SE/30 Capacitor Replacement Guide
Replacing electrolytic capacitors (recapping) in your Macintosh SE/30 is essential for restoring power stability, ensuring clean video output, and preventing long-term damage due to capacitor leakage. This guide outlines the recommended procedure and provides complete analog and logic board capacitor specifications.
๐ Capacitor Inspection
- Bulging Tops โ Swollen or domed caps indicate internal gas buildup.
- Electrolyte Leakage โ Brown/white crust or residue near leads shows capacitor failure.
- Corroded Pads or Traces โ PCB staining or corrosion suggests leakage damage.
๐ Macintosh SE/30 Capacitor List
๐งฏ Analog Board Capacitors
The SE/30 analog board is nearly identical to that of the Macintosh SE and Plus, and shares the same capacitor layout:
| C1 | 3.9ยตF | 35V | 1x |
| C2 | 4700ยตF | 16V | 1x |
| C3 | 220ยตF | 16V | 2x |
| C5 | 47ยตF | 10V | 1x |
| C6 | 22ยตF | 50V | 2x |
| C10 | 33ยตF | 16V | 2x |
| C11 | 10ยตF | 160V | 1x |
| C12 | 22ยตF | 50V | 2x |
| C18 | 33ยตF | 16V | 2x |
| C24 | 2200ยตF | 16V | 4x |
| C27 | 2200ยตF | 16V | 1x |
| C28 | 1000ยตF | 16V | 1x |
| C30 | 2200ยตF | 16V | 1x |
| C31 | 220ยตF | 16V | 1x |
| C32 | 2200ยตF | 16V | 1x |
| C33 | 4700pF | 250V | 2x |
| C34 | 100ยตF | 200V | 4x |
| C35 | 100ยตF | 200V | 1x |
| C36 | 4700pF | 250V | 1x |
| C37 | 0.47ยตF | 250V | 1x |
| C38 | 100ยตF | 200V | 1x |
| C39 | 100ยตF | 200V | 1x |
| C42 | 470ยตF | 10V | 2x |
| C45 | 470ยตF | 10V | 1x |
๐ง Logic Board Capacitors
The SE/30 logic board is particularly prone to capacitor failure and corrosion, making recapping especially important.
| C1 โ C10 | 47ยตF | 16V | 10x |
| C11 | 1ยตF | 50V | 1x |
๐ ๏ธ Capacitor Replacement Procedure
- Discharge the CRT โ Follow standard CRT discharge procedures before working inside.
- Remove the Logic & Analog Boards โ Label cables and safely extract both boards.
- Desolder Old Capacitors โ Use a quality soldering iron, braid, or pump to remove components cleanly.
- Install New Capacitors โ Insert with correct polarity (check for stripe on negative side).
- Solder Carefully โ Ensure clean, shiny joints without cold solder bridges.
- Trim Leads & Inspect Work โ Cut excess and examine under light or magnification.
- Test for Shorts โ Use a multimeter to confirm there are no shorts across power rails.
๐งฐ Recommended Tools
- Desoldering braid or vacuum pump
- Quality leaded solder (0.5 mm recommended)
- Isopropyl alcohol and ESD brush
- Multimeter
- Safety goggles and insulated gloves
โ๏ธ Voltage Adjustment After Recap
- +5V rail: 4.85V โ 5.15V
- +12V rail: 11.9V โ 12.7V
Use the analog board's trimmer potentiometer (R56) to fine-tune if necessary.
๐ก Tips for Best Results
- Always recap the logic board first โ leaking caps often cause corrosion damage.
- Use quality capacitors (e.g., Nichicon, Panasonic, Rubycon).
- Turn on the system periodically to prolong capacitor lifespan.
- Replace in full sets for even aging and reliability.
- Clean the board thoroughly with isopropyl alcohol after removal.
