Macintosh SE/30 Capacitor Replacement Guide
Revision as of 08:57, 12 May 2025 by Josh (talk | contribs)
Replacing electrolytic capacitors (recapping) in your Macintosh SE/30 is essential for restoring power stability, ensuring clean video output, and preventing long-term damage due to capacitor leakage. This guide outlines the recommended procedure and provides complete analog and logic board capacitor specifications.
Capacitor Inspection
  • Bulging Tops – Swollen or domed caps indicate internal gas buildup.
  • Electrolyte Leakage – Brown/white crust or residue near leads shows capacitor failure.
  • Corroded Pads or Traces – PCB staining or corrosion suggests leakage damage.
Macintosh SE/30 Capacitor List
Analog Board Capacitors
The SE/30 analog board is nearly identical to that of the Macintosh SE and Plus, and shares the same capacitor layout:
SE/30 Analog Board Capacitor Specifications
C1 3.9µF 35V 1x
C2 4700µF 16V 1x
C3 220µF 16V 2x
C5 47µF 10V 1x
C6 22µF 50V 2x
C10 33µF 16V 2x
C11 10µF 160V 1x
C12 22µF 50V 2x
C18 33µF 16V 2x
C24 2200µF 16V 4x
C27 2200µF 16V 1x
C28 1000µF 16V 1x
C30 2200µF 16V 1x
C31 220µF 16V 1x
C32 2200µF 16V 1x
C33 4700pF 250V 2x
C34 100µF 200V 4x
C35 100µF 200V 1x
C36 4700pF 250V 1x
C37 0.47µF 250V 1x
C38 100µF 200V 1x
C39 100µF 200V 1x
C42 470µF 10V 2x
C45 470µF 10V 1x
Logic Board Capacitors
The SE/30 logic board is particularly prone to capacitor failure and corrosion, making recapping especially important.
SE/30 Logic Board Capacitor Specifications
C1 – C10 47µF 16V 10x
C11 1µF 50V 1x
Macintosh SE/30 Logic Board Capacitor Locations
  1. Discharge the CRT – Follow standard CRT discharge procedures before working inside.
  2. Remove the Logic & Analog Boards – Label cables and safely extract both boards.
  3. Desolder Old Capacitors – Use a quality soldering iron, braid, or pump to remove components cleanly.
  4. Install New Capacitors – Insert with correct polarity (check for stripe on negative side).
  5. Solder Carefully – Ensure clean, shiny joints without cold solder bridges.
  6. Trim Leads & Inspect Work – Cut excess and examine under light or magnification.
  7. Test for Shorts – Use a multimeter to confirm there are no shorts across power rails.
  • Temperature-controlled soldering iron (fine tip)
  • Desoldering braid or vacuum pump
  • Quality leaded solder (0.5 mm recommended)
  • Isopropyl alcohol and ESD brush
  • Multimeter
  • Safety goggles and insulated gloves
Voltage Adjustment After Recap
  • +5V rail: 4.85V – 5.15V
  • +12V rail: 11.9V – 12.7V
Use the analog board's trimmer potentiometer (R56) to fine-tune if necessary.
Tips for Best Results
  • Always recap the logic board first – leaking caps often cause corrosion damage.
  • Use quality capacitors (e.g., Nichicon, Panasonic, Rubycon).
  • Turn on the system periodically to prolong capacitor lifespan.
  • Replace in full sets for even aging and reliability.
  • Clean the board thoroughly with isopropyl alcohol after removal.
