The Sinclair ZX80 is a classic home computer, and with careful maintenance, it can remain reliable for decades. This guide covers essential care, preventive steps, and troubleshooting for all ZX80 board revisions.
Always observe ESD (Electrostatic Discharge) precautions when handling the PCB or components—use a grounded wrist strap and work on an antistatic mat.
Regular maintenance intervals:
Visual inspection: Every 12 months
Capacitor check: Every 2–3 years
Full electrical test: Every 5 years or after storage
Sinclair ZX80 Mainboard (Issue 2)
🧾 Board Revisions
Revision
PCB Markings
Notable Differences
Common Issues
Issue 1
"ZX80 ISSUE ONE" silk
Early production, hand-wired mods
Poor video sync, regulator overheating
Issue 2
"ZX80 ISSUE TWO" silk
Improved video, revised regulator layout
Keyboard connector wear, RAM instability
🔌 Power Supply & Regulator Care
The ZX80 uses a simple linear power supply:
PSU Part: Sinclair 9V DC Adapter (center negative)
Specs: 9V DC, 700–1000mA, 2.1mm barrel
On-board Regulator: 7805 (IC3) 5V linear
Common Failure Modes:
PSU cable splits or shorts
7805 overheating or output drift
Capacitor (C4, C5) leakage or bulging
On-board Capacitor Designators:
C4, C5: Smoothing and decoupling for 7805
C1, C2, C3: Logic supply filtering
🔋 Capacitor Replacement Table
Position
Value
Voltage
Notes
Series/Type
C1
22μF
16V
Logic rail smoothing
Axial, low ESR
C2
1μF
16V
Video circuit
Tantalum or electrolytic
C3
0.1μF
50V
Noise bypass
Ceramic disc
C4
100μF
16V
7805 input
Axial, low ESR
C5
100μF
16V
7805 output
Axial, low ESR
⚡ Voltage & Clock Test Points
Test Point
IC/Pin
Expected Value (±Tolerance)
5V Rail
IC3 (7805) Output
5.00V ±0.15V
9V Input
C4 (+)
9.0V ±0.5V
CPU Clock
IC1 (Z80) Pin 6
3.25MHz ±0.05MHz
Video Sync
IC5 Pin 3
5Vpp square wave
Antistatic wrist strap & mat
Multimeter (with continuity and voltage)
Oscilloscope (≥10MHz, for clock/video)
Soldering iron (fine tip, ESD safe)
Solder sucker or wick
Small flat and Phillips screwdrivers
IC extractor
Fine tweezers
Isopropyl alcohol & brush (for cleaning)
🧹 Preventive Maintenance Checklist
Power off and unplug the unit.
Discharge static and open the case.
Inspect PCB for corrosion, broken traces, or burnt components.
Check all capacitors for bulging or leakage.
Verify keyboard membrane and connector for cracks.
Clean dust and debris with a soft brush.
Test PSU output voltage before connecting.
Reseat all socketed ICs gently.
Inspect solder joints for cracks ("dry joints").
Reassemble and test operation.
🛑 Common Faults & Quick Checks
Symptom
Likely Cause
Quick Check
No power
PSU or 7805 failure
Measure 9V in, 5V out at IC3
No video
C2, IC5, or ULA fault
Scope video out, check C2
Keyboard dead
Membrane or connector
Inspect for cracks, reseat
Random resets
C1, C4, or RAM
Replace caps, test RAM
Overheating
7805 or shorted cap
Check C4/C5, IC3 temp
🔄 Troubleshooting Flowcharts
No Power
→ Check PSU output (9V)
→ Check 7805 output (5V)
→ If 5V missing, replace 7805 and C4/C5
→ If still dead, inspect PCB for shorts
No Video Output
→ Confirm 5V present
→ Test C2 and IC5 (video circuit)
→ Swap ULA if available
→ Inspect video connector and cable
Keyboard Not Responding
→ Inspect membrane for cracks
→ Clean and reseat connector
→ Test continuity across matrix
Random Freezing/Resets
→ Replace C1, C4, C5
→ Test RAM ICs
→ Check for dry joints on IC sockets
