Macintosh Centris 610 Capacitor Replacement Guide
Revision as of 11:31, 10 February 2026 by Josh (talk | contribs) (Add recap guide and logic board images from Recap-a-Mac)
Replacing electrolytic capacitors (recapping) in your Macintosh Centris 610 (or Macintosh Quadra 610) is essential for long-term reliability. The original surface-mount capacitors leak electrolyte over time, causing corrosion and potential component damage.
Note: The Centris 610 and Quadra 610 share the same logic board. This guide applies to both models.
Centris/Quadra 610 logic board with capacitors visible
Why Recap?
The Centris/Quadra 610 logic board uses surface-mount electrolytic capacitors manufactured in the early 1990s. These capacitors:
  • Leak electrolyte as they age
  • Cause corrosion on PCB traces
  • Lead to intermittent failures and crashes
  • Can damage nearby components if left unchecked
Capacitor Inspection
Before recapping, inspect the logic board for signs of failure:
  • Bulging Tops – The top of the capacitor is domed instead of flat
  • Leaking Electrolyte – Brown or amber residue around the capacitor base
  • Corrosion or PCB Staining – Discoloration on the board near capacitors
  • Crystalline Deposits – White or tan crystalline buildup
Macintosh Centris 610 Capacitor List
Logic Board Capacitors
Capacitor locations on the Centris/Quadra 610 logic board (source: Recap-a-Mac)
Logic Board Capacitor Specifications
Designation Capacitance Voltage Type Quantity
All positions 47µF 16V SMD Electrolytic 10×
All 10 capacitors on the Centris/Quadra 610 logic board are the same value: 47µF 16V surface-mount electrolytics.[1]
Replacement Options
Electrolytic (traditional):
  • Nichicon, Rubycon, or Panasonic SMD electrolytics
  • 47µF 16V or higher voltage rating
  • Match original footprint (6.3mm diameter typical)
Tantalum (longer life):
  • KEMET T491 series: T491D476K016AT (47µF 16V)
  • More reliable, lower ESR
  • Observe correct polarity (tantalums fail short if reversed)
Power Supply Capacitors
The Centris 610 uses the ASTEC AA16990 power supply (Apple part 614-0022). The PSU also contains electrolytic capacitors that may need replacement. Consult the power supply service guide for cap values and locations.
⚠️ Warning: Power supplies contain high voltages. Discharge all capacitors before servicing.
  1. Prepare the workspace – Use an ESD mat and wrist strap
  2. Remove the logic board – Disconnect all cables, remove screws, slide board out
  3. Document capacitor positions – Note polarity markings (stripe = negative)
  4. Remove old capacitors – Use hot air or low-temp solder paste to desolder
  5. Clean pads – Remove old solder with wick, clean with isopropyl alcohol
  6. Inspect for damage – Check traces for corrosion; repair if necessary
  7. Install new capacitors – Observe correct polarity; stripe = negative
  8. Solder carefully – Use appropriate temperature for SMD work
  9. Clean residue – Remove flux with isopropyl alcohol
  10. Inspect solder joints – Check for bridges or cold joints
  11. Reinstall and test – Power on and verify operation
  • Temperature-controlled soldering iron (fine tip)
  • Hot air rework station (optional but helpful for SMD)
  • Solder wick or desoldering pump
  • Fine leaded solder (0.5mm or 0.3mm)
  • Flux (no-clean or water-soluble)
  • Isopropyl alcohol (90% or higher)
  • ESD brush for cleaning
  • Multimeter
  • Magnification (loupe or microscope)
  • ESD mat and wrist strap
Post-Recap Testing
After recapping:
  • Visual inspection of all solder joints
  • Continuity test on replaced capacitors
  • Power-on test (listen for startup chime)
  • Extended run test (several hours)
  • Check voltages if experiencing issues
Additional Tips
  • Work in a well-lit, clean environment
  • Take photos before removing capacitors
  • If traces are damaged, repair with wire or conductive ink before recapping
  • Consider replacing the PRAM battery at the same time
  • Clean the entire logic board with isopropyl alcohol after recapping
  • Store removed capacitors for reference if needed
  1. Quadra 610 Cap Reference, MacDat—link(accessed 2026-02-10)
