Macintosh Performa 5260CD
Revision as of 12:25, 10 February 2026 by Josh (talk | contribs) (Fix missing image: replace Performa5260.jpg with Macintosh_Performa_5200.jpg)
ReleasedApril 22, 1996
DiscontinuedFebruary 1, 1997
Intro priceUS$1,900
CPUPowerPC 603e @ 100 MHz
Memory8 MB or 16 MB RAM (expandable to 64 MB)
Storage800 MB or 1.2 GB IDE hard drive, 4X CD-ROM
Display14" Shadow Mask CRT (640×480 at 16-bit color)
Sound16-bit mono sound input
Dimensions17.5" H × 15.1" W × 16.0" D (44.5 × 38.4 × 40.6 cm)
Weight45 lbs (20.4 kg)
OS / FirmwareSystem 7.5.3 – Mac OS 9.1
PredecessorPerforma 5200CD
SuccessorPerforma 5400CD
Model no.M3457
The Macintosh Performa 5260CD is an all-in-one personal computer manufactured by Apple Computer, Inc., introduced on April 22, 1996.[1] It features a 100 MHz PowerPC 603e processor in the same all-in-one chassis as its predecessor, the Performa 5200CD.
The Performa 5260 series replaced the PowerPC 603 CPU with the improved 603e. The system shares its logic board and form factor with the education-market Power Macintosh 5260/100 and various regional variants sold under different model numbers.[2]
Model Variants
The Performa 5260 family includes several regional and speed variants:
Performa 5260/5280 Series Variants
Model CPU Speed Hard Drive CD-ROM Introduction Region
Performa 5260CD 100 MHz 800 MB or 1.2 GB 4X April 22, 1996 Worldwide
Performa 5270CD 100 MHz 1.2 GB 4X April 22, 1996 Asia, Europe
Performa 5280 120 MHz 1.2 GB 8X November 12, 1996 Japan
The Performa 5270CD is identical to the 5260CD with a different model designation for Asian and European markets. The Performa 5280 is a later variant with a faster 120 MHz CPU and 8X CD-ROM drive, sold exclusively in Japan.
The Performa 5260CD uses the PowerPC 603e processor running at 100 MHz with a 40 MHz system bus.[3] The 603e is a 32-bit processor with a 64-bit data path and includes an integrated floating-point unit.
Cache Configuration
  • L1 Cache: 32 KB (16 KB instruction + 16 KB data)
  • L2 Cache: 256 KB (optional expansion slot)
ROM
The system includes 4 MB of ROM in a "New World" ROM-in-RAM configuration.
Memory and Storage
RAM Configuration
Specification Details
RAM Type 72-pin SIMM
Minimum Speed 80 ns
Standard RAM 8 MB or 16 MB
Maximum RAM 64 MB
RAM Slots 2
RAM cannot be interleaved on this system. 1 MB of system RAM is permanently dedicated to video function.
Storage Systems
  • Hard Drive: 800 MB or 1.2 GB IDE internal drive
  • Floppy Drive: 1.44 MB 3.5" manual-inject
  • CD-ROM: 4X (5260CD/5270CD) or 8X (5280)
The system uses an IDE interface for the hard drive; internal SCSI hard drives are not supported.
Display and Graphics
The Performa 5260CD features a built-in 14" Shadow Mask RGB CRT display running at 640×480 resolution with 16-bit color (thousands of colors). Video memory consists of 1 MB dedicated from system RAM and cannot be expanded.[4]
An external display can be connected via an optional LC PDS video card.
Audio Capabilities
The system provides 16-bit mono sound input through the rear audio input jack. Standard Macintosh sound output is provided through built-in speakers and a rear audio output jack.
Input/Output and Expansion
Port Configuration
Port Type Quantity Notes
ADB 1 Apple Desktop Bus for keyboard and mouse
Serial 2 Printer and modem ports (no hardware handshaking)
Audio In 1 16-bit mono
Audio Out 1 Stereo
SCSI 1 External DB-25 SCSI port
Video Out 1 Optional DB-15 (via expansion)
The serial ports do not support hardware handshaking, limiting external modem speeds to 9600 bps.
Expansion Slots
  • LC PDS: 1 slot for Processor Direct Slot cards
  • Comm Slot: 1 slot for communication cards
  • Video I/O Slot: 1 slot for video input/output cards
  • TV Tuner Slot: 1 slot for optional TV tuner
For detailed maintenance practices including cleaning, PRAM battery management, connector corrosion prevention, and voltage adjustments, refer to the dedicated Macintosh Performa 5260CD General Maintenance page.
The Performa 5260 shares its logic board with the Power Macintosh 5260 series.
Apple Service Manual
The official Apple Service Source documentation covers both the Power Macintosh 5260 and Performa 5260/5280 series.
Detailed capacitor replacement guidelines for the logic board can be found on the Macintosh Performa 5260CD Capacitor Replacement Guide page.
Retrobrite
A comprehensive troubleshooting guide addressing no power, chime but no video, intermittent operation, Sad Mac errors, and floppy drive problems is available on the Macintosh Performa 5260CD Troubleshooting page.
Sub-system Specification (Performa 5260CD, April 1996)
CPU PowerPC 603e @ 100 MHz
Bus width 32-bit data • 64-bit data path
System Bus 40 MHz
ROM 4 MB
RAM 8-64 MB (72-pin SIMM)
Video 640 × 480 @ 16-bit color
VRAM 1 MB (from system RAM)
Sound 16-bit mono input, stereo output
Disks 1.44 MB floppy, 800 MB-1.2 GB HDD, 4X CD-ROM
Ports ADB, SCSI, Serial × 2, Audio I/O
Power Specifications
Specification Value
Input Voltage 110V-240V AC
Frequency 50-60 Hz
Maximum Wattage 125 W
  1. Apple Macintosh Performa 5260CD Specs, EveryMac.com—link(accessed 2026-02-10)
  2. Power Macintosh 5260, Wikipedia—link(accessed 2026-02-10)
  3. Macintosh Performa 5260CD: Technical Specifications, Apple Inc.—link(accessed 2026-02-10)
  4. Apple Macintosh Performa 5260CD Specs, EveryMac.com—link(accessed 2026-02-10)
