Sinclair ZX81
Revision as of 10:31, 12 May 2025 by Josh (talk | contribs)
Sinclair ZX81
Sinclair ZX81 – The Affordable Home Computer
ManufacturerSinclair Research Ltd
TypeHome computer
ReleasedMarch 1981
Discontinued1984
Intro price£69.95 kit / £89.95 ready-built (≈US$199/249 in 1981)
CPUZilog Z80A-compatible (NEC µPD780C) @ 3.25 MHz
Memory1 KB static RAM (expandable to 16 KB)
StorageExternal cassette tape (300 baud, EAR/MIC jacks)
DisplayMonochrome RF to TV – 32 × 24 text or 64 × 48 block-graphics
SoundNone (no audio hardware)
Dimensions200 mm × 150 mm × 35 mm (7.9 ″ × 5.9 ″ × 1.4 ″)
Weight≈ 400 g (0.88 lb)
OS / Firmware4 KB Sinclair BASIC in ROM
PredecessorSinclair ZX80
SuccessorSinclair ZX Spectrum
Codename“ZX81 project”
Model no.ZX81
The Sinclair ZX81 is an 8-bit home computer launched by Sinclair Research in March 1981. It was designed as an affordable entry into computing, selling over 1.5 million units worldwide. The ZX81's compact design and low price made it accessible to a broad audience, contributing to the rise of home computing in the UK.
The ZX81 was notable for its simple design and was one of the first computers to be sold for under £100. It provided a platform for programming in BASIC and was widely used in schools and homes for educational purposes.
Architecture
  • CPU – Z80A-class microprocessor clocked at 3.25 MHz.
  • ROM – 8 KB mask ROM containing Sinclair BASIC and system routines.
  • RAM – 1 KB of 2114 static RAM, expandable to 16 KB via the rear expansion bus.
  • Logic – Utilizes standard TTL logic chips, with no custom chips.
Video generation
The ZX81 generates video output using the Z80 processor, which produces a sync pulse and fetches character data from RAM. The video output is interleaved with CPU operations, which can lead to display flicker during intensive processing.
The ZX81 uses the 300 baud Kansas City Standard for loading and saving programs via cassette tape. The average time to load a program is approximately 4 seconds per kilobyte.
I/O and Expansion
  • Edge connector (40-way) – provides access to the Z80 bus, power, and video signals.
  • 9 V DC input – unregulated power supply.
  • RF modulator – outputs to channel 36 PAL TV.
Commercial accessories included:
1–16 KB RAM packs, ZX Printer, joystick interfaces, and various expansion modules.
Known PCB Revisions & Errata
ZX81 Logic-Board Issues
Issue Visible Clues Key Fixes / Changes
Issue 1 (Mar 1981) “ZX81 Issue 1” silkscreen; no solder mask. • Missing pull-up resistors on video output caused weak signals on some TVs.
• Early models had a tendency to overheat; later revisions included heatsinks.
Issue 2 (late 1982) Added solder mask; improved layout. • Enhanced power regulation for stability.
• Additional RAM compatibility improvements.
Issue Cause Remedy
Flickering display Poor power supply regulation Replace with a regulated power supply.
Unresponsive keys Wear on membrane keyboard Replace keyboard or clean contacts.
Overheating Lack of ventilation Ensure proper airflow or add ventilation holes.
Regular maintenance, including keyboard cleaning and power supply checks, is essential for longevity.
Schematic & PCB
The complete PCB schematic is available for reference.
Sinclair ZX81 circuit diagram
Original Issue 1 board – note layout changes
Common Modifications
  • 16 KB RAM upgrade – allows for more complex programs and reduces memory limitations.
  • Composite video output mod – improves video quality for modern displays.
  • Full-travel keyboard mod – replaces the membrane keyboard with a more tactile option.
ROM Keyword Map
Each key on the ZX81 keyboard has multiple functions depending on the mode selected:
Example ZX81 keyboard layer
Key F mode K mode L mode
P PRINT P (
R RETURN R )
G GOTO G >
Edge-Connector Pin-out
ZX81 40-way Expansion Bus (viewed from rear, component side up)
1 A15 Address bus MSB 21 D4 Data bit 4
2 A14 22 D5
3 A13 23 D6
4 A12 24 D7
5 A11 25 BUSACK Bus acknowledge
6 A10 26 BUSRQ Bus request
7 A9 27 WAIT Insert wait-states
8 A8 28 HALT
