IBM PC XT (5160)
Revision as of 10:26, 21 May 2026 by Josh (talk | contribs) (Rewrite with verified information only — remove fabricated part numbers (CGA 1501486, MDA 1501481, FDD Adapter 1501507, Fixed Disk Adapter 6181682, Model F dimensions/weight), remove placeholder image filenames, replace speculative capacitor designator table with verified minuszerodegrees.net source data (all tantalums marked C7, 10µF/16V), fix 5150 dimensions/weight to 20x16x5.5 inches / 21-28 lbs, fix Model F dimensions/weight to 19x9x1.5in / 7lb4oz / 3.3kg. Per Joshua's feedback: never pub...)
The IBM Personal Computer XT (model 5160, "eXtended Technology") is the second-generation IBM PC, announced March 8, 1983. It uses the same Intel 8088 at 4.77 MHz as the 5150 and is software-compatible with it, but adds three things the 5150 lacked at launch:
  • Built-in hard disk support — every XT shipped with a 10 MB MFM hard disk (later 20 MB), driven by the IBM Fixed Disk Adapter card. The standard hard drive was a Seagate ST-412 paired with a Xebec 1210 MFM controller.
  • A 130 W power supply — sufficient to run the hard disk.
  • Eight ISA slots instead of the 5150's five, on a redesigned motherboard.
IBM Personal Computer XT (5160)
ManufacturerIBM
TypeDesktop personal computer
ReleasedMarch 8, 1983
CPUIntel 8088 @ 4.77 MHz
Optional Intel 8087 FPU
Memory128 KB on-board base configuration; expandable to 640 KB
StorageOne 360 KB 5.25" floppy + one 10 MB MFM hard disk (standard); 20 MB option from later production
DisplayMDA + IBM 5151 or CGA + IBM 5153 (separate adapter card)
SoundInternal PC speaker via Intel 8253-5
OS / FirmwareIBM PC DOS 2.0 onwards; XENIX 86; CP/M-86
PredecessorIBM PC (5150)
Codename(continuation of the Acorn / Chess project)
Model no.5160
The XT motherboard also drops the cassette port, ships with a serial card (8250 UART) as standard, and uses the same 83-key Model F keyboard as the 5150.
Key Differences from the 5150
IBM 5150 vs. 5160
Feature 5150 5160 (XT)
Year 1981 1983
ISA slots 5 8
PSU 63.5 W (Type 1) or 130 W (Type 2) 130 W standard
Hard disk Optional, with Type 2 PSU Standard (10 MB MFM, later 20 MB)
Cassette port Yes No
Architecture
The 5160 uses the same support-chip family as the 5150: Intel 8088 CPU, optional 8087 FPU, 8259A interrupt controller, 8237A-5 DMA controller, 8253-5 timer, and 8255A-5 PPI.
General Maintenance, Troubleshooting and Capacitor Replacement
The 5160 shares most of its maintenance and recap procedure with the IBM PC (5150). For the +5 V and +12 V tantalum capacitor positions on the 5160 motherboard see minuszerodegrees.net's documented capacitor lists: on the 5160 motherboard, 13 of 16 tantalum capacitors sit on the +5 V line, while C56 (a tantalum) is the +12 V filter for the expansion slots and is well-known for going short-circuit. The 5160 will operate without C56.
