IBM 5153
| IBM Color Display | |
| IBM monitors, left to right: 5151 monochrome, 5153 colour, 5154 Enhanced Color Display | |
| Manufacturer | IBM |
| Type | TTL RGBI colour CRT monitor |
| Release date | Announced 4 February 1983; available March 1983 |
| Interface | TTL RGBI, 9-pin D-shell (driven by the IBM Color Graphics Adapter) |
| Compatible | IBM PC (5150), IBM PC XT (5160), IBM PC AT (5170), CGA-compatible systems |
| Dimensions | 297 mm H × 392 mm L × 407 mm D |
| Weight | 11.8 kg (26 lb) |
| Model | 5153 Model 1 (IBM publication 6361470) |
The IBM 5153, which IBM called the IBM Color Display, is the RGBI colour monitor IBM made for the Color/Graphics Monitor Adapter (CGA). IBM announced it on 4 February 1983 in announcement letter 183-002, with planned availability in March 1983.[1] CGA software was written for the colours a 5153 produces.
Display characteristics
[edit | edit source]IBM's figures:[2]
| Item | IBM figure |
| CRT | 340 mm (13 in), high-contrast (black) screen |
| Colours | Up to 16 with the Color/Graphics Monitor Adapter; red, green, blue and intensity are independent signals |
| Text | 80 characters by 25 rows; characters in an 8 PEL high by 8 PEL wide matrix |
| Vertical drive | Positive, TTL-compatible, 50/60 Hz, non-interlaced |
| Horizontal drive | Positive-level TTL, 15.75 kHz |
| Power | Own mains cable and power switch; supply switches automatically between 120 V 60 Hz and 220 V 50 Hz |
| Heat output | 240 BTU/hr |
| Cables | Power 1.83 m (18 AWG); signal 1.5 m (22 AWG) |
| Controls | Front: power, power indicator, brightness, contrast. Rear: vertical hold, vertical size |
Measured at the adapter, CGA horizontal sync is a 4 µs positive-going pulse every 63.7 µs and vertical sync a 190 µs positive-going pulse every 16.7 ms.[3]
Colour 6 is brown
[edit | edit source]With four digital lines, CGA colour 6 (red plus green, low intensity) would be dark yellow. The 5153 has a circuit that detects that combination and reduces the green drive, so the colour appears as brown.[4] minuszerodegrees.net publishes that part of the 5153 schematic.[5] IBM's own CGA documentation names the low-intensity graphics palette "green/red/brown", and IBM's announcement lists brown among the 16 colours.[6][1]
Monitors without the circuit, such as the Amdek Color II before its upgrade board was fitted, show dark yellow in that position, and so does a 5153 whose brown circuit has failed.[7]
Input connector
[edit | edit source]A 9-pin D-shell carrying TTL RGBI.[3]
| Pin | Signal |
| 1 | Ground |
| 2 | Ground |
| 3 | + Red |
| 4 | + Green |
| 5 | + Blue |
| 6 | + Intensity |
| 7 | Not used |
| 8 | + Horizontal sync |
| 9 | + Vertical sync |
Pin 7 is missing from the 5153's plug. That is normal, because CGA does not use it.[8]
Common faults
[edit | edit source]Normal behaviour first: the brightness and contrast knobs on a healthy 5153 are stiff.[8]
A white horizontal line just below the top of the raster is a known, correctable defect. minuszerodegrees.net points to the "Vertical Scan Issue" section of a document on fitting an EGA card to an IBM 5155 for the fix.[8]
The Sams Computerfacts service data gives a symptom-to-circuit chart and a troubleshooting section for the 5153:[9]
| Symptom | Where to look |
| No picture, no raster | AC power supply, then the supplies derived from horizontal output transformer T401 |
| Raster but no picture | Source voltages from T401 |
| No raster | The HV rectifier, which is part of T401 |
| Dead supply | AC line fuse F801; if it has blown, check bridge rectifier D801–D804, DC-to-DC converter transformer T802, output transistor Q801 and SCR Q805. Expect 153 V at the cathode of D801 and 115 V at the cathode of D815, measured from the isolated ground |
| No vertical deflection | Inject a vertical signal at pin 2 of sync processor IC Q402. If deflection returns, work around Q402; if not, check vertical driver Q301, vertical output transistors Q302 and Q303, electrolytic C315 and the yoke's vertical winding |
| Poor vertical linearity or foldover | Vertical feedback and bias circuits: D301–D306, C315, side pincushion transformer T402 |
| Yellow raster (no blue) | Chroma and blue output circuits |
| Cyan raster (no red) | Chroma and red output circuits |
| Magenta raster (no green) | Chroma and green output circuits |
Component failures reported by repairers in the minuszerodegrees.net monitor repair database include:[10]
- Dead or shutting down: C812 (1 µF), C815 (4.7 µF 50 V), C826 (47 µF), C821 (47 µF), C507, C537 and C567 (2.2 µF), fusible resistor R213 (2.2 Ω ½ W), the flyback (TFB150A), T401 (TLN114) and Q801 (2SD1185).
- Dim: R438 (200 kΩ) and C509 (4.7 µF 250 V) on the CRT board.
- Picture drifting sideways: C213 (1 µF).
- No vertical sync: vertical IC Q402 (HA11235), then C305 (140 pF) and C307 (470 pF).
- Vertical collapse: C308 (330 µF 16 V) shorted, which opened R312.
- Other vertical faults: C302 (1 µF 50 V) near the HA11235.
CRT safety
[edit | edit source]The 5153 runs from the mains and its CRT keeps a dangerous anode charge after the set is unplugged. IBM's logic diagram carries the warning that voltages up to 450 V exist on the printed circuit boards.[2] Sams takes power supply measurements from an isolated ground, so use the correct reference.[9] Discharge the tube before working inside; see CRT Discharge Procedure.
[edit | edit source]- ↑ 1.0 1.1 IBM announcement letter 183-002, "IBM Color Display, 5153 Model 1 for IBM Personal Computer", 4 February 1983, transcribed at ardent-tool.com: planned availability March 1983, 13-inch screen, 16 colours including brown, the Color/Graphics Monitor Adapter prerequisite, operating environment, and a three-month warranty.
- ↑ 2.0 2.1 IBM, IBM Color Display (6361470), Options and Adapters, Personal Computer Hardware Reference Library, pp. 1 to 5: description, specifications and logic diagram. Hosted here as File:IBM Options and Adapters - IBM Color Display (5153).pdf and described at IBM Options and Adapters - IBM Color Display.
- ↑ 3.0 3.1 IBM: MDA / CGA / EGA, minuszerodegrees.net: 9-pin assignments for MDA, CGA and EGA, sync frequencies, and sync pulse shapes measured on IBM cards.
- ↑ VileR, "The IBM 5153's True CGA Palette and Color Output", int10h.org, June 2022.
- ↑ IBM 5153: Dark yellow to brown circuitry, minuszerodegrees.net. Extract from the 5153 schematic.
- ↑ IBM, IBM Color/Graphics Monitor Adapter, Options and Adapters, Personal Computer Hardware Reference Library: the colour-select register, where bit 5 selects green/red/brown when 0 and cyan/magenta/white when 1. Hosted here as File:IBM Options and Adapters - IBM Color Graphics Monitor Adapter.pdf and described at IBM Options and Adapters - IBM Color Graphics Monitor Adapter.
- ↑ "The Saga of the Color Brown in the Early Years of the PC", Nerdly Pleasures, March 2023.
- ↑ 8.0 8.1 8.2 IBM 5153: Known Problems/Issues, minuszerodegrees.net.
- ↑ 9.0 9.1 Howard W. Sams & Co., Computerfacts service data for the IBM 5153, "Troubleshooting Aid" and "Troubleshooting" (power supply, horizontal, vertical, raster). Hosted here as IBM 5153 Color Display Service Manual (Sams).
- ↑ Monitors/Terminals Repair Database, minuszerodegrees.net, IBM 5153 (CGA) entries.
[edit | edit source]- IBM Color Graphics Adapter, the adapter that drives the 5153
- IBM 5151, the monochrome equivalent
- IBM PC (5150) · IBM PC XT (5160) · IBM PC AT (5170)
- IBM 5153 Color Display Service Manual (Sams) · IBM Options and Adapters - IBM Color Display · IBM Personal Systems Reference - Monitors
- CRT Discharge Procedure · Capacitor Failure Symptoms
