IBM PC Series 300
IBM PC Series 300
IBM PC 300PL, Type 6892
ManufacturerIBM
TypeDesktop personal computer family
Released1994
Discontinued2000
CPUIntel 486, Pentium, Pentium MMX, Pentium Pro, Pentium II, Pentium III or Celeron, by type
MemoryUp to 128 MB (486 and early Pentium types) to 1 GB (last PC 300GL and 300PL types)
StorageIDE or EIDE hard disk, 3.5-inch diskette
DisplayOn-board Cirrus Logic, S3, Matrox or Intel graphics, by type
Sound—
OS / FirmwarePreloads included DOS with Windows 3.11, Windows 95, Windows 98, Windows NT 4.0 and OS/2 Warp Connect
PredecessorIBM PS/ValuePoint
SuccessorIBM NetVista
Model no.Types 6560 to 6598, 6268 to 6288, 6344, 6345, 6862, 6892
The IBM PC Series 300 is the range of IBM business desktops sold under the IBM PC Series name between 1994 and 2000. The PC Series was announced in October 1994 as the successor to the PS/ValuePoint and withdrawn in October 2000, when IBM NetVista replaced it.[1][2] The first machines carried model names (PC 330, 340, 350, 360 and 365); from 1997 the range was sold as the PC 300GL, PC 300PL and PC 300XL, and in 2000 simply as the PC 300.[2] The PC Series 700 was the higher-end range sold alongside it.[3]
IBM's machine type numbers for the 300 Series begin 65 or 62; in IBM's scheme the first two digits identify the commercial desktop series (65 for 300, 68 for 700), the third the number of slots and bays, and the fourth the system board or riser type.[3] The PC 300PL types 6862 and 6892 and the IntelliStations also begin 68, so the type alone does not identify the series; check the name on the machine's label.
Models
First generation
PC 330, 340, 350, 360 and 365 (PSREF)
Type Name Processor Graphics Maximum memory Notes PSREF page
6571 PC 330 486DX2-66, 486DX4-100 Cirrus Logic GD5430, VL-Bus 128 MB 3 slots, 3 bays; VL/ISA 2
6573 PC 330 486DX2-66, 486DX4-100 GD5430 128 MB PCI/ISA 2
6581 PC 350 486DX2-66, 486DX4-100 GD5430, VL-Bus 128 MB 5 slots, 5 bays; VL/ISA 2
6583 PC 350 486DX2-66, 486DX4-100 GD5430 128 MB PCI/ISA 2
6575, 6585 PC 330, PC 350 Pentium 60 and 66 MHz S3 864 128 MB 4, 5
6576, 6586 PC 330, PC 350 Pentium 75 to 166 MHz S3 Trio64 128 MB 6 to 9
6577, 6587 PC 330, PC 350 Pentium 100 to 200 MHz S3 Trio64V+ 192 MB One 168-pin DIMM socket plus SIMMs, EDO non-parity only; supply 145 W (330) or 200 W (350) 10, 12
6560 PC 340 Pentium 100 to 166 MHz Cirrus Logic 128 MB Four 72-pin SIMM sockets, EDO non-parity 60 ns; 145 W supply 13, 14
6598 PC 360 Pentium Pro 150 and 200 MHz Matrox 128 MB Four 72-pin SIMM sockets, fast page mode only, parity or ECC 15, 16
6589 PC 365 Pentium Pro 180 and 200 MHz, second processor socket S3 Trio64V+ 512 MB 200 W supply 17, 18
The 486 models have IBM's SelectaBus riser, which can be changed to give either VL-Bus or PCI local bus slots.[2] Wikipedia states that the PC 350 with type 6586 has an Intel-designed system board with an Intel/AMI BIOS.[1]
IBM PC 330, Type 6577-9BT. (Image: Wikimedia Commons, CC BY-SA 4.0)
IBM PC 340, Type 6560. (Image: Wikimedia Commons, CC BY-SA 4.0)
PC 300GL, 300PL, 300XL and PC 300
Later PC 300 types (PSREF)
Type Name Processor Chipset and graphics Maximum memory PSREF page
6282, 6284 PC 300GL Pentium or Pentium MMX Cirrus Logic GD5446 128 MB 30, 31
6561, 6591 PC 300GL Pentium II; later Celeron 266 and 300 MHz 440LX; Cirrus Logic GD5465 AGP 256 MB 32, 33, 48, 49
6275, 6285 PC 300GL Pentium II or Celeron 440BX; S3 Trio3D AGP 768 MB 39 to 45
6277, 6287 PC 300GL Celeron 440BX; S3 Trio3D AGP 512 MB 34 to 38
6268, 6278, 6288 PC 300GL Celeron Intel 810, graphics in the chipset 512 MB 50 to 55
6563, 6564, 6574 PC 300GL Pentium III AGP 4X adapter 1 GB 46, 47, 56 to 64
6562, 6592 PC 300PL Pentium MMX 166 to 233 MHz Matrox Mystique 384 MB 65, 66
6862, 6892 PC 300PL Pentium II 440BX; S3 Trio3D AGP; Ethernet 768 MB 67 to 74
6565 PC 300PL Pentium III AGP 4X adapter 1 GB 75 to 78
6584, 6594 PC 300PL Pentium III Intel 820 79 to 82
6588 PC 300XL Pentium II 233, 266 or 300 MHz (Klamath) S3 Trio64V2 384 MB 83, 84
6344, 6345 PC 300 Celeron 500 to 633 MHz Intel 810E 512 MB 85, 86
The PC 300XL (6588) has three 168-pin DIMM sockets for 3.3 V EDO DIMMs, non-parity or ECC, of 16 to 128 MB each.[2]
IBM PC 300GL, Type 6282-81J. (Image: Wikimedia Commons, public domain)
IBM PC 300PL Type 6892-5BJ system board. (Image: Wikimedia Commons, public domain)
Power supplies
IBM's maintenance manual gives the supply capacity on each type's specification page: 145 W for types 6265, 6275, 6272, 6282, 6284, 6561, 6562, 6862 and the 6X7X group; 200 W for types 6285, 6560, 6588, 6589, 6591, 6592, 6598, 6892 and the 6X8X group.[3] The PSREF gives 145 W for the PC 330 and PC 340 and 200 W for the PC 350.[2]
On types 6265, 6275, 6285, 6561, 6591, 6562, 6592, 6862 and 6892 the 20-pin main power connector is on the riser card; on the PC 360-S150 it is on the system board.[3] IBM's service limits, measured with the supply connected, are +4.75 to +5.25 V on +5 V, +11.4 to +12.6 V on +12 V, −4.5 to −5.5 V on −5 V, −10.8 to −13.2 V on −12 V, and +4.75 to +5.25 V on Power Good. The +3.3 V output is checked at 3.3 to 3.46 V on the system board and 3.17 to 3.46 V at the riser. If the voltages are wrong and the power cord is good, IBM's instruction is to replace the supply.[3]
Battery and BIOS
The CMOS backup battery is a 3 V lithium cell, IBM FRU 33F8354, on the types in IBM's maintenance manual.[3] IBM's checkout procedure has the latest BIOS installed before any part is replaced, because an old BIOS can cause false errors and unnecessary system board replacement.[3]
IBM PC 300PL Type 6892 BIOS start-up screen. (Image: Wikimedia Commons, public domain)
Known problems
  • On the PC 300PL 6862, the AGP slot sits away from the riser and needs an NLX-format video card with its connector mounted high. A review of a 6862 found that the label under the cover gives switch settings for Pentium III processors up to 550 MHz; with the latest BIOS the reviewer ran an 800 MHz Pentium III, and a 1.3 GHz Tualatin on a PowerLeap adapter.[4]
  • The same reviewer found that a PC 300XL (6588) asked for Setup to be run after any configuration change, even unplugging the mouse.[5] The 6588's DIMM sockets take EDO memory; a commenter on that review notes that SDRAM DIMMs fit but do not work.[5]
  • One owner on the Badcaps forum found three CHHSI 560 µF 25 V capacitors (WG(M) series, date code 9846) on a PC 300PL with intermittent faults. Another member advised replacing every CHHSI capacitor; replacing those three did not cure that machine.[6] See IBM PC Series 300 Capacitor Replacement Guide.
  • IBM's G51 and G51t CRT monitors (6541-02N, -02E, -02S, -Q0N, -Q0E, -Q0S), sold from June 1997 to December 1998, were recalled for repair in 2003 because the circuit board can overheat and smoke.[7]
  1. ↑ 1.0 1.1 IBM PC Series, Wikipedia. Tertiary source, used here for the announcement and withdrawal months, which it takes from IBM's PSREF.
  2. ↑ 2.0 2.1 2.2 2.3 2.4 IBM PC Institute, Personal Systems Reference: IBM PC, 1994 to 2000 – withdrawn, November 2000, Version 212. Hosted as File:IBM PSREF IBM PC 1994 to 2000 Withdrawn (November 2000).pdf. Page numbers below are PDF pages.
  3. ↑ 3.0 3.1 3.2 3.3 3.4 3.5 3.6 3.7 IBM, IBM Personal Computer 300 Series, 700 Series, IntelliStation Hardware Maintenance Manual, S83G-7789-17, Eighteenth Edition (September 1998): supported types p. i; general checkout pp. 2 to 17; power supply checks pp. 28 to 30; parts listings pp. 86 to 137; specifications pp. 195 to 216; type and model number conversion p. 438. Hosted as File:IBM PC 300 700 IntelliStation Hardware Maintenance Manual S83G-7789-17 (Sep 1998).pdf.
  4. ↑ IBM PC 300PL Type 6862, Ancient Electronics blog, 2020. A single owner's review.
  5. ↑ 5.0 5.1 IBM PC 300XL Model 6588, Ancient Electronics blog, 2021, and its comments.
  6. ↑ IBM 300PL, Badcaps forum thread. First-hand reports, not a manufacturer document.
  7. ↑ U.S. Consumer Product Safety Commission, CPSC, IBM Announce Recall to Repair Computer Monitors (2003) and the expansion of that recall.
