IBM 5100
IBM 5100 Portable Computer
IBM 5100 with its built-in display, keyboard and tape drive
DeveloperIBM General Systems Division
ManufacturerIBM
TypePortable desktop computer
ReleasedAnnounced 9 September 1975; available worldwide April 1976
Intro priceUS$8,975 to US$19,975 (1975)
CPUIBM controller card (G2), 15.1 MHz oscillator; known as PALM
Memory16, 32, 48 or 64 KB read/write storage; executable ROS and language ROS
StorageBuilt-in DC300-type tape cartridge drive, 204K bytes per cartridge; optional IBM 5106 Auxiliary Tape Unit
DisplayBuilt-in 5-inch CRT, 16 lines of 64 characters; external video output for a monitor
SoundNone
Power0.4 kVA at 100, 115, 220 or 235 V AC
Dimensions445 × 610 × 203 mm (17.5 × 24.0 × 8.0 in), width × depth × height
Weight24 kg (50 lb)
OS / FirmwareAPL, BASIC or both, in ROS
PredecessorSCAMP prototype (1973)
SuccessorIBM 5110
Model no.5100
The IBM 5100 Portable Computer is a desktop computer made by IBM's General Systems Division. IBM announced it in a press release dated 9 September 1975,[1] and it became available worldwide in April 1976.[2] It has a built-in 5-inch display, keyboard and tape cartridge drive in one case, weighs 24 kg, and runs APL, BASIC or both directly from read-only storage (ROS).[3][1]
The 5100 grew out of a prototype that ran the IBM 1130 version of APL and stored data on an audio-type cassette. IBM formed a 5100 development team in late 1973; it added BASIC, replaced the cassette with the data cartridge, and switched the APL to APLSV from the System/370.[2] The prototype was SCAMP (Special Computer APL Machine Portable), built in 1973 by a team led by Paul Friedl, who described it in PC Magazine in 1983.[4] SCAMP is in the collection of the Smithsonian National Museum of American History.[5]
The 1973 SCAMP prototype at the Smithsonian National Museum of American History (Wikimedia Commons, CC BY-SA 2.0)
Launch and configurations
IBM's press release priced the 5100 at US$8,975 to US$19,975, depending on memory (16K, 32K, 48K or 64K bytes) and language (APL, BASIC or both). The 5103 printer cost US$3,675 and the 5106 Auxiliary Tape Unit US$2,300.[1] BYTE described the machine as "a very professional package at a premium price".[1]
Architecture
Processor
IBM's service manuals call the processor the controller, and define it as "the microinstruction processor within the 5100 Portable Computer".[6] It is the controller card in A1 board position G2.[7] The name PALM does not appear in the 5100 service manuals; see IBM PALM processor.
The controller uses a 15.1 MHz oscillator to generate 66.2 ns clock pulses, which IBM calls multiclock cycle (MCC) pulses. Each machine cycle has an I phase of three I cycles (3, 8 and 3 MCC) and an E phase of one to five E cycles of 3 or 8 MCC each, so an E phase lasts 3 to 40 MCC depending on the op code.[8] The 1.9 MHz clock figure found in secondary sources matches the length of one 8-MCC cycle (about 530 ns), not IBM's oscillator frequency.[8]
There are four program levels: level 0 for normal operation, level 1 for the serial I/O and asynchronous communications adapters, level 2 for tape and printer, and level 3 for the keyboard. Each level has sixteen 2-byte registers, which sit on the controller card and are addressed as the lowest 128 bytes of read/write storage. Register 0 of each level is its instruction address register.[8]
The storage read and write buses are 18 bits wide (two bytes plus parity), and the data buses to and from the base I/O card are 9 bits wide (one byte plus parity). The storage address bus is 16 bits wide and addresses read/write storage or executable ROS.[7] IBM's 1977 design paper describes the processor as "a fast two-chip 8-bit processor" with 49 16-bit microinstructions and four interrupt levels.[9]
Memory
The 5100 has three kinds of storage, all MOSFET LSI: read/write storage, and two kinds of ROM.[10]
  • Executable ROS holds the microcode the controller runs directly: the APL and BASIC emulators, device support and the I/O supervisor. It is on cards H2 (BASIC, I/O and diagnostics) and H4 (APL supervisor).[9][11]
  • Nonexecutable ROS holds the APL and BASIC interpreters in an intermediate language (System/370-like instructions in the case of APL). It uses a 48K-bit-per-chip FET ROM and is attached through the I/O adapter, so the controller reads it with a GET microinstruction as if it were a device, not through the storage address register.[10][9] It is on cards C2, C4, D2 and D4.[11]
  • Read/write storage is the user memory and also holds the controller's registers. It is on up to eight cards in positions K2 to N4.[11][10]
The design paper gives the machine a maximum capacity of 248K of memory.[2]
Physical design
IBM's specification is 17.5 in (445 mm) across the front, 24.0 in (609.6 mm) along the side and 8.0 in (203 mm) high, with a weight of 50 lb (24 kg). Heat output is 780 Btu per hour, and the machine draws 0.4 kVA at 100 V 50 Hz, 100 V 60 Hz, 115 V 60 Hz, 220 V 50 Hz or 235 V 50 Hz.[3] The machine is deeper than it is wide.
The control panel has a BRIGHTNESS control and switches for L32-64-R32 (show the left 32, all 64, or the right 32 character positions), REVERSE DISPLAY, BASIC-APL (on dual-language machines only), RESTART and DISPLAY REGISTERS. In the DISPLAY REGISTERS position the screen shows the first 512 bytes of storage in hexadecimal.[12] The machine is ready about 25 seconds after power-on, and IBM's instruction is to wait five seconds after switching off before switching on again.[12]
IBM 5100 front view with the display, keyboard and tape drive (Wikimedia Commons, public domain)
The built-in tape unit takes a data cartridge. IBM states that all tapes have 204K bytes of storage and that each new file needs a further 0.5K bytes for its header.[13] The IBM 5106 Auxiliary Tape Unit adds a second drive using the same cartridge.[14] The 5100 has no diskette support; diskettes arrived with the IBM 5110.
Peripherals and interfaces
  • The IBM 5103 Printer is an 80 characters-per-second, 132-column dot matrix printer.[1]
  • The IBM 5106 Auxiliary Tape Unit is a second tape drive.[1]
  • The Communications Adapter makes the 5100 emulate an IBM 2741 terminal.[1]
  • The Serial I/O Adapter is an RS-232C serial channel whose line rate, parity and code the user can set, for plotters, displays, card readers and printers.[15]
  • A video output drives an external monitor. IBM warns that a modified domestic television used as a monitor must be isolated from the mains by a transformer, because an unmodified set can put line voltage on the coaxial cable and the 5100 frame.[16]
  • The Tycom 5100 was a third-party adapter that drove an IBM Selectric typewriter from the 5100 at up to 15.5 characters per second, priced at US$2,495.[17]
Languages
APL and BASIC are the operating environment; there is no separate operating system. On machines with both, the BASIC-APL switch selects the language at power-on or when RESTART is pressed.[12]
The APL is APLSV from the System/370, run under an emulator. The team rejected two IBM 1130 APL implementations, whose overlay paging cost too much time and user storage, and adopted APLSV in late June 1974. APLSV gave 15 digits of numerical precision against six on the 1130 versions. The emulator, a supervisor, a command processor and an I/O processor were written in about six months, and the finished emulator uses less than 10K of ROM.[18]
Diagnostics and faults
At power-on, and whenever RESTART is pressed, the bring up diagnostic in executable ROS (card H2) tests the controller, storage, ROS, keyboard and display. If it completes, LOAD0 (BASIC) or CLEAR WS (APL) appears after about 25 seconds. A failure lights PROCESS CHECK or leaves a string of letters from A to K on the screen, which identifies the failing area.[19] Diagnostic Control Program 1 (DCP1), loaded from the keyboard with CMD, HOLD and the numeric minus key, displays and alters any read/write storage location.[20]
The power supply is a transistor switching regulator producing +5, −5, +8.5, +12 and −12 V, with overvoltage, undervoltage and overcurrent shutdown.[21] IBM's intermittent-failures guide lists the faults its engineers met in the field, including a badly formed clamp that lets the Y1 power plug fall out, a failing POWER ON/OFF switch, dirty flyplates in the keyboard, glazed tape spindles and worn spindle or jackshaft bearings.[22] Some A1 board cards, including the controller card, have jumpers set differently for the 5100 and the 5110, so check them on a card taken from a donor machine.[23]
See the IBM 5100 Troubleshooting Guide, IBM 5100 Maintenance Guide and IBM 5100 Capacitor Replacement Guide.
Other 5100 manuals are on bitsavers: the Communications/Serial I/O Maintenance Information Manual (SY31-0429-2), the APL and BASIC introductions and reference manuals, the Communications Reference Manual (SA21-9215-0) and the Serial I/O Adapter Feature User's Manual (SA21-9239-1).
The 5100 is the machine named in the John Titor internet hoax of 2000–2001, in which a poster claiming to be a time traveller from 2036 said he had come back for an IBM 5100 because it could run IBM mainframe code.[25] The APL in the 5100 does run System/370 code, under the emulator described in IBM's design paper.[18] The machine also appears as the "IBN 5100" in the 2009 visual novel and 2011 anime Steins;Gate.[26]
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 "Welcome, IBM, to personal computing", BYTE, vol. 1 no. 4, December 1975, p. 90. Archive.org scan. Announcement date, prices, memory and language options, display format, cartridge capacity, and the 5103, 5106 and communications options.
  2. ↑ 2.0 2.1 2.2 Cubbon, A. J., "The IBM 5100 Portable Computer Design", APL ITL Symposium, Endicott, N.Y., January 11–13, 1977, vol. 2 (IBM Internal Use Only), p. 52. Hosted as IBM 5100 Portable Computer Design (1977).
  3. ↑ 3.0 3.1 IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3 (October 1979), Appendix B, p. B-1, "IBM 5100 Portable Computer Specifications". Hosted as IBM 5100 Maintenance Information Manual.
  4. ↑ Friedl, P. J., "SCAMP: The Missing Link in the PC's Past?", PC Magazine vol. 2 no. 6, November 1983, pp. 190–197.
  5. ↑ Smithsonian National Museum of American History, "IBM SCAMP Microcomputer", catalogue record nmah_334628.
  6. ↑ IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3, Appendix D (Glossary), p. D-1.
  7. ↑ 7.0 7.1 IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3, p. 4-16, "5100 Controller Description".
  8. ↑ 8.0 8.1 8.2 IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3, p. 4-17, "Oscillators/Clocks", "Machine Cycles" and "Interrupts".
  9. ↑ 9.0 9.1 9.2 Cubbon, "The IBM 5100 Portable Computer Design", p. 55.
  10. ↑ 10.0 10.1 10.2 Cubbon, "The IBM 5100 Portable Computer Design", p. 54.
  11. ↑ 11.0 11.1 11.2 IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3, p. 2-15, item 209 "A1 Board (Card Locations)".
  12. ↑ 12.0 12.1 12.2 IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3, pp. 4-9 and 4-10, "Switches and Controls".
  13. ↑ IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3, p. 3-92, Intermittent Failures Troubleshooting Guide.
  14. ↑ IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3, p. 4-3, "Introduction".
  15. ↑ Cubbon, "The IBM 5100 Portable Computer Design", p. 56.
  16. ↑ IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3, pp. 3-94 and 3-97, "5100 Service Tips" and "Attachment of a TV Monitor".
  17. ↑ Datamation, May 1976, p. 212, new products. bitsavers scan.
  18. ↑ 18.0 18.1 Cubbon, "The IBM 5100 Portable Computer Design", pp. 53–54.
  19. ↑ IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3, p. 3-9, "Bring Up Diagnostic".
  20. ↑ IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3, pp. 3-17 and 3-18, "Diagnostic Control Program 1 (DCP1)".
  21. ↑ IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3, p. 4-51, "Power Supply PC Board" and "Power Supply Protection".
  22. ↑ IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3, pp. 3-90 to 3-93, "5100 Symptom Index".
  23. ↑ IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3, p. 2-16, item 209 "A1 Board (Card Jumpers)".
  24. ↑ IBM, IBM 5100 Maintenance Analysis Procedures, PN 1608314, second edition, March 1976. Hosted as File:IBM 5100 Maintenance Analysis Procedures 1608314.pdf.
  25. ↑ Wikipedia, "John Titor".
  26. ↑ Wikipedia, "IBM 5100", section "In popular culture".
Further reading
