IBM 5100 Capacitor Replacement Guide
The IBM 5100 Portable Computer's DC supply is a switching supply. IBM describes it as "a small, high power, high frequency transistor switching regulator (TSR) supply" developing five DC voltages: +5, −5, +8.5, +12 and −12 V.[1]
IBM's 5100 maintenance manual, Maintenance Analysis Procedures (MAPs) and parts catalogue give no capacitance values. The Power MAP treats the DC supply as one field-replaceable unit, the maintenance manual does not draw its circuit, and the parts catalogue lists the capacitors it does name by IBM part number only, with no capacitance, voltage or dielectric.[2][3] There is therefore no capacitor table for this machine. What IBM did publish, and what a restorer can use, is below: the rails and tolerances, the protection trip points, the named mains-side parts and their part numbers.
The 5110 and 5120 guides cover what differs on those machines.
Safety
[edit | edit source]- Mains: the AC box, under the display, carries mains to the line filter, fuse F1, the power on/off switch, the fan and the tape unit motor.[4][5] Unplug the line cord before removing the covers.
- Stored charge: the supply takes mains from the AC box through plug J1, and IBM does not draw its circuit.[5] Treat every large capacitor on the supply board as charged until measured, and discharge through a resistor.
- Display: the display and control panel take +5 V and +12 V from the Z3 cable,[6] but the tube's high voltage is generated inside the display unit. IBM warns that "the display unit contains high voltages".[7] Follow the CRT Discharge Procedure.
See also Battery Explosion, Capacitor or Corrosion Damage and Recommended Tools.
The supply and what each rail feeds
[edit | edit source]| Rail | Loads |
| +5 V | Basic logic voltage |
| −5 V | Tape control card, storage cards, BSCA cards and common ROS |
| +8.5 V | Storage cards, keyboard, display adapter, printer adapter, BSCA cards and all ROS cards |
| +12 V | Display unit, tape select magnets, tape LEDs, BSCA cards and 5114 R1 relay |
| −12 V | Tape unit, 5114 R1 relay, BSCA cards and asynchronous communications/serial I/O card |
IBM states that the outputs may vary from +10 % to −9 % of the rated voltage before they affect the system.[1]
Protection
[edit | edit source]The supply shuts down when the +12 V output exceeds +16 V, when the −5 V rail is less negative than −3 V, or when the current in the transformer primary is excessive. After any automatic shutdown, IBM says to leave the machine switched off for at least five seconds before powering up again.[1]
A short on the DC side, such as a failed capacitor on a card, can also blow mains fuse F1. IBM's Power MAP checks for this by disconnecting the DC power cable at Y1: if F1 then holds, the fault is on the A1 board, a card, a cable or an attached device. The MAP then reconnects Y1 with every other cable to the A1 board unplugged. If F1 still blows or the power drops, it removes all the cards and refits them one at a time, powering down and up for each; otherwise it reconnects the cables one at a time while watching the rail that was out of tolerance. The last part refitted before the fault returns is the faulty one.[2] Switch off before removing or refitting a read/write storage card (K2 to N4).[8]
Expected measurements
[edit | edit source]Measure at the Y1 power connector on the A1 board:[9]
| Voltage | Loaded | Unloaded (Y1 disconnected) |
| +5 V | 4.6 to 5.5 | 5.5 to 6.5 |
| +8.5 V | 7.9 to 9.35 | 7.4 to 9.0 |
| +12 V | 11.0 to 13.2 | 9.8 to 12.2 |
| −5 V | −4.6 to −5.5 | −3.7 to −4.7 |
| −12 V | −11.0 to −13.2 | −9.0 to −11.5 |
Unloaded, IBM's +5 V range is higher than the loaded one, and the +8.5, +12, −5 and −12 V ranges are lower in magnitude. Judge a supply tested off the machine against the unloaded column.
Y1 socket pin assignments
[edit | edit source]| Line | A1 board pins |
| +5 V | A1D11, A1D13, A1E11, A1E13, B1A11, B1A13, B1B11, B1B13 |
| Ground | B1C11, B1C13, B1D11, B1D13, B1E11, B1E13, C1A11, C1A13, C1B11 |
| +8.5 V | C1C11, C1C13 |
| +12 V | C1D11, C1D13 |
| −5 V | C1E11 |
| −12 V | C1E13 |
| Not used | C1B13 |
Check the meter first
[edit | edit source]The display card provides a +6 V zener reference. Ground the meter at J2-D08 and measure at J2-S02. If it does not read exactly 6 V, correct each later reading with
- actual voltage = 6 × measured voltage ÷ reference voltage
IBM's example: reference 5.8 V and +5 V rail reading 4.8 V gives an actual 4.97 V.[10]
The capacitors IBM does identify
[edit | edit source]Only the AC box components carry designators, and there are two AC box styles.[11][5]
| Designator | Part | Old style | New style |
| L1 | Line filter | Yes | Yes |
| C1 | AC capacitor | Yes | Yes |
| C2 | Capacitor | Yes | Yes |
| C3, C4, C5 | Capacitors | Yes | No |
| R1 | Resistor assembly | Yes | On 220 V and 235 V machines only |
| F1 | Fuse: 5 A 125 V on 100 V and 115 V machines, 3 A 250 V on 220 V and 235 V machines | Yes | Yes |
| SW1 | Power on/off switch | Yes | Yes |
| TB1 | Terminal block | Yes | No |
| J1, J2, J3 | Plugs to the power supply, fan and tape unit | Yes | Yes |
IBM part numbers from the parts catalogue:[3]
- Old-style AC box (figure 10): capacitors 1608347 (two) and 5252805, resistor 1608895, line filter 1860276, 5 A fuse 512137.
- New-style AC box (figure 11): capacitor assembly 1608119, filter 1608101, fuses 512137 (5 A, 100/115 V) and 855252 (3 A, 220/235 V).
- Tape drive (figure 8): capacitor 5252836 on the tape motor for 100/115 V 50/60 Hz machines; capacitor-resistor assemblies 2451254 (220 V 50 Hz) and 2451258 (235 V 50 Hz).
- Power supply assembly (figure 5): 5564570 for 100/115 V, 5564569 for 220/235 V.
These parts are on the mains side. A replacement must match the original's capacitance and have at least its AC voltage rating and safety class, which are printed on the part.
Getting real values for the rest
[edit | edit source]IBM's maintenance manual, MAPs and parts catalogue give no value for any capacitor inside the DC supply, the display unit or the tape electronics. Two methods work:
- Read the parts. Photograph each board on both sides before removing anything, then record the designator, value, voltage, type, lead spacing and size for each position.
- Measure. Out of circuit, capacitance and ESR show whether a part has drifted. A part that measures within tolerance does not need replacing.
Do not fit values taken from the IBM PC family (5150, 5155, 5160, 5170). Those are different machines with different supplies, and none of them has a +8.5 V rail.
When to recap
[edit | edit source]Replace capacitors on evidence:
- a capacitor that is vented, bulged, split or leaking;
- corrosion or residue around its pads;
- a rail outside the loaded tolerances above, or one that is stable cold and drifts warm;
- a supply that trips its overcurrent or undervoltage protection with no card fault found;
- a mains-side capacitor that is cracked or discoloured.
See Capacitor Failure Symptoms.
Replacement practice
[edit | edit source]- Fit a voltage rating equal to or higher than the original.
- Keep the capacitance the same as the original.
- Replace mains-side parts with parts of the same safety class.
- Check the lead form and hole spacing before ordering.
- Keep soldering times short on these boards to avoid lifting pads.
[edit | edit source]- IBM 5100, IBM 5100 Maintenance Guide, IBM 5100 Troubleshooting Guide
- IBM 5100 Maintenance Information Manual, IBM 5100 Portable Computer Parts Catalog
- IBM 5110 Capacitor Replacement Guide, IBM 5120 Capacitor Replacement Guide
- Capacitor Failure Symptoms, CRT Discharge Procedure, Recommended Tools
[edit | edit source]- ↑ 1.0 1.1 1.2 IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3 (October 1979), p. 4-51, "Power Supply PC Board" and "Power Supply Protection". Hosted as IBM 5100 Maintenance Information Manual.
- ↑ 2.0 2.1 IBM, IBM 5100 Maintenance Analysis Procedures, PN 1608314, second edition (March 1976), Power MAP 0700, pp. 0700-1 to 0700-5: fuse F1 and load isolation, rail checks, and "Defective power supply" as the end of the supply branch. Hosted as File:IBM 5100 Maintenance Analysis Procedures 1608314.pdf.
- ↑ 3.0 3.1 IBM, IBM 5100 Portable Computer Parts Catalog, S131-0599-3 (November 1976): figure 5 (gate assembly, including the power supply assemblies), figure 8 (tape drive assembly) and figures 10 and 11 (AC box assembly, old and new style). Hosted as IBM 5100 Portable Computer Parts Catalog.
- ↑ IBM 5100 MIM, p. 2-3, item 200 "Functional Units".
- ↑ 5.0 5.1 5.2 IBM 5100 MIM, pp. 2-53 and 2-54, item 273 "AC Voltage Distribution" (old and new style).
- ↑ IBM 5100 MIM, p. 2-42, item 241 "Display – Z3 Socket Pin Assignments".
- ↑ IBM 5100 MIM, p. 2-39, item 240 "Display".
- ↑ IBM 5100 MIM, p. 3-94, "5100 Service Tips".
- ↑ IBM 5100 MIM, p. 2-52, item 272 "Power – Y1 Socket Pin Assignments", with the tolerance table.
- ↑ IBM 5100 MIM, p. 2-49, item 270 "CE Meter Calibration Check".
- ↑ IBM 5100 MIM, pp. 2-11 and 2-12, item 207 "AC Box" (old and new style).
