IBM PALM processor
| PALM processor card from an IBM 5110 (slot J2), with 13 metal-can gate arrays. Photograph: Christian Corti, Stuttgart Computer Museum | |
| Developer | IBM, Boca Raton, Florida |
| Manufacturer | IBM |
| Type | Microprogrammed processor on one circuit card |
| Introduced | 1973 (SCAMP prototype); 1975 (IBM 5100) |
| Architecture | 16-bit instructions; 8-bit ALU; four interrupt levels, each with sixteen 16-bit registers |
| Data width | 16-bit storage data path plus 2 parity bits; 8-bit I/O bus plus parity |
| Address width | 16 bits |
| Clock rate | 15.1 MHz oscillator; 66.2 ns clock pulses |
| Package | Circuit card with 13 metal-can gate arrays |
| Used in | IBM 5100, IBM 5110, IBM 5120 |
The IBM PALM is the processor of the IBM 5100, IBM 5110 and IBM 5120. It is not a single chip but a circuit card carrying 13 metal-can gate arrays and a few other parts, which runs a 16-bit microinstruction set from read/write storage or read-only storage (ROS).[1] IBM's maintenance manuals never use the name PALM: the 5100 manual calls the card in slot G2 the controller and defines it as "the microinstruction processor within the 5100 Portable Computer", and the 5110 manual calls the card in slot J2 the processor card.[1][2] The name appears in IBM's internal documents, such as H. J. Myers' 1977 Instructions for the Use of Assembler Generator, General Assembler, General Loader, which uses "the PALM computer" as its example target machine, and IBM's description of the microinstruction set ("The micro-instructions selected for PALM are composed of sixteen bit control words").[3][4]
Origin
[edit | edit source]The PALM board first appeared in SCAMP, a portable APL prototype built in 1973. According to the Smithsonian, which holds the prototype, IBM's General Systems Division asked the IBM Scientific Center in Palo Alto in late 1972 to build a machine that would raise the profile of APL. Paul Friedl and his colleagues spent six months on it, using existing parts, including "a PALM microprocessor board from IBM in Boca Raton, Florida"; its APL emulated the IBM 1130 version. SCAMP was the prototype for the IBM 5100, announced in 1975.[5]
IBM's 1977 design paper on the 5100 says the prototype's APL ran on an 1130 emulator, and that the team later chose the System/370 APL, APLSV, and in late June 1974 began writing an emulator for it, which occupied less than 10K of executable ROM.[6]
How IBM describes the processor
[edit | edit source]The design paper describes the processor as "a fast two-chip 8-bit processor" with "49 16-bit microinstructions" and four interrupt levels.[6] The instruction count matches the maintenance manual, whose alphabetical list in Appendix C has 49 mnemonics.[1][7] The card itself carries 13 gate arrays, so "two-chip" does not describe the card as built.
The ALU is 8 bits wide and the arithmetic and logical instructions work on the low-order byte of a register; registers, instructions and the storage data path are 16 bits.[1]
Clock and cycle timing
The 5100 maintenance manual gives the timing:[1]
- A 15.1 MHz oscillator produces 66.2 ns multiclock cycle (MCC) pulses. On the card photographed above, the oscillator is a CTS Knights can marked 15.0912 MHz.
- Each machine cycle is an I (instruction) phase followed by an E (execute) phase.
- The I phase is three I cycles of 3, 8 and 3 MCC. In I cycle 1, register 0 of the current program level is loaded into the storage address register (SAR); in I cycle 2 the microinstruction is read from read/write storage or executable ROS into the operation register; in I cycle 3 the address is incremented by two and written back to register 0.
- The E phase is one to five E cycles of 3 or 8 MCC each, 3 to 40 MCC in total, depending on the op code. Only read/write storage can be addressed during E cycles.
IBM's microinstruction description says its execution-time table (Figure 11) assumes a storage cycle of 529.6 ns, which is eight MCC pulses, and that "execution times will be slightly larger when micro-instructions are executed out of FSU ROS".[4] Corti has a hand-copied table he believes is Figure 11; it gives times such as 2.65 µs for CTL and EMIT, 3.97 µs for MOVE, LDHD, STHD, CLRI, ADDI, SUBI and SETI, 4.63 µs for the register ALU instructions, GETB and the indirect loads and stores, and 5.30 µs for the jumps, each with a second, smaller figure in brackets that the copy does not explain.[8]
Registers and interrupt levels
[edit | edit source]IBM calls the interrupt levels program levels. Each has sixteen 2-byte registers, which are on the processor card but are addressed as the lowest 128 bytes of read/write storage. Register 0 of each level is the instruction address register; the other fifteen are general purpose.[1] IBM's microinstruction description reserves register 1 as the link register by convention.[4]
| Level | Devices on the 5100 |
| 0 | Normal operation |
| 1 | Serial I/O adapter and asynchronous communications adapter |
| 2 | Tape and printer |
| 3 | Keyboard |
The design paper lists the same levels from highest priority down: keyboard; tape and printer; communications and serial I/O; normal operation.[6] The processor checks the interrupt request lines after each microinstruction and takes the highest-numbered request; the system allows only one active request per level.[1] On the 5110, level 2 also serves the diskette.[9] Because each level has its own registers, switching level saves no state.
Instruction set
[edit | edit source]Every instruction is one 16-bit halfword. The top four bits give the op code; the rest hold register numbers, a device address, an immediate byte or a modifier.[7]
| Op code | Fields | Instructions |
| 0 | Rx, Ry, ALU modifier | MVM2, MVM1, MVP1, MVP2, MOVE, AND, ORB, XOR, ADD, SUB, ADDS1, ADDS2, HTL, LTH, GETR, GETA |
| 1 | Device address, command | CTL |
| 2, 3 | Rx, address | LDHD, STHD (direct, first 256 halfwords) |
| 4 | Device address, Ry, modifier | PUTB |
| 5, 6, 7 | Rx, Ry, modifier | STHI, LDBI, STBI (indirect) |
| 8 | Rx, byte | EMIT |
| 9 | Rx, mask | CLRI |
| A | Rx, byte | ADDI |
| B | Rx, mask | SETI |
| C | Rx, Ry, jump modifier | The 16 jumps: JLE, JLO, JEQ, JNO, JALL, JALLM, JNOM, JHAM, JHI, JHE, JHL, JSB, JSN, JSNM, JSM, JHSNM |
| D | Rx, Ry, modifier | LDHI |
| E | Device address, Ry, modifier | GETB, GETRB; with device address 0, SHFTR and ROTR |
| F | Rx, byte | SUBI |
The indirect instructions can add 1 to 4 to the address register or subtract 1 to 4 from it (modifier 0 to 7), or leave it unchanged (8 and above).[7] ADDI adds the immediate byte plus one, so a data byte of 00 adds 1; SUBI likewise subtracts the byte plus one.[1][4] GETA adds an even value from 0 to E, derived from the input byte, to a register.[7][8]
Jumps are skips
[edit | edit source]The 5100 manual defines the jump instructions this way: "A jump microinstruction tests for a condition and jumps over (skips) the next sequential microinstruction if that condition is met. If the jump condition is not met, the microinstruction following the jump microinstruction is executed and the address of the jump microinstruction plus 4 is stored in register 1 for use as a return address in case the next sequential microinstruction (after the jump microinstruction) branches to a subroutine."[1] The tests look at the low-order byte of the registers; modifiers 8 to F give the same tests with the jump on a false condition.[4]
There is no call, return or unconditional jump instruction and no hardware stack. A branch is a load into register 0, and IBM's description gives MOVE R0,R1 as the return from a subroutine. A subroutine that itself uses a conditional jump must save register 1 first, because every jump that is not taken overwrites it.[4]
Assemblers
[edit | edit source]The Myers document of 1977 describes IBM's assembler generator, general assembler and loader, with PALM as the worked example.[3] Alfred Arnold's Macro Assembler AS added an IBM PALM target in version 1.42 build 231 (October 2022).[10]
Buses and storage
The processor connects to the rest of the machine through three buses: a 16-bit storage address bus to read/write storage and executable ROS, an 18-bit storage read/write bus (two bytes, each with a parity bit), and a 9-bit data bus in and 9-bit data bus out (one byte plus parity) to the base I/O card. The display adapter reads storage by cycle steal.[1][9]
IBM's 5100 had two kinds of ROS. Executable ROS holds the microprograms the processor runs directly: the bring-up diagnostic, the tape and printer I/O microprograms and the language emulators. The denser non-executable (language) ROS holds the APL and BASIC interpreters and is read through the I/O bus as a device, with GET microinstructions.[1][6] On the 5100 the BASIC ROS is on card C4, the common ROS on E2 and the APL ROS on C2, D2 and D4.[1]
Reading the language ROS on the 5100 works like this:[1]
- A control instruction to device address 1 selects the ROS space.
- Two put instructions load the 16-bit ROS address, high byte first, into the address register on the E2 card. The top six bits decode an address range of 30K bytes.
- Two get instructions return the 16 bits, high byte first.
- The second get also increments the address register, so sequential reads need no new address.
The 5100 manual is not consistent about which bit selects which ROS. Its theory section (p. 4-19) says bus-out bit 4 selects BASIC and common ROS and bit 5 selects APL; its Control Command Data Table (p. C-4) gives command bit 12, which becomes bus-out bit 4, for APL and bit 13 for BASIC and common.[1] On the 5110, bits 4, 5 and 6 select BASIC, APL and common ROS respectively.[2]
On the 5110, read/write storage is laid out as registers (0000-007F), common language control area, display buffer (0200-05FF), system control area (0600-07FF) and user area.[2] Corti's list of fixed locations includes the printer status bytes at 0055 and 0057, the tape status byte at 008F, the highest available storage address at 00A8, the last storage address at 00AA, the address of the routine that enters executable ROS at 00AC and the I/O supervisor at 00AE.[11]
I/O addressing
[edit | edit source]A device address is one of four X lines and one of four Y lines, giving 16 addresses. Some addresses (1, B, C, D and E on the 5100) also take a subdevice address, so that one address can serve up to eight devices.[1] The 5100 and 5110 use different address maps.
| Address | Lines | Device |
| 0 | X0Y0 | Controller (G2) |
| 1 | X0Y1 | Non-executable ROS (BASIC C4, APL C2, D2, D4) |
| 4 | X1Y0 | Keyboard and the APL/BASIC switch |
| 5 | X1Y1 | Printer |
| 8 | X2Y0 | Expansion feature (communications adapter or serial I/O adapter) |
| E | X3Y2 | Tape units |
| F | X3Y3 | All I/O (resets individual devices) |
| 2, 3, 6, 7, 9, A, B, C, D | Not assigned |
| Address | Device |
| 00 | Video display and processor |
| 01 | Common and language ROS |
| 03 | Diskette sort |
| 04 | Keyboard |
| 05 | Printer |
| 06 | BSCA |
| 07 | Parallel I/O |
| 0A | Serial I/O |
| 0C | Print plot |
| 0D | Diskette drive |
| 0E | Tape drive |
| 02, 08, 09, 0B, 0F | Not used |
IOCB byte 1 selects the subdevice: for the diskette, hex 80, 40, 20 and 10 are drives 1 to 4; for tape, 80 is the internal drive and 40 the external one.[2] The 5110's error code summary lists async communications and BSC under device address 8, although the IOCB table gives BSCA as 06, and under APL it reports the tape, serial I/O and diskette as device address 0 with a subdevice code, where BASIC reports their own addresses (E, A and D).[2]
I/O transfers are signalled by strobes: a control strobe marks a command byte on bus out, a put strobe marks a data byte, the device answers with a get strobe, and the op code E line flags non-data transfers such as status.[9]
Physical implementation
[edit | edit source]The card in the photograph, from a 5110, carries 13 square metal-can gate arrays, each marked with a seven-digit IBM part number and "IBM 22", arranged in five rows. Besides these there are two larger white ceramic packages marked 2410086-C (date codes 7825 and 7828), four smaller black DIPs, the CTS Knights 15.0912 MHz oscillator, and resistor packs. The edge of the card is marked 1607136A9458YG41.
| Row | Left | Centre | Right |
| 1 | 2706507 | (oscillator) | 1554466 |
| 2 | 5564251 | (two 2410086-C packages) | 2706506 |
| 3 | 5564251 | 1554469 | 5564255 |
| 4 | 2706504 | 2706503 | 1554468 |
| 5 | 1554470 | 2706505 | 1554467 |
Part 5564251 appears twice, so the 13 arrays are 12 different parts. IBM's manuals do not say which array does what.
The controller card has jumper positions for use in a 5100 or a 5110.[1] It sits in slot G2 on the 5100's A1 board and in slot J2 on the 5110, where J2 on the 5100 is the display card, so take slot numbers from the right machine's manual.[1][2] The 5120's logic manual, which calls the machine the 5110 Model 3, also shows the processor card at A1J2 with a 15.1 MHz oscillator.[12]
| Function | 5100 slot | 5110 slot |
| Processor (controller) | G2 | J2 |
| Display | J2 | G2 |
| Base I/O | F2 | H2 |
| Executable ROS | H2 (BASIC, I/O and diagnostics), H4 (APL) | L2, feature ROS K4 |
| Language ROS | C4 (BASIC), C2, D2, D4 (APL), E2 (ROS adapter and common ROS) | F2 (common and language), E4 (APL) |
| Read/write storage | K2, K4, L2, L4, M2, M4, N2, N4 | M2, M4, N2, N4 |
| I/O cable driver | A2 | A2 |
Sources for the table: 5100 manual pp. 3-81 and 4-19; 5110 manual pp. 3-5 and 3-18.[1][2]
The 5110 power supply provides +5 V, −5 V, +8.5 V, +12 V and −12 V.[2]
Emulated instruction sets
[edit | edit source]The APL and BASIC interpreters are not written in PALM code. Executable ROS holds emulators that run the interpreters from the language ROS.
For APL, IBM's design paper describes adopting the System/370 APLSV interpreter and writing an emulator for it.[6] Corti, who disassembled the 5110's APL executable ROS, describes it as "mainly a System/360 emulator that executes the APL interpreter in 360 code from the non-executable ROS", and notes that it can also run code from read/write storage.[13] For BASIC, Tom Stepleton, who recovered the 5100's executable ROS, describes the interpreter as a modified version of IBM's System/3 BASIC running on an emulated System/3.[14]
Diagnostic features
[edit | edit source]A storage parity error, a bus parity error or an invalid device address raises a machine check, which stops the processor and lights PROCESS CHECK. On the 5110 a machine check jumper from J2-S07 to J2-S09 on the A1 board can be removed so that the processor carries on after such errors; IBM warns that results can then be misleading.[2][9]
The 5100's DISPLAY REGISTERS switch shows the processor register area in hexadecimal on the screen.[6] On the 5110, the Diagnostic Control Program is loaded by holding CMD, pressing HOLD and then the minus key on the numeric pad; it can display (D) and alter (A) any location in read/write storage, and so the registers. From there, ATTN followed by CMD and × enters DCP diagnostic mode. Two CE switches inside the 5110, run and step, reached by removing the top cover, let a service engineer stop and step the processor.[2]
Reading the ROS
[edit | edit source]The processor cannot read executable ROS as data. Stepleton recovered a 5100's executable ROS by starting the machine with the CE run switch set to single-step and DISPLAY REGISTERS on, which leaves the first 512 bytes of executable ROS on the screen, then pulling the seven highest-order address lines to ground through 100 Ω resistors to show each other 512-byte block, and photographing each screen.[14] The resulting images of the 5100's executable and non-executable ROS are on the Internet Archive.[15]
The language ROS can be read by software, because it is an I/O device. Corti publishes a short PALM program, entered through the DCP, that copies the APL ROS into read/write storage (control byte hex 04 selects APL ROS, 08 BASIC and 02 common on the 5110), from where the DCP can write it to diskette.[16]
[edit | edit source]- ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 1.15 1.16 1.17 IBM, IBM 5100 Maintenance Information Manual, SY31-0405-3. Section 3 intermittent process check table p. 3-81; Section 4 "Theory", controller pp. 4-16 to 4-18 and ROS pp. 4-19 to 4-20; Appendix C "Microinstructions", pp. C-1 to C-4 and following; Appendix D glossary. Hosted as File:IBM 5100 Maintenance Information Manual SY31-0405-3.pdf, described at IBM 5100 Maintenance Information Manual.
- ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 IBM, IBM 5110 Maintenance Information Manual, SY31-0550-2. Section 3 "Internal Operation of the 5110": A1 board block diagram p. 3-5, processor and interrupts, ROS and read/write storage pp. 3-18 to 3-19, IOCB p. 3-11, power supply p. 3-41; Section 4 "Diagnostic Aids": DCP p. 4-8, CE switches and jumpers p. 4-64, error codes and device address summary. Hosted as File:IBM 5110 Maintenance Information Manual SY31-0550-2.pdf, described at IBM 5110 Maintenance Information Manual.
- ↑ 3.0 3.1 H. J. Myers, Instructions for the Use of Assembler Generator, General Assembler, General Loader, IBM Internal Use Only, 1 February 1977. Scan in Steve Lewis's IBM_5100_DOCS repository as
PDFs_5100/AssemblerGenerator.pdf. - ↑ 4.0 4.1 4.2 4.3 4.4 4.5 IBM, "2.0 Micro-Instruction Set", chapter 2 of an internal PALM document held by the IBM museum in Sindelfingen, transcribed by Christian Corti: instruction set description, Stuttgart Computer Museum.
- ↑ Smithsonian National Museum of American History, "IBM SCAMP Microcomputer", object nmah_334628, catalogue description.
- ↑ 6.0 6.1 6.2 6.3 6.4 6.5 A. J. Cubbon, "The IBM 5100 Portable Computer Design", APL ITL Symposium, Endicott, New York, January 11-13, 1977, Volume 2 (IBM Internal Use Only), pp. 51-56. Hosted as File:IBM 5100 Portable Computer Design (1977).pdf, described at IBM 5100 Portable Computer Design (1977).
- ↑ 7.0 7.1 7.2 7.3 Christian Corti, "Opcodes", IBM 5110 pages, Stuttgart Computer Museum. Part 1 is Corti's own reverse-engineered list; part 2 reproduces IBM's opcode overview, modifiers and alphabetical mnemonic list.
- ↑ 8.0 8.1 Christian Corti, "Figure 11", Stuttgart Computer Museum: "a copy of a handwritten note. I suspect it to be 'Figure 11'".
- ↑ 9.0 9.1 9.2 9.3 Christian Corti, "The processor", IBM 5110 pages, Stuttgart Computer Museum.
- ↑ Alfred Arnold, Macro Assembler AS change log, entry for 2022-10-23, 1.42 Bld 231: "Add IBM PALM target".
- ↑ Christian Corti, "Useful memory locations", IBM 5110 pages, Stuttgart Computer Museum.
- ↑ IBM, IBM 5120 Computing System Logic Manual, SY34-0193-0. Hosted as File:IBM 5120 Computing System Logic Manual SY34-0193-0.pdf, described at IBM 5120 Computing System Logic Manual.
- ↑ Christian Corti, "Emulator and other files", Stuttgart Computer Museum, with the disassembly
aplros.asm. - ↑ 14.0 14.1 Tom Stepleton, 5100ExecutableROSDecode, GitHub, 2019: notebook
Executable_ROS_decode.ipynb. - ↑ Internet Archive, "IBM 5100 Executable and Non-executable ROS".
- ↑ Christian Corti, "Extracting the non-executable ROS", Stuttgart Computer Museum.
[edit | edit source]- IBM 5100, IBM 5110, IBM 5120
- IBM 5100 Maintenance Guide, IBM 5110 Maintenance Guide, IBM 5120 Maintenance Guide
- IBM 5100 Maintenance Information Manual, IBM 5110 Maintenance Information Manual, IBM 5120 Computing System Logic Manual, IBM 5100 Portable Computer Design (1977)
