Macintosh IIsi Troubleshooting
Revision as of 12:09, 9 February 2026 by Josh (talk | contribs) (Created Macintosh IIsi Troubleshooting guide)
This guide provides solutions to common faults experienced in the Macintosh IIsi. From power issues to video problems and audio failures, these diagnostics will help identify, isolate, and resolve problems.
Preliminary Checks
Before detailed troubleshooting, verify the basics:
  • Check that the power cable is securely connected
  • Test with a known-good power outlet
  • Disconnect all external peripherals (SCSI devices, serial devices)
  • Remove any PDS or NuBus cards
  • Check for visible capacitor leakage or battery corrosion on the logic board
No Power (Unit Dead)
No signs of life (no fan, no LED) Failed power supply, blown fuse, bad power cable Test power outlet; check power supply fuse; test with known-good power supply
Clicking or ticking from power supply Failed capacitors in PSU, shorted component Recap power supply; check for shorts on logic board
Fan spins briefly then stops Power supply overload, shorted logic board Disconnect logic board and test PSU alone; check for capacitor leakage
Power LED on but no startup Dead PRAM battery, failed logic board Replace PRAM battery; check for battery corrosion damage
Power Supply Test
The IIsi uses a 160W Sony power supply. With the logic board disconnected, the PSU should still power on when the soft power switch is actuated. If the PSU fails to start with no load, it likely needs recapping or replacement.
Startup Failures
Startup and Boot Problems
No startup chime, gray screen RAM failure, ROM failure, capacitor damage Reseat RAM SIMMs; check for capacitor leakage; test with minimal RAM config
Startup chime but no video Video circuit failure, bad monitor connection Check video cable; try different monitor; verify video port pins
Sad Mac error code Hardware failure (RAM, ROM, or logic) Decode error code (see below); test RAM; reseat ROM
Flashing question mark No bootable drive found Check SCSI drive; verify SCSI termination; test with boot floppy
Frozen gray screen SCSI bus conflict, bad SCSI device Disconnect all SCSI devices; check termination; verify SCSI ID settings
Sad Mac Error Codes
When a Sad Mac appears, the hexadecimal error code indicates the type of failure. Common codes for the IIsi:
Common Sad Mac Error Codes
Code Range Meaning Resolution
01XXXX ROM test failure Reseat or replace ROM SIMM (if equipped); check for ROM socket corrosion
02XXXX โ€“ 05XXXX RAM test failure Test with different SIMMs; clean SIMM slots; try minimal RAM config
0DXXXX NuBus card failure Remove NuBus adapter and any expansion cards
0EXXXX SCSI chip failure Check for capacitor damage near SCSI controller
0FXXXX Data bus test failure Indicates logic board failure; check for trace damage from capacitor leakage
See Sad Mac Error Codes for a complete reference.
Video Problems
Display and Video Issues
No video but startup chime present Video circuit failure, monitor issue Test with different monitor; check video port pins; verify cable
Distorted or garbled display RAM configuration issue, video RAM problem Ensure all 4 SIMM slots have matching SIMMs; try lower RAM config
Slow video performance Video using slow soldered RAM Set disk cache to 768 KB or larger to force use of faster SIMM RAM
Wrong resolution or colors Monitor sense pin issue Check video adapter; verify monitor compatibility
Video RAM Note
The IIsi shares system RAM for video, using 64 KB to 320 KB depending on resolution. The slow 1 MB of soldered RAM is used first, which impacts video performance. Installing a dedicated video card in the PDS or NuBus slot will significantly improve video speed.
Audio Problems
Sound Issues
No sound from internal speaker Speaker contact failure, speaker wire disconnected Clean speaker daughterboard contacts with pencil eraser; check speaker connections
Sound works through headphones only Speaker contact corrosion Remove logic board; clean spring contacts on speaker daughterboard
Intermittent audio dropouts Speaker contact fretting Clean and reseat speaker contacts; apply contact enhancer
Distorted or crackling audio Failed capacitor near audio circuit Recap logic board; check audio DAC
No sound at all (speaker or headphones) Audio chip failure, capacitor damage Check for capacitor leakage; may require logic board repair
SCSI and Storage Issues
SCSI and Drive Problems
Flashing question mark at startup No bootable system found Test with boot floppy; check SCSI drive; verify System Folder is blessed
SCSI drive not recognized Incorrect SCSI ID, termination issue Verify unique SCSI IDs; ensure proper termination at end of chain
System hangs during SCSI scan SCSI bus conflict, bad device Disconnect all SCSI devices; add back one at a time
Floppy drive not reading disks Dirty heads, failed drive Clean heads with IPA; test with different disks; may need drive replacement
Floppy disks not ejecting Mechanical failure, eject motor issue Check eject mechanism; clean and lubricate; may need gear replacement
SCSI Termination
The IIsi's internal SCSI bus requires proper termination:
  • Internal drive should be terminated if it's the only SCSI device
  • If using external SCSI devices, terminate only the last device in the chain
  • The IIsi logic board does not provide internal termination power by default
Expansion Slot Issues
PDS Card Problems
  • The IIsi PDS runs at 20 MHz; some SE/30 PDS cards designed for 16 MHz may not work
  • Ensure card is fully seated in the slot
  • Check for bent pins in the PDS connector
NuBus Adapter Issues
  • The Apple IIsi NuBus Adapter converts PDS to NuBus
  • Some NuBus cards may not fit due to case height restrictions (7" cards recommended)
  • The adapter includes the 68882 FPU socket
Many IIsi problems stem from leaking electrolytic capacitors:
Capacitor Failure Symptoms
Symptom Likely Cause Solution
Intermittent startup Leaking caps affecting reset circuit Full logic board recap
Corrupted video Leaking caps near video circuit Recap and clean affected area
Random crashes Voltage instability from failed caps Recap logic board and power supply
No startup after long storage Dried-out capacitors Full system recap
See Macintosh IIsi Capacitor Replacement Guide for detailed recapping procedures.
