Macintosh LC III+ Capacitor Replacement Guide
Revision as of 18:03, 9 February 2026 by Josh (talk | contribs) (Added Recap-a-Mac capacitor location images)
Replacing the electrolytic capacitors (recapping) in the Macintosh LC III+ is essential for long-term reliability.
Known Factory Defect: C22
Important: Like the LC III, the Macintosh LC III+ has a known manufacturing defect where capacitor C22 was installed with reversed polarity at the factory. The silkscreen marking on the PCB is printed backwards.
When replacing capacitors, install C22 with correct polarity according to the capacitor's markings, not the PCB silkscreen.
Symptoms of Capacitor Failure
  • No audio — Most common early symptom
  • Distorted or crackling audio
  • Boot failures or instability
  • Visible electrolyte leakage — Brown or black residue around capacitors
  • Corrosion on PCB traces
Capacitor List
Logic Board Capacitors
The LC III+ uses the same capacitor layout as the LC III.
Macintosh LC III+ Logic Board Capacitors
Designator Capacitance Voltage Notes
C1 1 µF 50V
C2 1 µF 50V
C3 10 µF 16V
C4 10 µF 16V
C5 10 µF 16V
C6 10 µF 16V
C7 47 µF 16V
C8 47 µF 16V
C9 47 µF 16V
C10 47 µF 16V
C11 47 µF 16V
C12 47 µF 16V
C13 47 µF 16V
C14 47 µF 16V
C15 100 µF 6.3V
C16 100 µF 6.3V
C17 100 µF 6.3V
C22 47 µF 16V Factory reversed polarity — install correctly!
Macintosh LC III/III+ logic board capacitor locations. Note C22 silkscreen error. Source: Recap-a-Mac
Power Supply Capacitors
Refer to the Macintosh LC Power Supply Recap Guide for PSU-specific information.
Macintosh LC power supply capacitor locations. Source: Recap-a-Mac
Tools Required
  • Temperature-controlled soldering iron (recommended: 300-350°C)
  • Fine tip for SMD work
  • Desoldering braid or solder wick
  • Flux (no-clean recommended)
  • Isopropyl alcohol (99%)
  • Soft brush (ESD-safe)
  • Multimeter
  • Replacement SMD electrolytic capacitors
Procedure
  1. Remove the logic board — Disconnect all cables, remove screws, and carefully lift the board.
  2. Document capacitor positions — Note polarity markings before removal.
  3. Clean the area — Remove any leaked electrolyte with isopropyl alcohol.
  4. Remove old capacitors — Heat one pad while gently lifting the capacitor. Alternate between pads.
  5. Clean the pads — Remove old solder with desoldering braid. Clean with IPA.
  6. Inspect for damage — Check traces and vias for corrosion.
  7. Install new capacitors — Observe polarity. For C22: ignore the PCB silkscreen.
  8. Clean residue — Remove flux with isopropyl alcohol.
  9. Test continuity — Verify no shorts between +5V, +12V, and ground.
  10. Reassemble and test
Important Notes
  • C22 silkscreen error — The PCB marking is wrong. Install based on the capacitor's polarity marking.
  • Polarity matters — SMD electrolytics will fail if installed backwards.
  • Use equivalent or better specs — Match capacitance; voltage rating can be equal or higher.
External Resources
