Macintosh Classic Capacitor Replacement Guide
Revision as of 09:04, 12 May 2025 by Josh (talk | contribs)
Replacing electrolytic capacitors (recapping) in your Macintosh Classic is essential for restoring power stability, ensuring clean video output, and preventing long-term damage due to capacitor leakage. This guide outlines the recommended procedure and provides complete analog and logic board capacitor specifications.
Capacitor Inspection
  • Bulging Tops – Swollen or domed caps indicate internal gas buildup.
  • Electrolyte Leakage – Brown/white crust or residue near leads shows capacitor failure.
  • Corroded Pads or Traces – PCB staining or corrosion suggests leakage damage.
Macintosh Classic Capacitor List
Analog Board Capacitors
The Macintosh Classic analog board has several capacitors that may require replacement. Due to variations in board revisions, consult the specific schematic for your model. Common capacitor values include:
Macintosh Classic Analog Board Capacitor Specifications
CF3 1000µF 16V 1x
CF4 470µF 25V 1x
CL1 1000µF 25V 1x
CL2 4.7µF 250V 1x
CL3 1µF 50V 1x
CP1 220µF 250V 1x
CP10 470µF 25V 1x
CP11 220µF 50V 1x
CP12 1000µF 16V 1x
CP13 220µF 250V 1x
CP2 470µF 50V 1x
CP34 1µF 50V 1x
CP36 2200µF 10V 1x
CP4 47µF 25V 1x
CP5 1µF 50V 1x
CP6 2200µF 10V 1x
CP7 1000µF 10V 1x
CP8 2200µF 16V 1x
CP9 470µF 25V 1x
CV2 470µF 10V 1x
CP3 10µF 25V 1x
CP37 1µF 50V 1x
CL11 47µF 16V 1x
CF2 220µF 16V 1x
CF1 47µF 25V 1x
  • Note: Capacitor labels and values may vary between board revisions. Always verify with your specific board.*
Macintosh Classic Analog Board (INT) Recap Diagram [1]
Logic Board Capacitors
The Macintosh Classic logic board contains surface-mount electrolytic capacitors prone to leakage and corrosion.
Macintosh Classic Logic Board Capacitor Specifications
C1 – C7 47µF 16V 7x
C8 1µF 50V 1x
Note: When replacing with tantalum capacitors, consider using 25V rated caps for the 47µF positions to ensure longevity.
Macintosh Classic Recap Diagram [2]
  1. Discharge the CRT – Follow standard CRT discharge procedures before working inside.
  2. Remove the Logic & Analog Boards – Label cables and safely extract both boards.
  3. Desolder Old Capacitors – Use a quality soldering iron, braid, or pump to remove components cleanly.
  4. Clean the Board – Thoroughly clean any electrolyte residue with isopropyl alcohol.
  5. Install New Capacitors – Insert with correct polarity (check for stripe on negative side).
  6. Solder Carefully – Ensure clean, shiny joints without cold solder bridges.
  7. Trim Leads & Inspect Work – Cut excess and examine under light or magnification.
  8. Test for Shorts – Use a multimeter to confirm there are no shorts across power rails.
  • Temperature-controlled soldering iron (fine tip)
  • Desoldering braid or vacuum pump
  • Quality leaded solder (0.5 mm recommended)
  • Isopropyl alcohol and ESD brush
  • Multimeter
  • Safety goggles and insulated gloves
Voltage Adjustment After Recap
  • +5V rail: 4.90V – 5.15V
  • +12V rail: 11.9V – 12.7V
Use the analog board's trimmer potentiometer (R56) to fine-tune if necessary.
Tips for Best Results
  • Always recap the logic board first – leaking caps often cause corrosion damage.
  • Use quality capacitors (e.g., Nichicon, Panasonic, Rubycon).
  • Turn on the system periodically to prolong capacitor lifespan.
  • Replace in full sets for even aging and reliability.
  • Clean the board thoroughly with isopropyl alcohol after removal.
