IBM PS/ValuePoint Maintenance Guide
This guide documents preventive maintenance for the IBM PS/ValuePoint family — IBM's corporate / SMB ISA-based PC line from October 1992 to July 1995, machine types 6381 / 6382 / 6384 / 6387. Procedures are common to the family where possible; per-submodel procedures are called out where they differ.
Safety Warning
All PS/ValuePoint PSUs contain mains-rectified bulk capacitors that hold a lethal charge after power-off. Before any work inside the PSU shell:
- Power off and unplug the mains lead.
- Wait at least 30 seconds.
- Discharge the bulk capacitor through a 1 kΩ / 5 W resistor.
- Verify with a multimeter.
The PSU is universal-voltage on most submodels but uses a manual selector switch on the rear (115 V / 230 V). Verify the switch position before connecting mains — IBM ships boards with the selector at 230 V from the factory, and powering a US 120 V mains into a board set to 230 V will not damage anything but the system will not power on; powering 240 V mains into a board set to 115 V will destroy the PSU.[1]
Identifying Your PS/ValuePoint
The machine type and submodel are printed on the rear-panel label (e.g. "Type 6381-Fxx", "Type 6384-1A3", "Type 6387-Yxx"). The MT maps to a Hardware Maintenance Manual (HMM):
Opening the System Unit
Tools: Philips #2 screwdriver, anti-static strap.
- Power off and unplug all cables (mains, keyboard, mouse, monitor, parallel, serial).
- Locate the cover screws on the rear panel.
- Loosen the screws. The cover slides off to the rear and lifts up.
- Inside:
- Planar mounts horizontally on the chassis floor (desktop) or vertically (tower).
- PSU is at the rear left.
- Drive cage runs along the right side of the chassis (desktop) or top (tower).
- ISA / VLB / PCI slots are on a riser card that plugs into the planar at right angles to the planar.
Cover Lock
Some PS/ValuePoints ship with a cover lock that requires a small key to open. Several systems were shipped from the factory without cover lock keys; if a system arrives with the lock present but no key, order a replacement cover lock assembly from IBM (or a modern locksmith can drill it out).[1]
Cover Switch / Interlock
Some PS/ValuePoint chassis carry a cover-interlock switch — the system will not power on or power off if the cover is not seated properly.[1] If the system refuses to power on with the cover off, depress the cover-interlock pin manually with a screwdriver for a smoke-test.
Inspecting the Planar
Planar inspection items (in order):
- Lithium battery at B1 / BT1 — verify the CR2032 cell is seated and shows no leakage. Replace if voltage is below 2.8 V.
- Floppy drive logic board — the Alps floppy drive used in many 6381-Fxx and similar boards has an SMD aluminium electrolytic capacitor next to the power connector that can leak.[5] This is the most common cap failure on PS/ValuePoint — see IBM PS/ValuePoint Capacitor Replacement Guide.
- Planar electrolytics — mostly through-hole; rarely fail; inspect for discolouration anyway.
- VLB / PCI slot connectors — clean with eraser or contact cleaner. VLB slots have a high pin count and oxidise.
- Video Frequency Controller chip — located just left of the Tseng video chip. May be either ICS or Chrontel branded depending on production date. The OS/2 2.00.1 SVGA driver fails on Chrontel boards — install the revised driver if you see this combination.[1]
Regular Cleaning
- Soft brush and low-pressure compressed air for the planar, riser, ISA/VLB/PCI cards, drive bays and PSU vents.
- Hold any fan blades by hand if using compressed air.
- CPU heatsink (passive on 486SX-25 boards, fan-cooled on DX2/DX4 boards) — clean fins; on DX4 or P60/D, replace original thermal compound at first service.
- Clean ISA / VLB card edge fingers with a soft eraser or deoxidising contact cleaner.
- Clean Mini-DIN-6 keyboard / mouse connectors with deoxidising contact cleaner on a foam swab.
PSU Voltage Checks
Probe the PSU output rails with a multimeter while the system is powered on (AT-style, not ATX).
| Rail | Acceptable range |
| +5 V | +4.75 V to +5.25 V |
| +12 V | +11.4 V to +12.6 V |
| −5 V | −4.50 to −5.50 V (±10 %) |
| −12 V | −10.80 to −13.20 V (±10 %) |
The two negative rails were previously given at ±5 %. Both the AT and the ATX specifications allow ±10 % on them, so a −12 V rail at −11.0 V is in specification and was being called a fault.[6] IBM publishes no per-rail tolerances of its own for these machines.
- 6381-Si (100 W) — sufficient for entry config; +12 V will sag if multiple drives added.
- 325T / original 6384 (145 W) — design limit 10 W per slot.
- 6382 /S, 6384 /D, P60/D, 6387 /T (200 W) — universal voltage 90–137 V LV / 180–265 V HV.
Voltage Selector
The rear-panel voltage selector switch must be set correctly for your mains:
- 115 V for 100–127 V mains (US, Canada, Japan, etc.).
- 230 V for 200–240 V mains (UK, Europe, Australia, etc.).
IBM ships boards with the selector at 230 V from the factory. If you receive a North American unit and it does not power on, check this switch first.
Battery — CR2032 Lithium Coin Cell
The PS/ValuePoint planar battery is a standard CR2032 lithium coin cell, not a soldered NiCd. Replacement procedure:
- Power off, unplug, discharge PSU.
- Locate the CR2032 in its snap-clip on the planar (typically labelled B1 or BT1).
- Pry the cell out with a fingernail or plastic spudger. Do not use a metal screwdriver — shorting + and − while levering can damage the planar power circuitry.
- Fit a fresh CR2032 with the + face up (matching the silkscreen).
- Power on; press F1 during memory count to enter Setup; re-enter date, time, boot order, drive parameters.
Symptoms of a dead battery (PS/ValuePoint inherits the classic IBM 161 / 162 / 163 POST cluster from the AT / PS/2 era):
- 161 — Battery dead / disconnected.
- 162 — CMOS checksum bad (configuration mismatch).
- 163 — Time and date not set.
After cell replacement, the F1 during memory count shortcut enters Setup. There is no Reference Diskette for PS/ValuePoint — Setup is in ROM.[1]
External Battery Header
The planar carries a J2 "External Battery" header and a JP8 "Battery Select" jumper.[7] For long-term storage, fit a remote CR2032 holder on flying leads to J2 and move JP8 to "External" — this lets you remove the planar's onboard cell without losing CMOS configuration during storage.
Memory
Memory varies dramatically by submodel:
- 325T (386SLC) — 72-pin parity SIMM, 70–85 ns; 2 MB soldered + 2 sockets; 16 MB system max.
- Original 1992 6384 (425SX, 433DX, 466DX2) — 30-pin parity SIMM (the only PS/ValuePoint family with 30-pin), 70–80 ns, installed in banks of 4, max 32 MB.
- All other 6381 /Si, 6382 /S, 6384 /D, 6387 /T — 72-pin parity SIMM, 70 ns (up to 85 ns), 4 sockets, max 64 MB.
- 6384 P60/D — 72-pin parity SIMM, 70 ns, installed in pairs for dual-channel, max 128 MB.
All PS/ValuePoint memory is parity. Do not fit non-parity SIMMs — the POST will halt at a 2xx memory error.
Storage Maintenance
- IDE drives — clean drive connector. Original IBM drives (80 / 120 / 170 / 212 / 245 / 340 / 420 / 527 MB) are aged 25+ years and are unreliable; replace with CompactFlash-to-IDE or XT-IDE / IDE2SD adapter for long-term use.
- Floppy drives — Alps drives have the SMD electrolytic on the drive logic board that can leak. See IBM PS/ValuePoint Capacitor Replacement Guide. Replace head-cleaning belt if drive is intermittent.
- Optional SCSI — Future Domain 8-bit (TMC-850IBM) or 16-bit AT Fast SCSI adapter. Driver disks for DOS / OS/2 / Windows.
2.88 MB Floppy Support
- 486 boards — do not support 2.88 MB drives.
- P60/D — does support 2.88 MB drives.
Connector Care
- Keyboard — 5-pin AT DIN on most submodels (PS/2 Mini-DIN-6 on later /D boards).
- Mouse — PS/2 Mini-DIN-6 on planar.
- Serial — DB-9 male × 2 on most boards.
- Parallel — DB-25 female on planar.
- Video — 15-pin DSUB VGA on planar (Cirrus / Tseng / S3 / ATI Mach32 chip-dependent).
- Cover lock — IBM-keyed cylinder, OEM by Chicago Lock Company.
BIOS Update Procedure
All Type-2 boards (6382, 6384 VP2, 6387) share flash BIOS image L6JT70A.EXE (version 70).[8]
- Download the BIOS image from IBM's archive (or from a mirror such as the kev009 collection).
- Write to a write-protected DOS floppy. Critical: do not run the update from a Windows 95 / 98 / NT command prompt with the floppy unprotected — the diskette can be corrupted by the OS.
- Boot from the DOS floppy.
- Run the BIOS update; do not power off until done.
- After update, re-enter Setup (F1 during memory count) and re-confirm boot order.
Per-MT BIOS images:
- 6381 /Si — L8JT52A.EXE.
- 6382 /S, 6384 /D, 6387 /T — L6JT70A.EXE (v70).
- 6384 P60/D — VPP60FL6.EXE.
BIOS v68 or later is required to enable P24T-83 Pentium OverDrive on 486 boards.[9]
Cache Configuration
L2 cache is field-upgradeable on most PS/ValuePoint 486 boards:
- 6381 SX / DX — supports 128 KB or 256 KB L2 cache module.
- 6382 /S, 6384 /D, 6387 /T — 128 KB or 256 KB L2.
- Type 1 boards — write-through L2.
- Type 2 boards — write-back L2.
- 466DX2 — 256 KB L2 standard.
If the L2 cache module is missing and a 12902 / 12904 POST code appears, fit an IBM cache module of the correct type.
Recommended Tools
- Philips #2 screwdriver.
- Anti-static strap.
- Digital multimeter (DC and AC modes).
- IPA + foam swabs.
- Soldering iron with fine tip + solder wick (for floppy drive logic board recap).
- Hot-air rework station (optional, useful for the floppy drive SMD cap).
- Spare CR2032 cells.
- DOS bootable floppy (or IDE-to-CF adapter with bootable DOS image).
- DOS-formatted floppy + BIOS image for your specific MT.
- IBM HMM PDF for your machine type.
Related Pages
- IBM PS/ValuePoint
- IBM PS/ValuePoint Troubleshooting Guide
- IBM PS/ValuePoint Capacitor Replacement Guide
- IBM PS/ValuePoint Video Mod Guide
- Recommended Tools
- ↑ 1.0 1.1 1.2 1.3 1.4 kev009.com — IBM PS/2 and PC document mirror — e1f6
- ↑ kev009.com — IBM PS/2 and PC document mirror — s61g1423
- ↑ kev009.com — IBM PS/2 and PC document mirror — S61G 1423 02
- ↑ kev009.com — IBM PS/2 and PC document mirror — S71G 1875 00
- ↑ zx.net.nz restoration notes — psvaluepoint 425sxsi
- ↑ Intel, ATX / ATX12V Power Supply Design Guide, the specification these supplies are built to. It sets ±5 per cent on +3.3 V, +5 V, +12 V and +5 VSB, and ±10 per cent on −5 V and −12 V. The figures in this table are the specification's, not IBM's: IBM does not publish per-rail tolerances for these machines, and the supplies are bought-in industry-standard units.
- ↑ kev009.com — IBM PS/2 and PC document mirror — a26e
- ↑ kev009.com — IBM PS/2 and PC document mirror — ceda
- ↑ kev009.com — IBM PS/2 and PC document mirror — 859e
Further reading
- IBM Hardware Maintenance Manual S61G-1423-01 (Sep 1993). Authoritative HMM for the 638x family.
- IBM HMM S61G-1423-02 (Aug 1996). Updated HMM including 64xx transitional models.
- IBM 6387/T Supplement S71G-1875-00 (May 1993). Tower-specific supplement.
- IBM PS/ValuePoint Tips & Tricks, kev009 mirror. Battery (lithium) confirmation, F1 enters Setup, voltage selector, cover lock, ICS/Chrontel video chip note.
- IBM PS/ValuePoint system board layouts. B1/BT1 battery position, J2 external battery, JP8 battery select.
- IBM PS/ValuePoint 6382/S, 6384/D, 6387/T system info. 200 W PSU, OverDrive jumpers, Type 1 vs Type 2, IBMKBFIX.
- IBM PS/ValuePoint flash BIOS update procedure. L6JT70A.EXE for Type-2 boards, write-protect floppy under Windows.
- zx.net.nz — IBM PS/ValuePoint 425SX/Si hands-on documentation. CR2032 leakage report, Alps floppy SMD cap note.
