Macintosh Plus Capacitor Replacement Guide
Replacing electrolytic capacitors (recapping) in your Macintosh Plus is essential for long-term reliability, stable voltages, and a crisp video image. Over time, capacitors degrade, leading to voltage instability, display artifacts, and system failure. Proactively replacing these components ensures the continued functionality of your system.
Capacitor Inspection
Before replacing capacitors, it is essential to inspect them for signs of deterioration. The most common signs of failing capacitors include:
- **Bulging Tops** – Capacitors should have a flat top. If swollen or domed, they are failing.
- **Leaking Electrolyte** – A brownish or white crust around capacitor leads indicates electrolyte leakage.
- **Corrosion** – PCB discoloration or corrosion around capacitor bases suggests imminent failure.
Macintosh Plus Capacitor List
The **Macintosh Plus analog board** contains numerous capacitors that should be replaced proactively. Below is a detailed table of capacitor specifications:
| Label | Stock Capacitance | Stock Voltage | Quantity |
| C1 | 3.9µF | 35V | 1x |
| C2 | 4700µF | 16V | 1x |
| C3 | 220µF | 16V | 2x |
| C5 | 47µF | 10V | 1x |
| C6 | 22µF | 50V | 2x |
| C10 | 33µF | 16V | 2x |
| C11 | 10µF | 160V | 1x |
| C12 | 22µF | 50V | 2x |
| C18 | 33µF | 16V | 2x |
| C24 | 2200µF | 16V | 4x |
| C27 | 2200µF | 16V | 1x |
| C28 | 1000µF | 16V | 1x |
| C30 | 2200µF | 16V | 1x |
| C31 | 220µF | 16V | 1x |
| C32 | 2200µF | 16V | 1x |
| C33 | 4700pF | 250V | 2x |
| C34 | 100µF | 200V | 4x |
| C35 | 100µF | 200V | 1x |
| C36 | 4700pF | 250V | 1x |
| C37 | 0.47µF | 250V | 1x |
| C38 | 100µF | 200V | 1x |
| C39 | 100µF | 200V | 1x |
| C42 | 470µF | 10V | 2x |
| C45 | 470µF | 10V | 1x |
Proper capacitor replacement requires careful handling and the right tools. Follow these steps:
- **CRT Safety** – Fully discharge the CRT before servicing to avoid dangerous high-voltage shocks.
- **Disassembly** – Remove the analog board, noting connector placements.
- **Desoldering** – Use a solder sucker or desoldering braid to remove old capacitors without damaging PCB traces.
- **Replacement** – Install new capacitors with correct polarity (**observe the + and - markings**).
- **Soldering** – Solder new capacitors securely and trim excess lead length.
- **Inspection** – Ensure all solder joints are **clean and well-adhered**.
- **Final Check** – Use a multimeter to verify **no shorts between power rails** before powering on.
Recommended Tools
To perform a successful capacitor replacement, the following tools are recommended:
- **Soldering iron** (temperature-controlled, fine tip)
- **Desoldering pump or braid**
- **Multimeter** (for voltage verification)
- **Anti-static brush, isopropyl alcohol** (for PCB cleaning)
- **Safety glasses and insulated gloves**
Voltage Adjustment Post-Recap
After recapping, voltages should be **verified and adjusted** to ensure stability. Measure using a multimeter at the floppy drive connector or logic board harness.
- **+5V Line**: Should be **4.85V – 5.15V**
- **+12V Line**: Should be **11.9V – 12.7V**
If voltages are **out of range**, adjust using the **trimmer potentiometer (R56)** on the analog board.
Additional Tips
- **Turn on the Macintosh Plus periodically** to prevent capacitors from drying out.
- **Replace capacitors in batches** to ensure even aging if full recapping is not possible.
- **Dispose of old capacitors properly** at an electronics recycling center.
For further maintenance and troubleshooting, refer to the **Macintosh Plus Troubleshooting Guide**.
