Amstrad CPC 664
Revision as of 20:20, 23 September 2026 by Josh (talk | contribs) (Major corrections against Amstrad's own service manual: the board is Z70205 MC0005A/B, not Z70200 (a 464 board); the OS ROM is part 40022 at IC103, not 40012 (which is IC211, a 74LS27); the Gate Array is the 40010, not 40007/40226; the drive is a Matsushita EME-150A on PCB 30001, not a Hitachi HD3.5R-1; Amstrad's own disc capacities are SYSTEM 169 KB, DATA 178 KB, IBM 154 KB; the display is not interlaced and there is no 400-line mode; DC jack is J301 and the 5-pin DIN J302 is the cassette so...)
Amstrad CPC 664
Amstrad CPC 664 with the CTM644 colour monitor
DeveloperAmstrad
ManufacturerAmstrad Consumer Electronics plc
TypeHome computer
Released1985
DiscontinuedAugust 1985
CPUZilog Z80A @ 4 MHz
Memory64 KB RAM (over 41 KB available to the user)
StorageBuilt-in 3-inch single-sided disc drive, Matsushita EME-150A
Display160×200×16, 320×200×4 or 640×200×2 from a 27-colour palette
SoundGeneral Instrument AY-3-8912, three voices
ROM32 KB OS and Locomotive BASIC 1.1, plus a 16 KB AMSDOS ROM
Power5 V DC and a separate 12 V disc feed, both from the monitor
OS / FirmwareAmstrad firmware, Locomotive BASIC 1.1, AMSDOS, CP/M 2.2
PredecessorAmstrad CPC 464
Model no.CPC 664
The Amstrad CPC 664 (sold as the Schneider CPC 664 in West Germany, Austria and Switzerland) is the second machine in the CPC line. It replaced the CPC 464's cassette deck with a built-in 3-inch disc drive, moved the disc controller onto the main board instead of the external DDI-1, and shipped Locomotive BASIC 1.1 with AMSDOS in a separate 16 KB ROM.
It was on sale from May to August 1985 before the CPC 6128 replaced it, which is why it is scarcer than either the 464 or the 6128 and why the community knowledge base around it is thinner.[1] No production figure has ever been published, so none is given here.
The part numbers, designators and specification figures on this page are Amstrad's own, from the service manual hosted on this wiki.[2][3]
The monitor is the power supply
Like the 464, the CPC 664 has no mains connection and no internal power supply — but it needs two DC feeds, not one. Amstrad's specification lists a socket for the 5 V supply from the monitor, and a plug and lead that goes out to the 12 V disc power socket on the monitor.[2] The CTM644 colour monitor and the GT65 green monitor provide both.
In the parts list these are J301 (DC jack, Amstrad part 170024 — the same part as the 464's J104) and CD301 (DC cord, part 170822).[2]
There is no five-pin DIN power connector on this machine. The 5-pin DIN on the back is J302 (part 170819), the external cassette recorder socket; the 3.5 mm socket is J103, stereo audio out.[2]
A drive that will not spin is very often a 12 V problem, not a drive problem. That rail comes down a separate lead from the monitor and that lead is a single point of failure. Check it before opening the drive.
Board
The CPC 664 main board is Z70205, 475 × 155 mm, in two variants:[3]
CPC 664 main PCB variants
Silkscreen Notes
Z70205 MC0005A 8-pin FDC data separator
Z70205 MC0005B German Schneider boards. Usually carries a patch resistor R160 between pin 9 (A0) and pin 14 (/CASADDR) of IC105, which is not labelled on the PCB — do not mistake it for a previous owner's bodge
Z70200 is a CPC 464 board, not a 664 board.[3] If your board is marked Z70200, you are looking at a 464.
Devices
Amstrad's own parts list:[2]
CPC 664 — principal devices
Ref Device Amstrad part no. Role
IC103 TMM-23256P-1952 40022 32 KB OS + Locomotive BASIC 1.1 ROM
IC204 TMM-23128P-1951 40015 16 KB AMSDOS ROM
IC111 Z8400APS 40080 Z80A CPU
IC116 HSG3130 / HSG3170 40010 Gate Array
IC108 HD6845SP 170106 CRTC
IC107 M5L8255AP-5 170105 Parallel I/O
IC102 AY-3-8912 40001 Sound generator
IC117–IC124 HM4864U-2 170110 64 KB DRAM, eight 64K × 1 devices
IC201 µPD765AC 40018 Floppy disc controller
IC202 FDC9216BT 40020 Data separator
IC301 LA4140 170111 Audio power amplifier
IC302 LA63585 170814 Cassette read chain
Two corrections worth stating plainly, because both have circulated widely:
  • The OS ROM is part 40022 at IC103. 40012 is IC211, a 74LS27 — a different device entirely.[2]
  • The Gate Array is the 40010 at IC116. The heatsinked 40007 is the CPC 464's part, and the 40226 is the ASIC on the 464's late cost-down board. Neither belongs in a 664.[2][3]
The 664 keeps the whole cassette interface even though it has no cassette deck. IC301, IC302, the tape motor relay RY301, the speaker, the volume control and the entire 300-series population are present, feeding J302 for an external recorder.[2]
The disc drive
Amstrad's specification describes it as "a 3" system, conforming to the Hitachi/Panasonic standard", configured in software for a 12 ms step rate and 30 ms settling time.[2] The mechanism actually fitted is the Matsushita EME-150A on PCB 30001 — the PCB number Amstrad's own manual refers to throughout.[2][4] Later machines in the family used the EME-155, EME-156 and EME-156V.
A 3-inch disc is physically double-sided, with a write-protect clip on each side, but the drive reads only the side facing it — you flip the disc by hand.[2]
Disc formats
Amstrad's own figures. All are single-sided, double density, 512-byte sectors, 40 tracks, 2:1 interleave:[2]
AMSDOS disc formats
Format Sectors per track Reserved tracks Capacity
SYSTEM 9 2 169 KB
DATA 9 none 178 KB
IBM 8 1 154 KB
The drive belt
The perished belt is the characteristic 664 fault. The motor runs, the disc does not, and the machine reports a read failure on a known-good disc.
Amstrad publishes no belt dimensions. The community specification for the CPC 664 / 6128 / FD-1 3-inch drive belt is 3 mm wide, 0.6 mm thick, 230 mm outer circumference — often advertised as "115 mm", which is the flat length.[5] Measure your own pulleys before ordering.
The spindle speed is adjustable at VR201 on the drive's own control PCB, to an index period of 200 ms — one revolution at 300 rpm.[2] Full procedure on Amstrad CPC 664 Maintenance Guide.
Amstrad's position on the mechanism
Printed twice in the manual, in a box: "Service Agents must not carry out any repair or adjustment to the Drive mechanism and its associated PCB 30001 during warranty. Faulty mechanism must be returned to AMSTRAD for exchange."[2] That was a 1985 warranty policy, not a statement that the drive is unserviceable — but it does mean the manual gives no component values for the drive PCB, and the parts list carries a matching note to that effect. The mechanical breakdown, the alignment checks and the replacement procedures are all there and all still usable.
Display
The same video subsystem as the 464: three modes, all 200 lines, from a 27-colour palette.
Video modes
Mode Resolution Colours Text
0 160 × 200 16 20 columns
1 320 × 200 4 40 columns
2 640 × 200 2 80 columns
The CPC display is not interlaced and there is no 400-line mode. Both claims appeared on earlier versions of this page and neither is correct.
Amstrad's published specification
CPC 664 — from Amstrad's specification page[2]
Item Figure
Processor Z80A at 4 MHz
RAM / ROM 64 KB RAM (over 41 KB available to the user) / 32 KB ROM for BASIC and OS
Video / sound / I/O 6845 CRT controller · AY-3-8912, 3 voice, 8 octave · 8255 parallel I/O
Keyboard 74 keys
Disc drive 3 inch, 12 ms step rate, 30 ms settling time, maximum 2 drives
Expansion Up to 252 additional 16 KB ROMs
Keyboard unit 580 × 70 × 170 mm, 2.4 kg
CTM644 monitor 375 × 340 × 365 mm, 10.6 kg
GT65 monitor 305 × 315 × 335 mm, 6.3 kg
Mains 240 V AC 50 Hz — at the monitor. Both the keyboard unit and the disc drive are powered from the screen system
Servicing
The keyboard, the audio chain and most of the main board are shared with the 464, so the Amstrad CPC 464 Maintenance Guide procedures apply to everything outside the disc subsystem.
  1. ↑ "CPC664", CPCWiki, citing Amstrad Action issue 1 (October 1985) page 8 for the May–August 1985 production window. CPCWiki gives no production figure for the 664, and none was found elsewhere. Secondary source.
  2. ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 2.10 2.11 2.12 2.13 2.14 Amstrad Consumer Electronics plc, CPC664 Micro Computer / CTM644 Colour Monitor / GT65 Green Monitor Service Manual. Hosted at Amstrad CPC 664 Service Manual. Source for the CPC664 Basic Hardware Analysis, the Diagnostic Flow Chart, the Alignment Checks including test points and the EME-CF2 test disk, the Electrical Parts List, the Mechanism drawing and Mechanical Replacements procedures, and the Technical Specification.
  3. ↑ 3.0 3.1 3.2 3.3 "Mainboard Versions", CPCWiki. Community catalogue of silkscreen markings, board dimensions and per-version differences across the CPC range. Gives the CPC664 board as Z70205 / MC0005A and MC0005B and notes the MC0005B's unlabelled patch resistor R160. Secondary source, compiled from observed boards.
  4. ↑ "Amstrad FDD part", CPCWiki — catalogue of the Matsushita EME-series 3-inch mechanisms Amstrad fitted: EME-150A (PCB 30001, CPC664, early DDI-1 and early 6128), EME-155 (PCB 30002), EME-156 (PCB Z70312), EME-156V (PCB Z80264) and the 5 V-only EME-157 (PCB Z80425). All single-sided, 40 track, 180 KB per side, 300 rpm. Secondary source.
  5. ↑ "Changing the drive belt", CPCWiki — gives the replacement belt as 3 mm wide, 0.6 mm thick and 230 mm outer circumference (commonly advertised as 115 mm), with the removal procedure. Secondary source; Amstrad published no belt dimensions.
