PLA Replacement Options
The original MOS 906114-01 Programmable Logic Array (PLA) in early C64 board revisions (ASSY 326298 → 250466) is _the_ single highest-failure-rate part in the machine. It runs hot (≈ 65 °C surface on an un-ventilated bread-bin), consumes ≈ 120 mA, and any internal electrical overstress manifests as:
- Black screen / no border on power-up.
- Colour-flashing “garbage” that crashes after warm-up.
- Selective cartridge or bank-switch errors (EXROM/GAME decoding faults).
Because original spare parts are scarce and almost forty years old, several replacement families have appeared. They differ in technology, power draw, compatibility and cost.
🔍 Selection criteria
| Criterion | Why it matters |
| Timing accuracy | PLA outputs must meet a < 60 ns access window to avoid VIC-II bus contention; marginal parts work in BASIC but fail with fast cartridges. |
| Voltage tolerance & heat | Lower idle current (≤ 20 mA) keeps internal case temperature down and avoids over-loading the 5 V rail. PLAnkton, for example, dissipates < 0.2 W compared with ≈ 0.6 W for the ceramic MOS part. |
| Board compatibility | 250469 “short-board” machines integrate the PLA inside the 251715-01 gate-array; external plug-ins are not required there. |
| Cartridge support | Fast loaders (Epyx FastLoad, KFF, EasyFlash) depend on tight /CASRAM and /ROML asserts — earlier EPROM-based substitutes can break these. |
🗂️ Replacement families
1. Salvaged original MOS ceramic PLAs
- Perfect electrical fit if tested good, but still run hot and may fail again.
- Short supply & rising price (US $40–80 on auction sites).
2. EPROM + TTL glue (first-generation DIY)
- EPROM (27C512/27C256) programmed with PLA truth-table, gated by 74LS04/74LS86.
- Cheap but slow output edges and ~65 mA current → will over-heat inside a closed case.
- Timing marginal with some Ocean/AR II cartridges.
3. GAL / PAL-based (PLA20V8, ThED PLA20V8, “128 PLA in C64”)
- Single GAL20V8 or ATF22V10C, pin-compatible.
- Draw ≈ 20 mA, emit little heat.
- Open-source JEDEC; hobbyists can burn their own chips.
- Slightly higher propagation delay than CPLD, but passes timing on > 99 % of boards in field reports.
4. CPLD / FPGA-based (current gold standard)
| Replacement | Logic core | Idle current | Notable points |
| SuperPLA V3 | Xilinx XC9536XL | ≈ 15 mA | Earliest “plug-and-play” commercial part, wide PAL/NTSC & cartridge compatibility. 20 € PCB kit. |
| U17 PLAnkton | Altera MAX CPLD | < 10 mA | Eight-layer µPCB nestled inside a plastic SIL socket; runs cool & supports C16/+4 PLAs via jumper. |
| RealPLA / “Ultimate PLA” | Lattice ispMACH 4064 | 12 mA | Shipped with _Ultimate-64_ boards; cartridge timing verified with Kung-Fu Flash & Epyx. |
| SaRuMan-64 | iCE40LP384 FPGA | ~ 8 mA | Adds a tiny linear-drop regulator to isolate noisy 5 V rails; user-upgradable bit-stream. |
5. Multi-chip TTL recreations (educational)
- 27 × 74LS/AHC gates that implement the PLA equations.
- Excellent edge-rate but enormous current draw; avoided except as teaching tools.
🛠️ Installation
- Power off & unplug PSU; discharge by pressing the power switch several times.
- Gently remove the original PLA from socket U17 using a PLCC puller or flat tool.
- Visually inspect the socket for oxidation or lifted pads.
- Align the notch or pin-1 indicator on the replacement with the board silk.
- Firmly press straight down — do not rock side-to-side.
- Power on and test:
- BASIC screen appears → `PRINT FRE(0)` returns 38911.
- Run a fast-loader cartridge or *Dead Test* to exercise all decode paths.
⚖️ Comparison summary
| Solution | Cost | Heat | Cartridge compat. | Availability | ||||||||||||||||||||
| Salvaged MOS | High | 🔥🔥🔥 | ✅ | declining | EPROM TTL | Low | 🔥🔥 | ⚠️ mixed | DIY only | GAL20V8 | Low-mid | 🔥 | ✅ | open-source | CPLD/FPGA (e.g. PLAnkton) | Mid (15–25 €) | ❄️ | ✅✅✅ | multiple stores | TTL array | High (parts) | 🔥🔥🔥 | ✅ | niche |
📚 Further reading
- Raymond Carlsen, “PLA Failures and Substitutes”
