Nintendo Entertainment System Troubleshooting Guide
| Manufacturer | |
| Type | |
| CPU | |
| Memory | |
| Storage | |
| Display | |
| Sound | |
| OS / Firmware | |
[[Category:Lua error in package.lua at line 80: module 'Module:Pagetype/setindex' not found. with short description]]Template:SDcat
Template:Redirect-multi Template:Use British English
| Nintendo Entertainment System (NES) Control Deck | |
| Developer | Nintendo R&D2 |
| Manufacturer | Nintendo |
| Type | Home video game console |
| Released | July 15, 1983 (JP) October 18, 1985 (NA) September 1, 1986 (EU) |
| Discontinued | 2003 (JP) |
| Intro price | US$179 (1985, NA launch) |
| CPU | Ricoh 2A03 (MOS 6502 core) @ 1.79 MHz (NTSC) / Ricoh 2A07 @ 1.66 MHz (PAL) |
| Memory | 2 KB RAM, 2 KB video RAM |
| Storage | ROM cartridges (up to 1 MB with mappers) |
| Display | 256×240 px (NTSC), 256×240 px (PAL) |
| Sound | 5-channel mono (2 pulse, 1 triangle, 1 noise, 1 DPCM) |
| Dimensions | 25.4 × 20.3 × 7.6 cm (NES) |
| Weight | 1.4 kg |
| OS / Firmware | None (game cartridge based) |
| Predecessor | Color TV-Game |
| Successor | Super Nintendo Entertainment System |
| Codename | AVS (prototype) |
| Model no. | NES-001, HVC-001 (Famicom) |
The Nintendo Entertainment System troubleshooting guide provides technical information, common faults, and repair tips for the NES and Famicom consoles. This guide covers hardware faults, cleaning, cartridge slot issues, and basic component-level diagnosis for both the original front-loader NES and the Japanese Family Computer.
🧠 Architecture and Processor
The NES is powered by the Ricoh 2A03 (NTSC) or 2A07 (PAL) microprocessor, a custom variant of the MOS 6502. The CPU integrates basic sound hardware and communicates with the PPU (Picture Processing Unit) for graphics.
💾 Memory and Storage
- 2 KB internal RAM (CPU)
- 2 KB video RAM (PPU)
- Game data stored on ROM cartridges, with additional RAM or mappers on some cartridges
🖥️ Display and Graphics
- 256×240 pixels resolution (NTSC/PAL)
- 48 colours (54 on Famicom), 25 on-screen at once
- Hardware sprites and scrolling
🔊 Sound Capabilities
- 5 audio channels: 2 pulse, 1 triangle, 1 noise, 1 DPCM sample
- Mono output via AV or RF
🎮 Input/Output and Expansion
- 2 controller ports (NES: detachable, Famicom: hardwired)
- Expansion port (underside, rarely used)
- Cartridge slot (72-pin NES, 60-pin Famicom)
- RF and composite AV output (Famicom: RF only)
🧰 General Maintenance
- Clean cartridge contacts with isopropyl alcohol and a soft cloth
- Clean console slot pins using a soft brush or contact cleaner
- Avoid blowing into cartridges (introduces moisture)
- Store in a dry, dust-free environment
🧾 PCB Schematics & Service Guide
Official schematics are available in Nintendo's service manuals. Key ICs include:
- CPU: Ricoh 2A03/2A07
- PPU: Ricoh 2C02/2C07
- RAM: 6116 (2 KB), 2114 (video RAM)
- CIC lockout chip (NES only)
📷 Motherboard Images
📚 Technical Documentation
📷 Gallery
NES Control Deck
Famicom main unit
NES motherboard
Famicom motherboard
🧪 Related Pages
- Nintendo Entertainment System
- Famicom Disk System
- NES hardware clone
- NES controller
- List of NES games
See: General Maintenance
See: PCB Schematics & Service Guide
Apple Service Manual
Not applicable to NES hardware.
- Inspect for bulging or leaking capacitors (rare on NES, more common on Famicom)
- Replace with same value, low-ESR electrolytic capacitors
- Common values: 220μF/16V (power), 10μF/16V (audio), 1μF/50V (reset circuit)
Retrobrite
- Retrobrite can be used to whiten yellowed NES/Famicom plastic cases
- Use with caution; prolonged exposure may weaken plastic
Common Faults and Fixes
- Blinking red power LED / flashing screen: Dirty or worn 72-pin connector. Clean or replace connector.
- No picture or sound: Check power supply, AV/RF cables, and cartridge contacts.
- Distorted graphics: Faulty PPU or bad cartridge connection.
- No controller response: Faulty controller, port, or mainboard traces.
- Random resets: Failing power supply, loose connector, or bad capacitors.
Diagnostic Steps
- Test with known-good game and power supply.
- Clean cartridge and slot contacts.
- Inspect for broken solder joints, especially on the 72-pin connector.
- Check for bulging capacitors or burnt components.
- Use a multimeter to verify voltage rails (+5V, GND).
- CPU: Ricoh 2A03/2A07 (6502 core)
- RAM: 2 KB internal, 2 KB video
- Cartridge ROM and optional RAM/mappers
Memory Map (Physical)
- $0000–$07FF: 2 KB internal RAM
- $2000–$2007: PPU registers
- $4000–$401F: APU and I/O registers
