BBC Micro Model A/B General Maintenance
The BBC Micro Model A/B is a classic British microcomputer, now over 40 years old. Regular maintenance is essential to preserve its reliability, prevent avoidable failures, and ensure safe operation for years to come.
🧼 Regular Cleaning
Case and Keyboard
- Wipe the ABS case and keycaps with a damp microfibre cloth and mild soap. Avoid excess water near the badge or labels.
- Remove keycaps gently (vertical pull) for deep cleaning; clean plungers and springs with 99% isopropyl alcohol (IPA).
- For yellowed plastics, retrobrite is possible but monitor carefully to avoid warping or streaking.
- Lubricate the space bar stabiliser wire with plastic-safe grease if sticky.
Mainboard and Expansion Sockets
- Unplug the computer and allow capacitors to discharge for 5 minutes before opening.
- Use compressed air or a soft anti-static brush to remove dust from the mainboard, PSU, and connectors.
- Re-seat all socketed ICs (including ULA, CPU, ROMs) annually to reduce contact oxidation.
- Clean edge connectors (user port, 1 MHz bus, Tube, Econet) with IPA and a lint-free swab.
🔋 Power Supply & Voltage Checks
The BBC Micro’s internal linear PSU is robust but can fail with age, especially due to capacitor degradation.
Safety Precautions
- Never operate the PSU with the cover removed. High voltages are present.
- If the machine is unused for years, power up gradually using a variac or series bulb limiter if available.
Voltage Test Points
| Rail | Test Location | Expected Value |
| +5V DC | Any 74LS IC pin 14 vs pin 7 | 4.90 – 5.15 V |
| -5V DC | IC49 (SN76489) pin 1 vs GND | -4.75 – -5.25 V |
| +12V DC | IC11 (Video ULA) pin 24 vs GND | 11.5 – 12.5 V |
| Unregulated +18V | C9 positive lead | 17 – 20 V (varies with load) |
- Use a digital multimeter; check voltages before and after cleaning or repairs.
- If any rail is out of range, do not use the machine until the PSU is serviced.
Power Supply Refurbishment
- Replace all electrolytic capacitors in the PSU as a precaution (see below).
- Inspect for cracked solder joints, especially on the transformer and output connectors.
- Modern switch-mode replacement PSUs are available for the BBC Micro, but original units can be safely rebuilt.
⚠️ Connector & Socket Corrosion
Age and humidity can cause oxidation on edge connectors, sockets, and switches.
Areas to Inspect
- IC sockets (CPU, ROMs, ULA, video, sound)
- Expansion edge connectors: user port, 1 MHz bus, Tube, Econet, disk drive
- Keyboard ribbon cable and connectors
- Power switch and rear panel connectors
Cleaning Procedure
- Apply DeoxIT or IPA to contacts; insert and remove ICs or cables several times to wipe oxidation.
- For persistent tarnish, use a fiberglass pen or pink eraser (gently).
- Inspect for green or white corrosion, especially on the user port and cassette socket.
💣 Capacitor Health & Replacement
The BBC Micro contains both electrolytic and tantalum capacitors, some now well past their service life.
PSU Capacitors
- The RIFA X2 suppression capacitors (usually yellow or clear plastic, marked “RIFA”) are notorious for cracking and smoking. Replace immediately with new X2-rated parts.
- Replace all large electrolytics (e.g., C1, C2, C9) in the PSU to prevent voltage ripple and failure.
Mainboard Capacitors
- Replace any leaking, bulging, or crusty electrolytics (e.g., C9, C10, C31, C32, C37).
- Tantalum capacitors (e.g., C7, C8) rarely fail but can short-circuit catastrophically—replace if suspect.
- Clean any residue with IPA and repair corroded traces as needed.
Symptoms of Capacitor Failure
- PSU emits smoke or acrid smell (RIFA failure)
- Computer fails to power on, random resets, or video instability
- Audio hum, loss of sound, or video sync issues
🛠️ Common Failure Points
| Component | Symptom | Notes / Quick Test |
| RIFA X2 caps (PSU) | Smoke, bang, burning smell | Replace all X2 caps on sight; do not power up until done |
| IC sockets (esp. ULA, CPU, ROMs) | No boot, random crashes, “beeeeeeeep” | Reseat chips, clean sockets, check for bent pins |
| Keyboard matrix / ribbon | Dead keys, stuck keys, no response | Inspect cable, clean contacts, test with continuity meter |
| Video ULA (IC6) | No video, garbled display, missing colours | Swap with known good ULA if available |
| RAM chips (ICs 61–76) | “Language?” error, random crashes, coloured screen | Use RAM test ROM or swap chips |
| Power switch | Intermittent power, won’t turn on/off | Clean or replace switch; check for arcing |
| Speaker / sound circuit | No sound, buzzing, distortion | Check speaker, C31/C32, SN76489 (IC49) |
🔌 Device-Specific Subsystems
Cassette Interface
- Clean the cassette socket with IPA; inspect for corrosion.
- Use good-quality, azimuth-adjusted cassette recorders and tapes.
- Replace C31/C32 if loading is unreliable.
Disk Drive Interface
- Clean the 34-pin disk connector and check for bent pins.
- Inspect for dry joints on the disk interface header.
- For DFS/Econet upgrades, ensure ROMs are properly seated.
RGB/Composite Video
- Clean the RGB and composite sockets.
- If video is unstable, check C9, C10, and the Video ULA.
User Port, 1 MHz Bus, Tube
- Clean edge connectors; inspect for corrosion or broken traces.
- For unreliable operation, check for dry joints and reflow as needed.
Cooling and Ventilation
- The BBC Micro is passively cooled. Ensure vents are clear and do not block airflow.
- In hot environments, consider adding a low-noise 5V fan inside the case, powered from the user port (observe current limits).
🧰 Recommended Tools & Consumables
- ESD wrist strap and anti-static mat
- Digital multimeter (for voltage and continuity checks)
- Soldering station with fine tip, flux, desolder braid
- DeoxIT or high-purity IPA for contact cleaning
- Fiberglass brush or pink eraser for edge connectors
- Replacement X2 safety capacitors (RIFA), electrolytics, and tantalums
- Small Phillips and flat screwdrivers, spudger for keycap removal
- Diagnostic ROMs (e.g., “Test ROM”, “Acorn Diagnostic”)
📝 Preventive Maintenance Checklist
- Inspect and replace RIFA X2 capacitors in the PSU before first power-up.
- Check all PSU output voltages (+5V, -5V, +12V) before connecting peripherals.
- Clean and re-seat all socketed ICs; treat sockets with contact cleaner.
- Clean edge connectors (user port, Tube, etc.) annually.
- Inspect and clean keyboard matrix and ribbon cable.
- Replace mainboard electrolytic capacitors if leaking, bulging, or over 40 years old.
- Check for dry joints on the PSU, connectors, and expansion headers.
- Maintain good ventilation—keep vents clear and avoid stacking equipment.
