Macintosh SE/30 Troubleshooting
Revision as of 08:56, 12 May 2025 by Josh (talk | contribs)
This guide provides solutions to common faults experienced in the Macintosh SE/30. From power issues to Simasimac patterns and SCSI failures, these diagnostics will help identify, isolate, and resolve problems.
Begin by verifying the analog board delivers proper voltages:
  • +5V rail: 4.90V – 5.10V
  • +12V rail: Confirmed at floppy or hard drive connectors
If the unit is completely dead (no fan, CRT glow, or chime), inspect:
  • Fuses
  • Rectifiers CR2 and CR3
  • Transistor Q2
  • Resistor R22
Also:
  • Disconnect external peripherals and cards
  • Check logic board for PRAM battery corrosion
  • Replace all electrolytic capacitors on the logic board
"Simasimac" – Horizontal Stripe Pattern
Macintosh SE/30 Simasimac pattern
The infamous "Simasimac" pattern shows horizontal black-and-white lines with no startup chime. Causes include:
  • Leaking capacitors disrupting the reset circuit
  • Corroded traces or vias near RAM/ROM
Solutions:
  • Clean and reseat ROM and RAM SIMMs
  • Replace PRAM battery if < 3V
  • Check for reset pulse at CPU
  • Test for 16 MHz clock at CPU
  • Inspect Apple Sound Chip (ASC) at UB11 and filter RP2
  • Use multimeter or oscilloscope to confirm continuity
Chimes of Death and Sad Mac Codes
The Chimes of Death signify early boot failure—commonly RAM or ROM faults.
Checklist:
  • Use 4 matched SIMMs per bank
  • Larger-capacity SIMMs go in Bank A
  • Clean/reseat ROM SIMM
  • Check address/data continuity near capacitors
  • Replace 74F258 multiplexers or RAM if needed
  • Check VIA chips for overheating or corrosion
See: Sad Mac Error Codes for detailed interpretation.
Video Display Issues
No Video but Chime Present
  • Verify brightness knob
  • Confirm CRT glow
  • Check UE8 (video multiplexer)
  • Probe video/sync signals at P1 connector
Vertical "Jailbar" Stripes
  • Indicates incorrect RAM configuration
  • Use identical SIMMs per bank (larger ones in Bank A)
Checkerboard Pattern
Checkerboard error screen
  • Typically a ROM failure
  • Clean/reseat the ROM SIMM
  • Confirm compatibility (use SE/30 or IIsi ROMs only)
Disk Drive and SCSI Issues
Frozen Mouse on Gray Screen
  • Possible failure of SCSI controller (NCR 53C80)
  • Disconnect all internal/external SCSI devices
  • Inspect and replace termination resistors
Floppy Drive Issues
  • Dirty mechanism
  • Faulty SWIM controller
  • Cold solder joints on VIA or SWIM ICs
For more, see:
Audio and ADB Issues
No Sound
  • Test audio at the headphone jack
  • Inspect ASC (Apple Sound Chip)
  • Inspect analog board audio amplifier
ADB Malfunction
  • Blown fuse F1
  • Failed ADB microcontroller (Egret)
  • VIA chip solder cracks or corrosion
Reset and Clock Problems
  • Random resets: Check power rail stability
  • No time retention: Dead PRAM battery or failed 32.768 kHz crystal
  • Check surrounding electrolyte residue near Egret or VIA chips
Brief Analog Board Troubleshooting
  • Vertical line only: Horizontal deflection fault – reflow P1 connector and replace C15
  • Horizontal line only: Vertical deflection fault – reflow P1 and replace TDA1170A
  • Wavy or distorted video: Failing flyback transformer
  • PSU clicking repeatedly: Shorted logic board or failed CR2, CR3, Q2, or R22
