Macintosh LC 630 DOS Compatible Troubleshooting
Revision as of 11:10, 10 February 2026 by Josh (talk | contribs) (Created troubleshooting guide for Macintosh LC 630 DOS Compatible)
Troubleshooting is essential for diagnosing and resolving issues with your Macintosh LC 630 DOS Compatible. This guide covers both standard LC 630 problems and issues specific to the DOS Compatibility Card. The dual-processor nature of this system introduces unique failure modes not present in standard Macintosh computers.
Before detailed troubleshooting, verify:
  • Power cable is securely connected
  • Power outlet is functioning (test with another device)
  • All external cables are properly seated
  • PRAM battery has not leaked (remove if suspect)
  • DOS card is firmly seated in both CPU socket and PDS slot
Power Supply Specifications:
Rail Nominal Acceptable Range
+5V 5.00V 4.85V โ€“ 5.15V
+12V 12.00V 11.9V โ€“ 12.7V
-12V -12.00V -11.5V โ€“ -12.5V
No response when power button pressed Dead power supply Test outlet; verify power cable; check PSU fuse
Clicking or ticking from PSU Power supply failure PSU capacitors likely failed; recap or replace PSU
Fans spin briefly then stop Short circuit on logic board Remove all cards and RAM; test with minimal config
Power LED on but no boot Logic board failure Check capacitors; verify DOS card properly seated
Intermittent power-on Failing PSU capacitors Recap power supply
Powers on with case open only Interlock switch issue Check rear panel interlock mechanism
Power Supply Testing
  1. Disconnect all drives and expansion cards
  2. Power on and measure voltages at SIMM socket or test points
  3. If voltages are low or unstable, PSU needs recap or replacement
  4. Check for swollen or leaking capacitors in PSU (discharge before opening)
Chime but No Video
Video Problems After Startup Chime
Chime, no video on Mac Monitor connection Check DA-15 cable; test with known-good monitor
Chime, no video, drive activity RAM issue Reseat/test SIMM modules; try known-good RAM
Video works briefly then fails Failing capacitors Inspect and replace logic board capacitors
Distorted or rolling image Video timing issue Check monitor compatibility; verify refresh settings
Correct colors but dim Monitor aging Adjust monitor brightness; consider CRT rejuvenation
Stuck in PC mode (no Mac video) DOS card mode conflict Remove DOS card; boot Mac side; check PC Setup settings
Video Troubleshooting Procedure
  1. Verify monitor works with another system
  2. Try a different video cable
  3. Remove DOS card temporarily to test base Mac video
  4. Reseat SIMM modules
  5. Check for capacitor leakage near video circuits
DOS Card Specific Issues
The DOS Compatibility Card introduces unique problems not found in standard LC 630 systems:
DOS Card Not Detected
DOS Card Detection Problems
PC Setup shows "No card installed" Poor card seating Reseat DOS card in both CPU socket and PDS slot
Card detected but won't initialize Corrupted PC Setup software Reinstall PC Setup from original disks
Intermittent detection Oxidized connectors Clean card edges and sockets with DeoxIT
Mac boots, PC Setup crashes Extension conflict Boot with extensions disabled; reinstall PC Setup
DOS card worked then stopped Capacitor failure on card Inspect DOS card for leaking capacitors
Switching Problems
Mac/PC Switching Issues
Command-Return doesn't switch Hot-key conflict Check PC Setup for hot-key setting; try alternative combo
Switch causes system hang RAM allocation conflict Reduce RAM allocated to DOS card
PC mode shows garbled video Video configuration mismatch Check PC video settings in AUTOEXEC.BAT
PC mode has no sound SoundBlaster driver issue Verify SOUND.COM loaded; check CONFIG.SYS
Mouse doesn't work in PC mode Missing mouse driver Install Microsoft or PS/2 mouse driver for DOS
Can't switch back to Mac DOS card crash Hard reset required; check for DOS software conflicts
PC Mode Performance Issues
DOS/Windows Performance Problems
Very slow PC performance Shared RAM mode Install dedicated RAM on DOS card
Windows 3.1 crashes frequently Insufficient RAM Allocate more RAM to DOS card (8 MB minimum recommended)
Games run slowly CPU limitation 486DX2/66 is period-appropriate; no significant upgrade available
DOS programs crash on exit Memory manager conflict Check CONFIG.SYS memory manager settings
CD-ROM not accessible in DOS Driver not loaded Install MSCDEX and CD-ROM driver in CONFIG.SYS
DOS Card RAM Issues
DOS Card Memory Problems
PC Setup shows 0 MB for DOS SIMM not recognized Reseat DOS card SIMM; try different SIMM
Less RAM than expected SIMM compatibility Use 80ns or faster 72-pin SIMM; 32 MB maximum
DOS reports less than allocated DOS conventional memory limit Normal DOS limitation; use memory manager for extended
Random crashes in PC mode Bad SIMM Test SIMM in Mac slots; replace if faulty
Stability Problems
Random freezes on Mac side Failing capacitors Recap logic board
Freezes when accessing floppy Floppy drive failure Clean/replace floppy drive
Freezes when accessing HD IDE drive or cable Check IDE cable; try different drive
Freezes after sleep/wake PRAM corruption Zap PRAM (Cmd-Opt-P-R at startup)
Freezes with specific software Software incompatibility Test with clean System install
Freezes when switching Mac/PC DOS card connector issue Reseat and clean DOS card connections
Sad Mac Error Codes
See the Sad Mac Error Codes page for a complete reference. Common codes for LC 630 systems:
Common Sad Mac Codes
Code Meaning Action
0000000F 00000001 ROM test failed Check ROM chips; logic board may need replacement
0000000F 00000002 Memory (RAM) test exception Test/replace SIMM; check SIMM sockets
0000000F 00000003 Memory (RAM) test error Reseat/replace RAM; clean SIMM sockets
0000000F 00000004 Memory (RAM) addressing failure Try individual SIMMs to isolate failure
0000000F 00000005 Memory (RAM) addressing failure SIMM compatibility issue; try different SIMM
0000000F 00000010 NuBus/PDS test failure DOS card may have issues; remove and test Mac boot
0000000D 0000XXXX Exception in boot code Logic board issue; check capacitors
Interpreting Sad Mac Codes
The Sad Mac code consists of two hex numbers:
  • First number: Error class
  • Second number: Specific error within that class
For RAM errors, the second number often indicates which SIMM bank failed.
Floppy Drive Issues
Floppy Drive Problems
Disk not recognized Dirty heads Clean heads with cleaning disk
Disk stuck in drive Mechanical failure Manually eject with paper clip; inspect mechanism
Read errors only Failing drive Clean heads; replace drive if persistent
Write errors Write-protect tab on Check disk write-protect; try different disk
Drive makes grinding noise Mechanical wear Replace floppy drive mechanism
PC mode can't access floppy Driver issue Check BIOS settings; verify floppy enabled in PC Setup
Capacitor Failure and Recapping
Capacitor failure is the most common issue in 30+ year-old LC 630 systems:
Capacitor Failure Symptoms
Capacitor Location Symptom Fix
Audio section Distorted or no sound Replace audio capacitors
Power regulation Unstable operation, random resets Replace all electrolytic capacitors
Video circuits Image distortion, color issues Replace capacitors near video circuits
Clock circuits Incorrect time, PRAM not saved Replace capacitors; check battery
DOS card PC mode failures, detection issues Inspect and replace DOS card capacitors
See Macintosh LC 630 DOS Compatible Capacitor Replacement Guide for complete specifications and procedures.
IDE Drive Issues
Hard Drive Problems
Drive not recognized Old drive formatting Use Drive Setup 1.0.3+ (System 7.5.2+)
Drive spins but not mounted Partition corruption Initialize with Drive Setup or third-party tool
Slow drive access PIO mode limitation Normal for 630; max PIO Mode 3 (11.1 MB/s)
"The disk is unreadable" Modern drive incompatibility Use Drive Setup; format with 630-compatible utility
Drive works on Mac but not PC FAT partition issue Create proper DOS partition using PC FDISK
Clicking from drive Drive failure Backup immediately; replace drive
IDE Controller Limitations:
  • Single device only (no master/slave)
  • 8 GB addressing limit
  • PIO Mode 3 maximum
CD-ROM Issues
CD-ROM Problems
CD not recognized in Mac Driver not loaded Check System extensions for Apple CD driver
CD not recognized in DOS MSCDEX not loaded Install MSCDEX in AUTOEXEC.BAT
Audio CDs play but data fails SCSI issue Check internal SCSI cable; clean connectors
Tray won't eject Mechanical failure Use paperclip emergency eject; clean mechanism
Random read errors Dirty lens Clean laser lens with CD cleaning disc
Troubleshooting Flowchart
System Won't Power On:
  1. Check power cable and outlet โ†’ Working? Continue.
  2. Open case, check for obvious damage โ†’ Found? Repair first.
  3. Disconnect all drives and cards โ†’ Boot now? Reconnect one at a time.
  4. Still dead โ†’ Power supply needs recap or replacement.
System Powers But No Boot:
  1. Listen for chime โ†’ No chime? RAM or logic board issue.
  2. Chime heard? โ†’ Check monitor connection.
  3. Reseat all RAM โ†’ Try with minimal RAM.
  4. Remove DOS card โ†’ Mac boots? DOS card connection issue.
  5. Still no boot โ†’ Check capacitors; consider recap.
Mac Works, DOS Card Fails:
  1. Open PC Setup โ†’ Card detected? If no, reseat card.
  2. Clean DOS card edge connectors with DeoxIT.
  3. Check for capacitor leakage on DOS card.
  4. Try reinstalling PC Setup software.
  5. Test with different DOS card if available.
