Sega CD Service Manual
Revision as of 01:16, 25 September 2026 by Josh (talk | contribs) (P4 documentation drive: rewrite doc-holder as a real documentation page - title as printed, manual number, issue date, contents with page numbers, honest gaps, and what the document settles; flags two truncated uploads in the Mega CD schematic set)
The document behind this page is titled, on its own cover, MEGA-CD Maintenance Manual, Export — with the inner title page reading MEGA-CD Maintenance Manual, Europe — dated August 1992, Rev. A, 118 pages, Sega Enterprises, Ltd. It is the European/export manual for the first-generation Mega CD; the page title here uses the American name for the same machine.
It is by a wide margin the most complete Sega document on this wiki for the Model 1 unit, and it goes all the way down to PCB copper layers.
The scan carries a text layer.
Contents
Section Page
1. Block diagram
2. Assembly drawing — 2-1 general reference number list 4
2-2. Assembly list: 1001 top case; 1002 side cover and side knob; 1003 side cover; 1004 CD-ROM unit shield; 1005 main board; 1006 CD drive unit and sub board; 1007 bottom shield and front cover 5–19
2-3. Procedure of disassembly and assembly 20–31
3. Spare parts list
4. Accessories list
7. IC pin assignments — main board IC1/IC2, IC3, IC6, IC7/IC8, IC10/IC11, IC13, IC14/IC15; sub board IC1, IC2, IC3/IC4/IC5
8. Parts list of PCB — 8-1 IC BD MEGA-CD MAIN BD EXPORT; 8-2 IC BD MEGA-CD SUB BD EXPORT; 8-3 ASSY MEGA-CD CONNECT BD EXPORT 84–96
9. Schematic diagram — 9-1 main board; 9-2 sub board; 9-3 connect board 91–103
10. Mount diagram — component side and solder side for all three boards 104–109
11. PCB design spec — copper layer artwork, component side and solder side, for all three boards 110–115
What this manual settles
  • The Mega CD Model 1 is three boards, not one: a main board, a sub board and a connect board. Each has its own parts list, its own schematic and its own mount diagram. A capacitor list for this machine that does not say which board a designator belongs to is ambiguous.
  • The IC complement of the main board, with pin assignments for each: IC1/IC2 HD68HC000CP-12 and the Sega custom MCE2 MB634120, part 315-5548; IC3 custom RF5C164A, part 315-5476A; IC6 MB3790; IC7/IC8 TC511664BZ-80; IC10/IC11 TC51832FL-10; IC13 LC8951; IC14/IC15 MB8464A-80. On the sub board: IC1 LC7883KM, IC2 LC7881M-C, IC3/IC4/IC5 µPC844G2.
  • The Model 1 boards use a plain interleaved C sequence with no CE series — C1 through C58 in one run, with the electrolytics named in the description column (for example C41–C50 are 10 µF 16 V, Sega 150-0400 / 150-0400-01, and C51/C52 are 100 µF 6.3 V radial, 150-0401). This matches the Mega Drive Model 1 convention, not the Model 2 one.
  • Two part numbers are given for the same position in places — 150-0400 and 150-0400-01 for C41–C50 — which is Sega recording a second approved vendor, not a contradiction.
  • No fault tree or symptom table. This is a maintenance and parts manual: assemblies, disassembly, parts, schematics and board artwork. It does not tell you what a symptom means.
  • No CD drive alignment or adjustment procedure.
  • No Model 2 coverage. For the Sega CD (Model 2) see the Sega CD 2 / Mega CD 2 - Service Manual.
  • Export/Europe machine only.
Pages that cite this document
Download: Sega CD Service Manual.pdf
