Power Macintosh 4400 Service Source
Revision as of 08:28, 25 September 2026 by Josh (talk | contribs) (P4 verification: turn document holder into a real documentation page (contents with PDF page numbers, Apple's own specifications, honest gaps, citing pages))
The Power Macintosh 4400 volume of Apple's Service Source is a 132-page service manual covering the Power Macintosh 4400/200 and 4400/200 PC, the Far East Power Macintosh 7220/200 and 7220/200 PC, and the Europe-only Power Macintosh 4400/160. The PDF was distilled on 20 February 1997.
Service Source volumes are module-level documents. They give Apple's own specifications, symptom charts, take-apart procedures and module part numbers, but they do not carry schematics, board-level parts lists or component values, so they cannot be used to source a capacitor table. Where a figure below is quoted, it is quoted as Apple printed it.
Specifications as Apple prints them
Item As printed
CPU, PM 4400/160 PowerPC 603e at 160 MHz with built-in FPU
Line voltage 90–270 VAC, switchable 110/220 VAC manually, RMS single phase
Frequency 47–63 Hz, single phase
Power 200 W maximum, not including the display
Energy Star EPA Energy Star compliant
Battery replace if below 3.0 V
Contents
Reconstructed from the manual's own running headers; page numbers are positions in the PDF, so a citation can be checked directly.
  • Basics — System Overview (pdf p. 3), Power Macintosh 4400/200, 7220/200 (pdf p. 4), Voltage Switch (pdf p. 5), Key Commands (pdf p. 9), CD-ROM and Hard Drive Interface (pdf p. 10), Peripheral Component Interconnect (PCI) Technology (pdf p. 11), Dual In-Line Memory Modules (DIMMs) (pdf p. 13), Video RAM (pdf p. 15), GeoPort Technology (pdf p. 16), Front View (pdf p. 17), Rear View (pdf p. 18), Logic Board (pdf p. 19)
  • Specifications — Processor (pdf p. 21), Memory (pdf p. 23), Disk Storage (pdf p. 25), I/O Interfaces (pdf p. 26), Electrical (pdf p. 31), Physical (pdf p. 32), Environmental (pdf p. 33)
  • Troubleshooting — General (pdf p. 35), Symptom Charts (pdf p. 36)
  • Take Apart — Top Housing (pdf p. 52), Link Bar (pdf p. 56), Front Bezel (pdf p. 61), Cache Card (pdf p. 64), PCI Adapter Card (pdf p. 65), Hard Drive Carrier (pdf p. 66), Hard Drive (pdf p. 70), Floppy/CD-ROM Drive Carrier (pdf p. 72), CD-ROM Drive (pdf p. 78), Floppy Drive (pdf p. 81), Logic Board (pdf p. 84), Power Supply (pdf p. 91), SCSI Cable (pdf p. 97)
  • Upgrades — DRAM DIMM (pdf p. 101), Video RAM DIMM (pdf p. 103), Cache Card (pdf p. 105), PCI Card (pdf p. 107), Communications Card (pdf p. 113), PC Compatibility Cards (pdf p. 119)
  • Additional Procedures — Battery Verification (pdf p. 121), Battery Replacement (pdf p. 123), Logic Board Reset (pdf p. 125), Battery Replacement for 4400s Sold in Germany (pdf p. 128)
Notable content
Two things here exist in no other volume. Basics has a dedicated Voltage Switch section — this supply is manually set, not auto-ranging, and an imported machine can arrive on the wrong setting. And Additional Procedures carries Battery Replacement for 4400s Sold in Germany, a separate procedure for a separate part. The 7220 is the same machine under a Far East model number.
  • No schematic, no parts list, no component values.
  • No Adjustments chapter.
Pages that cite this document
Download: Powermac_4400.pdf (3.6 MB)
