DECpc LP Troubleshooting Guide
Revision as of 00:29, 2 October 2026 by Josh (talk | contribs) (New page from DEC K-MN-SD00000-21-JG00.A service manual, CPU booklets and David Hall's zx.net.nz notes)
Rear of a DECpc LP (David Hall, zx.net.nz)
Fault-finding on the DECpc LP range from chapter 4 of DEC's DECpc LP PC Service Maintenance Manual (K-MN-SD00000-21-JG00.A), with notes from David Hall's machines.[1][2]
First steps
DEC's initial troubleshooting:[1]
  • Press Ctrl+Alt+Del. If the computer still does not start, switch off, wait until the hard disks have stopped, and switch on again.
  • Check that every cable and connection is secure.
  • Act on any POST message or beep code using the tables below, then restart.
  • Run the diagnostic software (DEC used QAPlus/FE) and the BIOS Setup utility.
If the front button does nothing at all, check the linkage between the button and the switch inside the power supply before anything else; its rubber coupling tube perishes on these machines.[2] See DECpc LP Power Supply Service.
Beep codes
When POST cannot show a message it beeps and writes a value to I/O port 80h. A code of 2-1-4 is a burst of two beeps, one beep, then four.[3]
Beep codes (DEC service manual)
Beeps Error
1-1-3 CMOS write/read failure
1-1-4 ROM checksum failure
1-2-1 Interval timer failure
1-2-2 DMA failure
1-2-3 DMA page register write/read failure
1-3-1 RAM refresh failure
1-3-3 First 64 KB RAM chip or data line failure
1-3-4 First 64 KB RAM odd/even logic failure
1-4-1 First 64 KB RAM address line failure
1-4-2 First 64 KB RAM parity failure
2-1-1 to 2-4-4 Bits 0 to F of the first 64 KB of RAM, in order (2-1-4 is bit 3)
3-1-1 Slave DMA register failure
3-1-2 Master DMA register failure
3-1-3 Master interrupt mask register failure
3-1-4 Slave interrupt mask register failure
3-2-4 Keyboard/mouse controller failure
4-2-1 Timer tick interrupt failure
4-2-2 Shutdown failure
4-2-3 Gate A20 failure
4-2-4 Unexpected interrupt in protected mode
4-3-1 RAM failure above 0FFFFh
4-3-3 Interval timer 2 failure
4-3-4 Time-of-day clock failure
4-4-1 Serial port failure
4-4-2 Parallel port failure
4-4-3 Maths coprocessor failure
3-3-4, 3-4-1, 3-4-2 Screen memory, initialisation or retrace failure (non-fatal)
[3]
POST messages
POST and boot messages (DEC service manual)
Message DEC's action
No timer tick; Shutdown failure; Timer 2 failure Replace the main logic board
Keyboard stuck key, controller, clock line, data line or failure Check the keyboard connection; replace the keyboard
Mouse failure Check the mouse connection; replace the mouse
Time-of-day clock stopped Replace the RTC
Invalid configuration information Run BIOS Setup
Diskette drive failure; hard disk controller failure; hard disk 0 failure Run BIOS Setup, check connections, then replace the drive or controller
Optional ROM bad checksum Correct the address conflict, or replace the ROM
Time-of-day not set Run BIOS Setup and set the time and date
Keyboard is locked Unlock the keyboard
[4]
The clock and CMOS run from the original alkaline battery pack, if it is still fitted. Check and replace the battery before replacing the clock chip for "Time-of-day clock stopped" or "Invalid configuration information".[2][5]
Computer faults
Computer, disk and monitor faults (from DEC's tables)
Problem Possible cause Action
No response at switch-on Main logic board failure, or board jumpers set wrongly Check the jumpers; replace the board
Power on, no picture Brightness and contrast, monitor cable, VGA disabled by jumper or Setup Adjust the monitor; check the cable; set J2 and Setup for on-board VGA
Colour monitor shows monochrome Computer switched on before the monitor, or J11 set for mono Switch the monitor on first; fit J11 for a colour monitor
Will not boot from the IDE disk No operating system or partition, wrong drive type in Setup, drive jumpers, loose cables Install or partition; set the drive type from the drive's label; check jumpers and cables
Will not boot from a SCSI disk IDE still enabled, SCSI IDs or termination In Setup set both hard disks to "Not Installed" and disable the IDE interface; with both fitted the computer boots from IDE
Will not boot from a diskette Drive not enabled, "Boot From Diskette A" disabled, no system files, drive ID Enable the drive and diskette boot in Setup
Disk cannot read or write Drive type, controller disabled in Setup, diskette write protection enabled in Setup Correct the Setup options
No response to keyboard or mouse Password set; plugged into the wrong port; no mouse driver Enter the password; swap the connectors with the power off; install the driver
[6]
Memory and disk compatibility
Use only 4 MB or 16 MB 36-bit SIMMs of 70 ns or faster in DEC's permitted combinations; see DECpc LP General Maintenance.[7] Hall finds the machines fussy about memory and likely to work only with fast-page-mode SIMMs.[2] A large modern disk or a CompactFlash card may not work with the BIOS, which has no LBA support; Hall suggests an XT-IDE ROM.[2]
A dead board
Hall's 433dxLP has never worked: no video, POST card codes 0A09 with no memory fitted and 2725 with memory, and a few beeps of an unusually low tone.[2]
  1. ↑ 1.0 1.1 Digital Equipment Corporation, DECpc LP PC Service Maintenance Manual, K-MN-SD00000-21-JG00.A, March 1996, p. 43 (File:DECpc LP Service Maintenance Manual (K-MN-SD00000-21-JG00.A).pdf). Initial troubleshooting.
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 David Hall, "Digital DECpc 340dx LP/425sx LP/433dx LP/450d2 LP/466d2 LP", zxnet, last modified 2 February 2024, zx.net.nz.
  3. ↑ 3.0 3.1 DEC, K-MN-SD00000-21-JG00.A, pp. 44–45. Beep codes for fatal and non-fatal errors.
  4. ↑ DEC, K-MN-SD00000-21-JG00.A, pp. 45–46. POST and boot messages.
  5. ↑ DEC, K-MN-SD00000-21-JG00.A, p. 40. Replacing the computer battery.
  6. ↑ DEC, K-MN-SD00000-21-JG00.A, pp. 47–50. Computer, disk drive and monitor troubleshooting tables.
  7. ↑ DEC, K-MN-SD00000-21-JG00.A, p. 32. Memory configurations.
