Commodore PET 2001 General Maintenance
Proper maintenance of the Commodore PET 2001 is essential to preserve its functionality and prevent age-related failures. This guide covers cleaning, keyboard servicing, capacitor replacement, power supply care, and CRT-specific issues unique to early Commodore PETs.
๐งผ Regular Cleaning
The PET 2001 features a hinged metal chassis for easy internal access. Dust buildup and oxidized contacts are common in these early systems.
Internal Cleaning
- Disconnect the PET from mains power.
- Carefully lift the PET's top panel to access the motherboard and CRT.
- Use compressed air and an anti-static brush to clean:
- The motherboard (especially under ROM/RAM sockets)
- Power supply area
- CRT yoke and anode cup region
- Cassette deck area (for 2001N models)
- Use isopropyl alcohol (>90%) and cotton swabs to clean stubborn areas, but avoid soaking.
External Case and CRT
- Wipe the painted metal case with a mild soap solution on a damp microfiber cloth.
- CRT screen can be cleaned using a lint-free cloth and glass cleaner sprayed onto the cloth.
- Avoid aggressive rubbing of the screen label ("Commodore") which may degrade over time.
๐ Power Supply Maintenance
The PET uses an unregulated linear power supply without a switching regulator. While robust, they do require inspection:
Inspection Checklist
- Check transformer and rectifier board for heat stress and corrosion.
- Examine all RIFA X2 safety capacitors โ these are known to explode with age. Replace immediately if original.
- Check solder joints around bridge rectifier and voltage regulators (7812, 7805, etc).
- Confirm voltages at the edge connector:
- +5V, -5V, and +12V should be within 5% tolerance.
๐ฃ Capacitor Replacement (Recapping)
Like many late-70s electronics, the PET contains aging electrolytic capacitors.
Symptoms of Failing Caps
- Vertical hold issues on CRT
- Unstable startup or flickering screen
- Noise in cassette audio playback/record
- Random freezes or garbled text
Recommended Areas to Recap
- Mainboard decoupling capacitors (especially around the 6540/6550 chips)
- CRT analog section (for power filtering)
- Power supply (main filter caps, axial types)
See the Commodore PET 2001 Capacitor Replacement Guide for a full list.
๐น Keyboard Maintenance
The chiclet keyboard on early PETs (especially the 2001-8) is notorious for key bounce, non-responsive keys, and deterioration.
Cleaning Procedure
- Remove keyboard from the chassis.
- Disassemble keycaps and springs (carefully photograph layout).
- Clean contact pads on the PCB using isopropyl alcohol.
- Polish carbon contact domes if applicable.
- Inspect for lifted traces or oxidized vias.
Repair Tips
- Use conductive paint to restore worn-out pads.
- Replace deteriorated foam/copper domes with modern equivalents (keyboard repair kits exist).
- For permanently dead rows/columns, trace the keyboard matrix and check solder joints or connector oxidation.
โ ๏ธ Common Failure Points
ROM and RAM Sockets
- The original PET 2001 uses ceramic-packaged 6540 ROMs and 6550 SRAMs in notoriously flaky sockets.
- Symptoms include:
- Blank screen
- Garbage characters
- Lock-ups or repeating startup tone
Remove, clean, and reseat chips using DeoxIT. Replace broken sockets with turned-pin variants if needed.
Cassette Mechanism (Optional)
The internal cassette recorder in early PETs may suffer from:
- Broken drive belts
- Oxidized heads
- Dirty read/write contacts
Clean with head cleaner fluid and demagnetize if possible.
Display-Related Issues
- Cold solder joints on CRT neck board or deflection board are common.
- CRT brightness/focus may drift โ use internal trimpots for focus and brightness (accessible on deflection board).
- If the CRT fails to light up:
- Check filament voltage
- Verify flyback transformer and HV section
๐ Socket and Connector Cleaning
Many ICs are socketed โ an advantage for repairs, but also a source of faults.
Steps
- Gently remove suspect chips (e.g., VIA, PIA, ROMs) using a chip puller.
- Clean pins with isopropyl or contact cleaner.
- Inspect for green corrosion or black oxide buildup.
- Reseat firmly or upgrade sockets.
๐งช Diagnostics and Burn-In
Diagnostic Tools
- Use a PET tester ROM (e.g., dead test cartridge or test harness) for RAM and ROM diagnostics.
- Use a logic probe or scope to check clock (phi2) and reset behavior.
Burn-In Tips
- Leave PET running on test pattern for several hours to identify marginal components.
- Monitor voltage regulators for excessive heat.
๐ง Voltage Test Points
Use a multimeter to check:
- +5V at 6502 Vcc (Pin 8)
- +12V on cassette motor supply
- CRT filament voltage (typically ~6.3VAC)
- Mains side capacitors should not show leakage or bulging.
๐งฐ Tools Youโll Need
- ESD-safe screwdriver set
- Chip puller or spudger
- Isopropyl alcohol (99%)
- Contact cleaner (e.g., DeoxIT)
- Soldering iron with fine tip
- Capacitor tester (optional)
- Logic probe or oscilloscope (advanced)
