Nintendo 64 Capacitor Replacement Guide
Recapping a Nintendo 64 ensures long-term reliability, stable power delivery, and crisp video/audio output. While the N64โ€™s original Japanese and early PAL models used high-quality capacitors, all units are now over 25 years old. Ageing electrolytic capacitors can cause power instability, video noise, audio distortion, or outright failureโ€”especially in humid climates or after storage. Proactive replacement of these components is a vital preventative measure for any N64 restoration.
๐Ÿ” Visual Inspection & Failure Signs
  • Bulging or domed tops โ€“ Any convex shape on the capacitorโ€™s aluminium can indicates internal pressure and imminent failure.
  • Leaking electrolyte โ€“ Brown, white, or green crust at the base or leads signals a leaking or vented capacitor.
  • Corrosion or PCB staining โ€“ Discolouration or residue around capacitors, especially near the AV section, means urgent replacement is needed.
  • Video/audio artefacts โ€“ Lines, flicker, or buzzing audio may be traced to dried-out SMD or through-hole capacitors.
  • Boot/power issues โ€“ Intermittent startup or random resets can result from high-ESR (failed) power rail capacitors.
If any capacitor shows signs of failure, replace all electrolytics on the board.
๐Ÿ“‹ Nintendo 64 Capacitor List
The Nintendo 64 uses a mix of through-hole and SMD aluminium electrolytic capacitors. The exact count and layout may vary slightly between NTSC (NUS-CPU-xx) and PAL (NUS-CPU(P)-xx) revisions, but values are generally consistent. Always verify markings and orientation before removal.
๐Ÿ–ฅ๏ธ Mainboard Electrolytic Capacitors
Nintendo 64 Mainboard Electrolytic Capacitors
Ref. Designator Capacitance Voltage Type Location / Purpose
C6 100 ยตF 6.3 V SMD 3.3 V rail filter (near power input)
C7 100 ยตF 6.3 V SMD 3.3 V rail filter (secondary)
C12 10 ยตF 16 V SMD Audio output decoupling
C13 10 ยตF 16 V SMD Audio output decoupling
C22 22 ยตF 16 V SMD Video output filter (composite/S-video)
C23 22 ยตF 16 V SMD Video output filter (composite/S-video)
C41 220 ยตF 10 V Through-hole Main 3.3 V bulk filter (near power input)
C42 220 ยตF 10 V Through-hole Main 5 V bulk filter (near power input)
C43 47 ยตF 16 V SMD RAMBUS supply filter
C51 47 ยตF 16 V SMD Cartridge slot supply filter
C61 10 ยตF 16 V SMD Controller port logic filter
Some late PAL boards (NUS-CPU(P)-03 and later) may use 220 ยตF 16 V for C41/C42; always match or exceed original voltage ratings.
๐Ÿ’พ Expansion Pak / Jumper Pak Capacitors
N64 Expansion Pak/Jumper Pak Electrolytic Capacitors
Ref. Capacitance Voltage Type Notes
C1 100 ยตF 6.3 V SMD 3.3 V filter (main)
C2 10 ยตF 16 V SMD RAM supply decoupling
If recapping the Expansion Pak, use low-ESR SMD electrolytics or solid polymer types for best results.
๐Ÿ› ๏ธ Recapping Procedure
  1. Disassemble โ€“ Remove the six tri-wing screws, gently lift the top shell, and unplug the LED/power board if fitted.
  2. Remove shielding โ€“ Unscrew and lift the RF shield. Note the thermal pads and their positions.
  3. Label all connectors โ€“ Especially AV, power, and controller port ribbons.
  4. Desolder SMD capacitors โ€“ Use hot air (set to ~280โ€“320 ยฐC) or a fine-tipped iron with flux. Gently rock the can side-to-side while heating both ends. Avoid lifting pads.
  5. Desolder through-hole capacitors โ€“ Use braid or a pump. Nintendo used high-quality solder; 350โ€“370 ยฐC is usually sufficient.
  6. Clean pads โ€“ Remove old flux and residue with IPA and a nylon brush.
  7. Install new capacitors โ€“ Match polarity (stripe = negative), value, and lead spacing. For SMD, align with original footprint and tack each end.
  8. Inspect for bridges โ€“ Use a magnifier to check for solder bridges or lifted pads.
  9. Reassemble and test โ€“ Replace shields and thermal pads before closing the shell.
  • Temperature-controlled soldering iron (fine tip, 1โ€“2 mm)
  • Hot air rework station (for SMD removal)
  • Desoldering braid and pump
  • Isopropyl alcohol (99%) and nylon brush
  • ESD-safe tweezers
  • Magnifier or microscope
  • High-quality 105 ยฐC low-ESR capacitors (e.g., Nichicon, Panasonic, Rubycon)
  • Kapton tape (to shield plastic connectors from hot air)
โš™๏ธ Post-Recap Voltage / Ripple Checks
After reassembly, measure voltage rails at the mainboard test points or cartridge slot (with the official PSU):
Nintendo 64 Power Rails โ€“ Expected Values
Test Point Nominal Voltage Acceptable Range Max Ripple (p-p)
3.3 V rail (C6/C41) 3.30 V 3.2 โ€“ 3.4 V < 40 mV
5 V rail (C42) 5.00 V 4.9 โ€“ 5.1 V < 50 mV
AV Out (video pin) 2.0 V (bias) 1.8 โ€“ 2.2 V < 30 mV
Excessive ripple (> 100 mV) or unstable voltages may indicate a faulty power supply or missed capacitor.
๐Ÿ’ก Extra Tips
  • Check the PSU first! A failing external adapter can damage new capacitors and the N64โ€™s power circuit.
  • Use low-ESR or solid polymer SMD capacitors for SMD locationsโ€”these last longer and reduce ripple.
  • Keep capacitor height โ‰ค 13 mm for through-hole parts so the RF shield fits without pressure.
  • Clean all flux residue after soldering to prevent corrosion and shorts.
  • If you experience video noise after recapping, double-check C22/C23 orientation and solder joints.
  • Expansion Pak recapping is optional but recommended for maximum reliability, especially if you see random lockups or RAM errors.
