Nintendo 64 Troubleshooting Guide
Nintendo 64 (photo)
Nintendo 64
Nintendo's service-centre manual of June 2002 covers the Nintendo 64 only to the level of exchanging the whole console or main board, with a test cartridge procedure and no schematic.[1] Nintendo's instruction booklet has a short troubleshooting table, reproduced below. The board-level figures here come from RDC's schematic of the NUS-CPU-03 and -04 mainboards and from the N64brew wiki, and apply to other revisions only where the same parts are fitted.[2][3][4]
Work from the outside in: supply, Jumper Pak, cartridge and cables first, then the board.
Safety and tools
  • The console base uses 4.5 mm Gamebit screws, cartridges 3.8 mm Gamebit, and the controller JIS #1 cross-head.[5]
  • Warning: the AC Power Supply's primary side runs at mains voltage, and its primary reservoir capacitor can stay charged after the supply is unplugged. Discharge it and check with a meter before working inside.
  • A multimeter is enough for the supply and PIF checks. The clock checks need a frequency counter or an oscilloscope good to at least 20 MHz, and the CIC and PIF data checks a logic analyser or oscilloscope.[4]
Preliminary checks
Nintendo's booklet lists these checks before anything is opened.[2]
Nintendo's troubleshooting table, condensed
Symptom Probable cause Action
No picture Power off; TV on the wrong input; Game Pak or Jumper Pak not seated Check the power switch and TV input; reseat the Game Pak; check the Jumper Pak or Expansion Pak is fully in the Memory Expansion slot
Power light does not come on, or goes off during play Supply not connected; supply needs resetting; a faulty accessory or Game Pak Check the supply and mains plug. Unplug the supply from the wall for at least two minutes to reset it. If the light still fails, remove the Game Pak, controllers and accessories and repeat; if it then stays on, the fault is in what was removed
Picture rolls or has bars or lines TV hold settings; unlicensed RF switch or modulator Adjust the TV's vertical and horizontal hold; use Nintendo's RF switch and modulator
Picture good, sound buzzes Audio leads in the wrong sockets; RF interference Check the red and white leads go to the TV's inputs; on RF, move the modulator and TV to channel 4
Picture fuzzy, colourless or snowy (RF only) RF connection or tuning Check the RF switch connections; adjust fine tuning; try with AFC off
Picture blinks or is scrambled Game Pak contact Press RESET; if no better, switch off, reload the Game Pak, switch on and press RESET
Controller does not work, or characters move on their own Controller plugged in with power on; stick held off-centre at power-on; wrong socket Plug controllers in with the power off; leave the stick centred when switching on; use socket 1
Controller buttons stick Dirt round the buttons Clean with a toothbrush and hot tap water, no soap, then dry for at least two hours
Power faults
Power light off
The power LED, D3, runs from the +3.3 V rail through R31, so a dark LED usually means no +3.3 V is reaching the board through the power switch.[3] A dim LED can also be the supply.[4]
  1. Unplug the supply from the wall for at least two minutes, then try again with the Game Pak, controllers and accessories removed.[2]
  2. Measure the supply at its plug. It should give +3.3 V and +12 V. On the plug, +3.3 V is on pins 2 and 3, +12 V on pin 6 and ground on pins 1, 4 and 5; the console socket numbers them the other way round, so confirm with a meter.[6]
  3. If the supply is low or dead, recap or replace it. Its capacitor lists are on Nintendo 64 Capacitor Replacement Guide.
  4. If the supply is good, check the power switch, SW1, for continuity on both of its poles. There is no fuse on the mainboard to check.[3]
Board supply checks
With the console switched on, measure:
  • +5 V at the output of U13 (78M05), which is fed from +12 V. The 5 V and 12 V rails are used mainly by the audio and video output stages.[3][4]
  • Vterm, 2.56 V, from U12 (PQ7VZ5), and Vref, 1.92 V, divided from Vterm by R25 and R35. These feed the RDRAM.[3]
  • +3.3 V at pin 28 of the PIF-NUS (U6, behind controller sockets 3 and 4), against ground at pin 14. Pin 1 is at the corner marked with a moulded circle. N64brew suggests suspecting the mainboard capacitors if this rail is missing or poor.[4]
Black screen with the power light on
N64brew calls this the most common symptom, because almost any fault produces it.[4]
  1. Check the Jumper Pak or Expansion Pak is fully seated. Without one, the console will not operate.[2]
  2. Try several other cartridges, with the power off each time a cartridge is changed. Dirty cartridge contacts and a dirty slot are the usual cause, and removing and reinserting a cartridge can scrape enough oxide off to help.[4]
  3. Wait. Depending on the game, it can take up to about five seconds after power-on for a picture to appear and the TV to lock to it.[4]
  4. Try another TV, and remove any chain of video adapters or converters between the console and the TV.[4]
  5. Make the board checks above.
  6. With an oscilloscope, look for activity on the composite output about ten seconds after switching on. Activity alone does not prove a picture, as a black screen still has a signal.[4]
Reset and boot lines at the PIF
The PIF-NUS holds the CPU in reset until the cartridge's CIC chip has answered it correctly. Measure with a meter, with the console switched on:[4][3]
PIF-NUS (U6) checks
Pin Signal Running console If wrong
28 VCC +3.3 V Supply or mainboard capacitor fault
14 GND 0 V
6 Cold reset 3.3 V 0 V: the CIC exchange probably failed. Clean and reseat the cartridge or try another
7 NMI to the CPU 3.3 V As pin 6
27 Reset button 3.3 V 0 V: check the reset switch, SW2
With a logic analyser, pin 3 carries data from the PIF to the cartridge's CIC, which shows the PIF is running, and pin 5 carries the CIC's reply. No reply after reseating the cartridge points at the cartridge or the slot. A reply can still be wrong, for example from a PAL cartridge in an NTSC console. Activity on pins 9, 11 and 13 within ten seconds of power-on shows the CPU has begun loading its boot code.[4]
Region and CIC mismatch
Each cartridge has a CIC-NUS lockout chip. NTSC cartridges use the 6101, 6102, 6103, 6105 or 6106, and PAL cartridges the 7101, 7102, 7103, 7105 or 7106. The region is fixed in the CIC's firmware, and the PIF's own boot ROM is region-specific too, so a cartridge from the other region gives a black screen even if it fits.[7] The UltraPIF, an FPGA board that replaces the desoldered PIF-NUS, removes the region check.[8]
Clock checks
Clock sources
Point NTSC PAL
X1 crystal (video and audio clock source) 14.318 MHz 17.734 MHz
Colour subcarrier, X1 ÷ 4, at the synthesiser's FSC pin (pin 8 of U7 on MX8330 boards) 3.580 MHz 4.434 MHz
X2 crystal (RDRAM and system clock source) 14.706 MHz 14.706 MHz
The MX8330 synthesisers on early boards are 8-pin parts; the crystal frequency appears on their pins 5 and 6. Later boards replace the two MX8330s with a single 14-pin MX8350 (U17).[9][4][3] The CPU's 93.75 MHz clock comes from X2, through the 62.5 MHz master clock, not from X1.[9]
Video faults
  • Picture or sound drops out when the lead is moved: reflow the six contacts where the multi-out connector meets the mainboard.[10]
  • On the NUS-CPU-03/04 schematic, composite video leaves through C15 (220 µF) and R5 to multi-out pin 9, and S-Video luma through C16 (220 µF) and R6 to pin 7. A missing output can be traced along that path.[3]
  • The video chips differ between revisions: VDC-NUS and ENC-NUS on NUS-CPU-01 to -04, DENC-NUS on the first PAL board, and AVDC-NUS or MAV-NUS, which also include the audio DAC, from NUS-CPU-05.[11]
Not faults:
  • PAL NUS-CPU(P)-03 boards have no S-Video on the multi-out, and the PAL (P)-01 and -02 boards need a special cable for it.[12]
  • NUS-CPU-04 boards have no composite sync on multi-out pin 3; the parts were left unfitted. An RGB cable that takes sync from pin 3 will not work on them.[12]
  • RF output needs Nintendo's RF Modulator (NUS-003) and RF Switch (NUS-009); the console has no RF output of its own.[13]
Audio faults
  • Buzz with a good picture: check the audio leads go to the TV's inputs, not its outputs.[2]
  • Sound may not start until about ten seconds after the game is running, so a missing signal straight after power-on is not proof of a fault.[4]
  • On the NUS-CPU-03/04 schematic, the audio DAC (U1, BU9480F) feeds the AMP-NUS amplifier (U2), which is powered from +12 V. Left audio leaves through C25 (10 µF) and R58 (1 kΩ) to multi-out pin 11, and right audio through C26 (10 µF) and R57 (1 kΩ) to pin 12. A dead channel can be traced along that path. On these boards, silence on both channels with a good picture points at U1, U2 or U2's +12 V supply.[3]
Cartridge and save faults
  • Before inserting a Game Pak, check its edge connector for foreign material, which Nintendo warns can damage the console. Switch off before inserting or removing one.[2]
  • Clean contacts with isopropyl alcohol on a swab and let them dry.
  • Battery-backed cartridges and the Controller Pak use a CR2032 cell. Saves that vanish when the console is switched off mean a flat cell.[14] To keep the save while changing the cell, connect a second cell in parallel across the save supply first.[15] Games that save to EEPROM or flash have no battery.
Controller faults
  • Characters move on their own: switch off, centre the stick and switch on again without touching it, or re-centre during play by holding L and R and pressing START.[2] The stick reports movement from wherever it was when counting began.[16]
  • Loose stick: the plastic bowl in the stick module has worn. Rebuild it as in iFixit's guide or replace the module, which plugs into the controller board on a six-pin connector.[17][16]
  • Rumble Pak does not vibrate: it runs from two AAA cells. Check them and clean any corrosion from the contacts without using water.[13][18]
  • One controller socket dead: try a known-good controller in it, then check the socket's pins and solder joints. The PIF reads all four sockets directly, on pins 15 to 22.[7]
Chip-level repair
The CPU-NUS and RCP-NUS are leaded QFP packages and the PIF-NUS a 28-pin SOP, so all three can be reworked with hot air.[19][7] A failed PIF can be replaced with an UltraPIF.[8]
  1. ↑ Nintendo of America, Authorized Service Center Manual, Rev. June 2002, chapter 7 (Nintendo 64), from p. 43: whole-unit or board-level exchange, disassembly and screw torques, exploded view and parts list with the main board as one part, the Paks, and the N64 test cartridge. No schematic or component values. Hosted as Nintendo Authorized Service Center Manual (June 2002).
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 Nintendo of America, Nintendo 64 Instruction Booklet, form NUS-S-HB-USA-4 (1996). Hosted as File:Nintendo 64 Instruction Booklet NUS-S-HB-USA-4.pdf. Page 3: Jumper Pak warning; page 9: AC Power Supply; page 12: Game Pak and Control Stick cautions; pages 15 to 18: troubleshooting.
  3. ↑ 3.0 3.1 3.2 3.3 3.4 3.5 3.6 3.7 3.8 RDC, Nintendo 64bit (N64) Motherboard, schematic NUS-CPU-03/04 (NTSC), dated 02-07-2013. Hosted as N64 NUS-CPU-03-04 Schematic (PDF). P4 supply input (+12 V, +3.3 V); SW1 power switch on both rails; U13 78M05 (+5 V); U12 PQ7VZ5 (Vterm 2.56 V, Vref 1.92 V); D3 power LED from +3.3 V through R31; U6 PIF-NUS with VCC on pin 28, GND on 14, COLD RESET on 6, NMI_CPU on 7, RESET (from SW2) on 27, CIC DATA OUT on 3 and CIC DATA IN on 5; U7 MX8330 with X1 14.318 MHz; multi-out P7 with S-Video Y on pin 7, S-Video C on 8, composite on 9, left audio on 11 and right audio on 12.
  4. ↑ 4.00 4.01 4.02 4.03 4.04 4.05 4.06 4.07 4.08 4.09 4.10 4.11 4.12 4.13 N64brew Wiki, "Non-Booting Troubleshooting" (retrieved 2026-10-01).
  5. ↑ iFixit, "Nintendo 64 Screwdriver" (retrieved 2026-10-01).
  6. ↑ The Hardware Book, "N64 Power" (retrieved 2026-10-01), after Christopher James Pepi's Video Game Power Supply Voltages and Minor Repair FAQ. NUS-002 rating 3.3 V DC 2.7 A and 12 V DC 0.8 A, with plug and socket pinouts.
  7. ↑ 7.0 7.1 7.2 N64brew Wiki, "CIC-NUS" and "PIF-NUS" (retrieved 2026-10-01). CIC variants and the region bit in the CIC firmware; the PIF is a Sharp SM5-based part in a 28-pin SOP package with a region-specific boot ROM.
  8. ↑ 8.0 8.1 RetroRGB, "UltraPIF: Multi-Region N64 PIF Replacement" (20 October 2020).
  9. ↑ 9.0 9.1 N64brew Wiki, "Clock Timing" (retrieved 2026-10-01). X1 per region, X2 at 250/17 MHz multiplied by 17 to give the 250 MHz RDRAM clock, MClock 62.5 MHz and the CPU at 93.75 MHz; MX8330MC, MX9911MC and MX8350 synthesisers.
  10. ↑ iFixit, "Repairing Nintendo 64 Audio Video Port", guide 20102 (retrieved 2026-10-01).
  11. ↑ N64brew Wiki, "Video DAC" (retrieved 2026-10-01).
  12. ↑ 12.0 12.1 ConsoleMods Wiki, "N64 Model Differences" (retrieved 2026-10-01).
  13. ↑ 13.0 13.1 N64brew Wiki, "Parts and Accessories" (retrieved 2026-10-01).
  14. ↑ ConsoleMods Wiki, "List of Nintendo 64 Games with Save Batteries" (retrieved 2026-10-01). Games with a save battery, all CR2032; the Controller Pak also uses a CR2032.
  15. ↑ iFixit, "Nintendo 64 Game Cartridge Battery Replacement WITHOUT LOSING SAVE FILES.", guide 66433 (retrieved 2026-10-01).
  16. ↑ 16.0 16.1 N64brew Wiki, "Controller" (retrieved 2026-10-01).
  17. ↑ iFixit, "Nintendo 64 Controller Joystick Repair", guide 51581 (retrieved 2026-10-01).
  18. ↑ iFixit, "Nintendo 64 Rumble Pak Battery Replacement", guide 44827 (retrieved 2026-10-01).
  19. ↑ Evan-Amos, "Nintendo-N64-Motherboard-Top.jpg", Wikimedia Commons, public domain. NUS-CPU-03 mainboard.
