Nintendo 64 Maintenance Guide
Nintendo-N64-Motherboard-Top
Nintendo 64 NUS-CPU-03 mainboard, top
The Nintendo 64 was made from 1996 to 2002, so the youngest consoles are over twenty years old. Nintendo's service-centre manual of June 2002 covers its disassembly and parts list but gives no schematic or component values.[1] Nintendo's maintenance advice for owners is in the consumer instruction booklet, and the most detailed circuit reference is RDC's schematic of the NUS-CPU-03 and -04 mainboards.[2][3]
For per-revision capacitor lists see Nintendo 64 Capacitor Replacement Guide; for fault-finding see Nintendo 64 Troubleshooting Guide.
Opening the console
Six 4.5 mm Gamebit screws in the base hold the top cover. The screws inside are JIS cross-head: use a JIS driver, or an iFixit cross-head bit, which iFixit makes to fit JIS heads. Cartridges take a 3.8 mm Gamebit and controllers a JIS #1.[4]
  1. Switch off, unplug the supply from the wall and pull the AC Power Supply out of the console with its release button pressed.[2]
  2. Remove the Jumper Pak or Expansion Pak.
  3. Undo the six Gamebit screws in the base and lift off the top cover.
  4. Remove the metal shields and brackets, then the screws holding the board, as in iFixit's motherboard guide.[5]
The board carries heatsinks under its shields. N64brew notes that a board can be run on the bench for a while without them, but not indefinitely.[6]
The AC Power Supply (NUS-002) gives +3.3 V at 2.7 A and +12 V at 0.8 A on a six-pin connector with three ground pins.[7] No +5 V comes from the supply. Pin numbers differ between the plug and the socket, so find the rails with a meter rather than trusting a pinout: 12 V on a pin that should carry 3.3 V will damage the board.
Nintendo advises leaving the supply plugged into the console, even in storage, to save wear on the connector, and unplugging it from the wall instead.[2] North American supplies are built for 120 V and European ones for 220-240 V; their primary reservoir capacitors are rated 200 V and 400 V respectively, and the supplies are not interchangeable.[8]
Warning: the supply's primary side runs at mains voltage, and the primary reservoir can hold a dangerous charge after the supply is unplugged. Discharge it through a suitable resistor and confirm with a meter before touching the board. Capacitor lists for each supply board are on Nintendo 64 Capacitor Replacement Guide.
Supplies on the mainboard
On-board supplies, from the NUS-CPU-03/04 schematic
Part Function Expected
P4 Supply input +3.3 V and +12 V
SW1 Power switch; breaks both input rails
U13 (78M05) +5 V regulator, fed from +12 V +5 V
U12 (PQ7VZ5) RDRAM termination supply, fed from +3.3 V Vterm 2.56 V
R25, R35 Divider from Vterm Vref 1.92 V
D3, R31 (75 Ω) Power LED, from +3.3 V
The schematic shows no fuse on the mainboard.[3] The CPU, RCP, RDRAM and PIF run from +3.3 V; +5 V and +12 V are used mainly by the audio and video output stages.[6]
Capacitors
All the mainboard electrolytics are surface-mount cans, 13 to 18 of them depending on the board revision.[8] Read the revision (NUS-CPU-xx, NUS-CPU(P)-xx or NUS-CPU(R)-01) off the board before ordering parts, and use the lists on Nintendo 64 Capacitor Replacement Guide.
Jumper Pak and Expansion Pak
One of the two must be in the Memory Expansion slot or the console will not operate.[2] The Jumper Pak (NUS-008) only terminates the RDRAM bus; the Expansion Pak (NUS-007) adds 4 MB of RDRAM. Nintendo supplied a Jumper Pak Ejector (NUS-012) with the Expansion Pak for pulling the Jumper Pak.[9] A pak left out or half-seated after a repair looks like a dead console.
Cleaning
Nintendo sold a cleaning kit for the N64 outside Japan, with a Control Deck Cleaner (NUS-014), a Controller Cleaner (NUS-015) that fits the controller's pak slot, and a Cleaning Wand (NUS-016) for Game Pak and Controller Pak contacts.[9]
  • Before loading a Game Pak, check its edge connector for foreign material, as Nintendo's booklet says. Clean dirty contacts with isopropyl alcohol on a lint-free swab and let them dry.[2]
  • Clean the cartridge slot, Memory Expansion slot, controller sockets and multi-out with low-pressure air, a soft brush and isopropyl alcohol, with the console unplugged.
  • Clean the case with a damp cloth and a little mild detergent.
Controller
For sticking buttons, Nintendo's procedure is: disconnect the controller, dip an unused toothbrush in hot tap water (not boiling, and with no soap or detergent), shake it off, scrub around the sides of the buttons, towel it dry and leave it to air-dry for at least two hours. Do not pour liquid on the controller or submerge it.[2]
The analogue stick is a self-contained module on a six-pin connector, so a worn one can be swapped as a unit.[10] A stick that has gone loose has a worn plastic bowl inside the module. iFixit's guide rebuilds the bowl with epoxy putty shaped with a marble, then greases it.[11] A stick that drifts may only need re-centring: leave it centred at power-on, or hold L and R and press START with the stick released.[2]
Batteries
The console has no battery. Cartridges that save to SRAM, and Nintendo's Controller Pak, keep their saves with a CR2032 cell.[12] To change a cartridge cell without losing the save, wire a second CR2032 across the save-RAM supply first so the RAM stays powered while the old cell is removed.[13] See Battery Refurbishment.
The Rumble Pak (NUS-013) runs from two AAA cells.[9] Remove them for storage. iFixit's guide clears corrosion from the contacts with a flat screwdriver and a cotton bud and warns against using water.[14] See Battery Explosion, Capacitor or Corrosion Damage.
Multi-out connector
If video or audio cuts out when the lead is moved, iFixit's fix is to reflow the six contacts where the multi-out connector meets the mainboard.[15]
Tools
  • 4.5 mm Gamebit (console) and 3.8 mm Gamebit (cartridges)
  • JIS cross-head drivers, including JIS #1 for the controller
  • ESD wrist strap and a soft anti-static brush
  • Isopropyl alcohol (99 %) and lint-free swabs
  • Digital multimeter
  • Hot-air station or a fine iron and flux for surface-mount capacitors
See Recommended Tools.
Routine checks
Nintendo set no service interval for the N64. When a console comes in, or before a long session on one of unknown history:
  1. Measure both supply rails at the plug before connecting it to the console.
  2. With the console running, check +5 V at U13's output, Vterm at 2.56 V and Vref at 1.92 V.[3]
  3. Reseat the Jumper Pak or Expansion Pak.
  4. Clean the cartridge contacts and slot if games need more than one insertion to start.
  5. Check that the save battery still holds in any battery-backed cartridges.
  1. ↑ Nintendo of America, Authorized Service Center Manual, Rev. June 2002, chapter 7 (Nintendo 64), from p. 43: whole-unit or board-level exchange, disassembly and screw torques, exploded view and parts list with the main board as one part, the Paks, and the N64 test cartridge. No schematic or component values. Hosted as Nintendo Authorized Service Center Manual (June 2002).
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 Nintendo of America, Nintendo 64 Instruction Booklet, form NUS-S-HB-USA-4 (1996). Hosted as File:Nintendo 64 Instruction Booklet NUS-S-HB-USA-4.pdf. Page 3: Jumper Pak warning; page 9: AC Power Supply; page 12: Game Pak edge connector check and Control Stick neutral position; pages 15 to 18: troubleshooting, including the controller button cleaning procedure on page 18.
  3. ↑ 3.0 3.1 3.2 RDC, Nintendo 64bit (N64) Motherboard, schematic NUS-CPU-03/04 (NTSC), dated 02-07-2013. Hosted as N64 NUS-CPU-03-04 Schematic (PDF). Power section: P4 brings in +12 V and +3.3 V; SW1 switches both; U13 (78M05) makes +5 V from +12 V; U12 (PQ7VZ5) makes Vterm (2.56 V) from +3.3 V, set by R26 (316 Ω) and R27 (301 Ω); Vref (1.92 V) is divided from Vterm by R25 (130 Ω) and R35 (390 Ω); D3, the power LED, runs from +3.3 V through R31 (75 Ω). No fuse is drawn.
  4. ↑ iFixit, "Nintendo 64 Screwdriver" (retrieved 2026-10-01).
  5. ↑ iFixit, "Nintendo 64 Motherboard Replacement", guide 1608 (retrieved 2026-10-01).
  6. ↑ 6.0 6.1 N64brew Wiki, "Non-Booting Troubleshooting" (retrieved 2026-10-01).
  7. ↑ The Hardware Book, "N64 Power" (retrieved 2026-10-01), after Christopher James Pepi's Video Game Power Supply Voltages and Minor Repair FAQ. Console socket: pins 1 and 2 +3.3 V, pin 4 +12 V, pins 3, 5 and 6 ground. Plug: pins 2 and 3 +3.3 V, pin 6 +12 V, pins 1, 4 and 5 ground.
  8. ↑ 8.0 8.1 Console5 TechWiki, "N64" (retrieved 2026-10-01). Community wiki; capacitor lists per mainboard revision and per power supply board.
  9. ↑ 9.0 9.1 9.2 N64brew Wiki, "Parts and Accessories" (retrieved 2026-10-01).
  10. ↑ N64brew Wiki, "Controller" (retrieved 2026-10-01).
  11. ↑ iFixit, "Nintendo 64 Controller Joystick Repair", guide 51581 (retrieved 2026-10-01).
  12. ↑ ConsoleMods Wiki, "List of Nintendo 64 Games with Save Batteries" (retrieved 2026-10-01). All known battery-backed N64 cartridges and the Controller Pak use a CR2032.
  13. ↑ iFixit, "Nintendo 64 Game Cartridge Battery Replacement WITHOUT LOSING SAVE FILES.", guide 66433 (retrieved 2026-10-01).
  14. ↑ iFixit, "Nintendo 64 Rumble Pak Battery Replacement", guide 44827 (retrieved 2026-10-01).
  15. ↑ iFixit, "Repairing Nintendo 64 Audio Video Port", guide 20102 (retrieved 2026-10-01).
