Apple Desktop Bus Mouse
| Apple Desktop Bus Mouse | |
| Apple Desktop Bus Mouse (Model M0142) | |
| Type | Pointing device |
| Discontinued | January 1993 |
| Price | US$119 (retail) |
| Interface | Apple Desktop Bus |
| Compatible | Apple IIGS, Macintosh SE, Macintosh II, all ADB-equipped Macs |
| Dimensions | 93 mm L × 61 mm W × 36 mm H |
| Weight | 175 g (6.2 oz) |
| Predecessor | Apple Mouse (DE-9) |
| Successor | Apple Desktop Bus Mouse II |
| Model | M0142, G5431, A9M0331 |
The Apple Desktop Bus Mouse was the first mouse designed for the Apple Desktop Bus (ADB) interface, introduced in September 1986 with the Apple IIGS. Released alongside Apple's transition from proprietary connectors to the standardized ADB system, it became the standard mouse for Macintosh computers from the Macintosh SE and Macintosh II through early 1993. The mouse retained the angular, blocky design of its DE-9 predecessor but adopted the Snow White design language with uniform Platinum gray coloring.
Model Variants
Three model numbers were assigned to the Apple Desktop Bus Mouse during its production run:
- A9M0331 – Original model introduced with the Apple IIGS (September 1986)
- G5431 – Version bundled with Macintosh II and SE (March 1987)
- M0142 – Consolidated model number used from 1988-1993
Despite different model numbers, all variants were functionally identical. Manufacturing occurred in Taiwan (early models), Ireland, USA, and later Singapore and Malaysia facilities.
Design & Construction
Physical Characteristics
The ADB Mouse maintained the rectangular footprint of earlier Apple mice but featured a lower, triangular profile measuring 93mm × 61mm × 36mm. The single button spanned the entire front section of the mouse, providing a large clicking surface. The case was injection-molded ABS plastic in Apple's standard Platinum gray (Pantone 423C), with only the cable and connector retaining the darker "Smoke" gray color.
Internal Components
The mouse utilized mechanical ball tracking with the following key components:
- Tracking mechanism: 19mm rubber-coated steel ball (black on early models, gray on later)
- Optical encoders: Two perpendicular slotted wheels with infrared LED/phototransistor pairs
- Controller chip: Various manufacturers including:
- Mitsumi custom ADB controller
- Logitech 42c60p5625 (Taiwan models)
- IC Designs custom ASIC
- Alps 820-0232 (USA models)
- Microswitch: Omron D2F series rated for 1 million clicks
- Circuit board: Single-sided PCB with through-hole components
Manufacturing Variations
Five primary internal designs existed across production facilities:
Taiwan manufacture (Logitech):
- Model A9M0331 with black ball
- Beige PCB top, green bottom
- Marked "ADB Mouse by Logitech Rev C2"
- White ball cage
- Part numbers: 400115-400118
Taiwan manufacture (Logitech G5431):
- Green PCB marked "Logitech AT Rev B"
- P/N 200048-00
- Black ball cage
- Part numbers: 400234-400235
USA manufacture (Alps):
- Brown PCB stamped 820-0232
- Gray 25mm ball
- Round retainer with V-notch
- Integrated ball cage
- Part numbers: 815-1090 to 815-1092
USA manufacture (Unknown):
- Green PCB stamped 820-0146
- Gray 25mm ball
- Ribbed retainer with 3 tabs
- White ball cage
- Steel rollers
Malaysia manufacture (Mitsumi):
- Brown PCB marked Mitsumi
- Gray 25mm ball
- Black ball cage
- Two-screw PCB mounting
- Part numbers: 64-1259 to 64-1262
Technical Specifications
ADB Interface
The Apple Desktop Bus Mouse communicated using the ADB protocol over a 4-pin mini-DIN connector:
| Pin | Signal | Description |
| 1 | ADB Data | Bidirectional serial data line |
| 2 | PSW | Power switch signal (unused on mouse) |
| 3 | +5V | Power supply (100mA max draw) |
| 4 | GND | Ground reference |
Communication Protocol
- Data rate: Up to 125 kbit/s theoretical (typically 10-50 kbit/s)
- Bit encoding: Self-clocking duty cycle modulation
- Logic 0: Low 65μs, High 35μs
- Logic 1: Low 35μs, High 65μs
- Default address: $3 (reassignable via bus enumeration)
- Polling rate: ~100 Hz typical
Protocol Timing Details
Each ADB transaction follows this sequence:
- Attention signal: Host pulls bus low for 800μs
- Sync signal: Bus high for 70μs
- Command byte: 8 bits (4-bit address, 2-bit command, 2-bit register)
- Stop bit: Logic 0 with optional 300μs service request window
- Stop-to-start time (Tlt): 140-260μs high period
Device Registers
The ADB Mouse implemented standard ADB register functionality:
- Register 0: Mouse movement data (2 bytes)
- Byte 0: Button state (bit 7) + X movement delta (-127 to +127)
- Byte 1: Button state (bit 7) + Y movement delta (-127 to +127)
- Register 1: Reserved (unused, later used for extended protocol)
- Register 2: Reserved (unused)
- Register 3: Device identification and address
- Default handler ID: $01 (standard mouse)
- Bits 11-8: Device address (default $3)
- Bits 7-0: Handler ID
Tracking Performance
- Resolution: 100 counts per inch (CPI)
- Maximum tracking speed: 10 inches/second
- Sampling rate: Mechanical encoder dependent (~200 Hz)
- Encoder wheel slots: 36 per wheel (10° resolution)
ADB System Architecture
The Apple Desktop Bus represented a major shift in Apple's peripheral connectivity strategy. Key features included:
- Multi-device support: Up to 16 devices on a single bus
- Daisy-chaining: Devices could be connected in series
- Hot-swapping: Theoretical support (not recommended on most systems)
- Power distribution: Bus supplied up to 500mA at 5V total
- Collision detection: Automatic address conflict resolution
The mouse typically operated at address $3, with the keyboard at address $2. During system initialization, the ADB Manager would enumerate devices and resolve any address conflicts through a sophisticated random address generation scheme.
Expanded Troubleshooting & Repair
Diagnostic Procedures
Erratic Cursor Movement
Symptoms: Jumpy, inconsistent, or drifting cursor movement
Root Causes & Solutions:
- Dirty encoder wheels (Most common)
- Remove ball and inspect encoder wheels for dust/debris
- Clean wheels with cotton swab and 90%+ isopropyl alcohol
- Use compressed air to clear encoder slots
- Ensure LED/phototransistor pairs are clean
- Worn ball surface
- Check for flat spots or uneven wear
- Clean ball with isopropyl alcohol
- Replace if severely worn (19mm rubber-coated steel ball)
- Encoder wheel damage
- Inspect for broken or bent encoder wheel teeth
- Check encoder shaft for excessive play
- Replacement requires donor mouse or compatible encoder assembly
- Controller chip issues
- Test with known-good ADB system
- Check for proper +5V supply at controller
- Controller replacement requires exact matching part
Button Failures
Symptoms: No click, stuck button, double-clicking, intermittent response
Microswitch Testing:
- Measure resistance across switch terminals (should be <1Ω when pressed)
- Test for proper tactile feedback and audible click
- Check for mechanical obstruction in button mechanism
Replacement Procedure:
- Compatible switches: Omron D2F-01, D2F-01F, D2F-01F-T
- Specifications: SPDT, 10mA minimum current rating
- Desolder old switch carefully to avoid PCB damage
- Install new switch ensuring proper alignment with button actuator
Complete Failure
Symptoms: No response, system doesn't recognize mouse
Systematic Diagnosis:
- Power verification
- Measure +5V at pin 3 of ADB connector
- Check ground continuity at pin 4
- Typical current draw: 50-80mA during operation
- Cable testing
- Check for breaks at strain relief points
- Test continuity of all four wires end-to-end
- Common failure point: cable entry to mouse body
- ADB communication test
- Use oscilloscope to verify data signal on pin 1
- Check for 800μs attention pulse from host
- Verify mouse responds with register data when polled
- Controller diagnostics
- Check crystal oscillator (if present) for proper frequency
- Verify controller power pins (+5V and ground)
- Test for shorts on data lines
Component-Level Repairs
Circuit Board Repair
Common PCB Issues:
- Cracked traces near cable entry
- Cold solder joints on through-hole components
- Corrosion from liquid spills
Repair Techniques:
- Use 30AWG wire for trace repairs
- Reflow all solder joints with flux
- Clean corrosion with white vinegar, then IPA
- Apply conformal coating after repairs
Encoder Maintenance
Cleaning Procedure:
- Remove encoder wheels from shafts
- Clean wheel slots with soft brush
- Clean optical pairs with lens cleaning solution
- Verify proper spring tension on roller shafts
- Apply small amount of silicone lubricant to shafts
Alignment Check:
- Encoder wheels must be perpendicular
- LED must align with center of phototransistor
- Wheel must pass cleanly through optical gap
- No rubbing or binding during rotation
Cable Replacement
Required Skills: Soldering, cable preparation
Procedure:
- Source replacement 4-conductor cable with shield
- Match original wire colors if possible:
- Pin 1 (Data): Usually white or yellow
- Pin 2 (PSW): Usually black or brown
- Pin 3 (+5V): Usually red
- Pin 4 (Ground): Usually green or shield
- Maintain original cable length (approximately 1.2m)
- Use heat shrink tubing at stress points
Test Equipment & Tools
Essential Tools:
- Digital multimeter with continuity test
- Precision screwdriver set (Phillips #0, #1)
- Desoldering pump or wick
- Temperature-controlled soldering iron (15-25W)
- 90%+ isopropyl alcohol
- Cotton swabs and lint-free cloths
- Compressed air
Advanced Diagnostics:
- Oscilloscope (10MHz minimum bandwidth)
- Logic analyzer for protocol analysis
- ADB diagnostic software (TechTool, ADB Parser)
- Frequency counter for timing verification
Preventive Maintenance Schedule
Monthly:
- External cleaning of mouse surface
- Check cable for damage
Quarterly:
- Remove and clean ball
- Inspect encoder wheels
- Clean mouse pad surface
Annually:
- Disassemble and deep clean
- Check microswitch operation
- Inspect PCB for damage
- Test on known-good system
Common Modifications
Two-Button Conversion
Most ADB controller chips included support for a second button, though Apple never implemented it. Common modifications included:
- Identifying the unused second button pin on the controller chip (varies by manufacturer)
- Adding a tactile switch connected to this pin and ground
- Modifying the case to accommodate the additional button
- Software support via third-party control panels (ClickChange, MouseWorks)
Optical Sensor Upgrade
Modern retrofit kits allow replacement of the mechanical ball system with optical tracking:
- TT Design's ADB Optical Mouse Retro Board (RP2040-based)
- Uses modern optical sensor (PixArt or similar)
- Maintains original 100 CPI default with adjustable settings
- Compatible with original ADB protocol and timing
- Requires desoldering original PCB and installing retrofit board
Performance Enhancements
- Teflon pad replacement: Replace worn pads with PTFE dots
- Ball upgrade: Replace with precision phenolic resin ball
- Spring tension adjustment: Optimize encoder wheel pressure
- Shielding improvements: Add EMI shielding to reduce interference
Maintenance & Repair
Cleaning Procedure
Regular maintenance was essential for reliable operation:
- Remove the retaining ring on the bottom of the mouse (rotate counterclockwise)
- Extract the tracking ball
- Remove lint and debris from encoder wheels using compressed air
- Clean encoder wheel surfaces with cotton swab and IPA
- Clean mouse pad contacts if present
- Reassemble in reverse order
Common Failures
- Erratic cursor movement: Dirty encoder wheels or worn ball (80% of issues)
- Button failure: Worn microswitch (replaceable with D2F series)
- Intermittent connection: Broken wires at cable strain relief
- Complete failure: ADB controller chip damage (often from hot-swapping)
ADB Port Safety
The ADB port lacked proper protection against hot-swapping on most systems. Connecting or disconnecting devices while powered could blow the ADB fuse on the motherboard (typically 1.1A polyfuse), requiring professional repair or fuse replacement.
Historical Context
The Apple Desktop Bus Mouse marked several important transitions:
- First ADB peripheral: Introduced the new connection standard alongside the Apple IIGS
- Design language shift: Fully embraced Snow White industrial design
- Manufacturing globalization: Production spread across multiple facilities worldwide
- Extended compatibility: Worked with all ADB-equipped systems through 1999
Production estimates suggest over 4 million units manufactured during its 6.5-year production run.
Software Compatibility
System Software
- Apple IIGS: GS/OS with built-in mouse driver
- Macintosh: System 3.2 through Mac OS 9.2.2
- NeXT: Compatible with ADB-equipped NeXT systems
- Third-party: MouseKeys, QuicKeys, SteerMouse, USB Overdrive (with adapters)
Control Panels
- Mouse control panel: Tracking speed adjustment (System 6.0+)
- CloseView: Cursor size and visibility options
- Third-party tools: Added acceleration curves and button customization
Parts & Specifications
Replacement Components
| Component | Specification | Modern Equivalent |
| Microswitch | Omron D2F series | D2F-01F-T, D2FC-F-7N |
| Ball | 19mm rubber-coated steel | 3/4" precision bearing ball |
| Encoder wheels | 36-slot optical | Custom part (donor required) |
| LED | IR 940nm | Standard 3mm IR LED |
| Phototransistor | IR sensitive | Standard 3mm phototransistor |
| Controller IC | Various proprietary | No direct replacement |
Electrical Specifications
- Operating voltage: 4.75V - 5.25V
- Current consumption: 50mA typical, 100mA maximum
- Data rate: 10-50 kbit/s typical
- Temperature range: 10°C - 40°C operating
- Humidity: 20% - 80% non-condensing
Collector Information
Identification
- Early models (1986-1988): Larger printed label with two screws
- Later models (1988-1993): Smaller label with single center screw
- Serial number format: First letter indicates year, second indicates manufacturing location
Condition Assessment
- Case yellowing: Common due to brominated flame retardants in ABS plastic
- Cable integrity: Check for cracks at strain relief points
- Mechanical wear: Test ball retention and encoder wheel movement
- Button feel: Should have distinct tactile feedback
Modern Usage
- ADB-to-USB converters: Griffin iMate (discontinued), Wombat adapter, Belkin F5U118
- Retrobrighting: Possible but risky for painted Platinum plastic
- Replacement parts: NOS balls and microswitches still available
- Modern retrofits: Optical sensor upgrades maintain vintage appearance
