Macintosh Performa 6400
Revision as of 11:52, 10 February 2026 by Josh (talk | contribs) (Created article for Macintosh Performa 6400 series)
Macintosh Performa 6400/200
TypePersonal Computer
ReleasedAugust 7, 1996
DiscontinuedAugust 1, 1997
Intro priceUS$2,100–$2,800
CPUPowerPC 603ev @ 180 or 200 MHz
Memory16 MB RAM (expandable to 136 MB)
Storage1.6–2.4 GB IDE hard drive, 8X CD-ROM
DisplaySupports up to 1024×768 @ 8-bit
SoundSRS 3D surround sound with integrated subwoofer
Dimensions16.0" H × 7.8" W × 16.9" D (40.6 × 19.8 × 42.9 cm)
Weight44.5 lbs (20.2 kg)
OS / FirmwareSystem 7.5.3 – Mac OS 9.1
PredecessorPerforma 6360
SuccessorPower Macintosh 6500
CodenameAlchemy (logic board)
Model no.M3548
The Macintosh Performa 6400 is a personal computer designed, manufactured and sold by Apple Computer from August 1996 to August 1997.[1] It is the only Macintosh mini-tower to be branded as a Performa, and was one of the last new Performa-branded models introduced by Apple.[2]
The Performa 6400 was succeeded by the uniformly-named Power Macintosh 6500 in August 1997.
Model Variants
The Performa 6400 was sold in several configurations based on region and processor speed:
Model CPU Speed Hard Drive Region Notes
Performa 6400/180 180 MHz 1.6 GB North America Base consumer model
Performa 6400/200 200 MHz 2.4 GB North America Higher-end consumer model
Performa 6400/200 Video Editing Edition 200 MHz 2.4 GB North America Included Avid Cinema video I/O card, 32 MB RAM
Power Macintosh 6400/200 200 MHz 2.4 GB North America, UK Education market
Performa 6410 180 MHz 1.6 GB Europe, Asia Rebadged 6400/180
Performa 6420 200 MHz 2.4 GB Europe, Asia Rebadged 6400/200
All Performa 6400 models use a PowerPC 603ev processor soldered to the logic board and cooled by a fanless heatsink.[3] The processor is a 32-bit design with a 64-bit data path to main memory.
The logic board, codenamed "Alchemy", is shared with the Power Macintosh 5400 all-in-one and Performa 6360 desktop models. The Alchemy board improved upon its 5200/6200 predecessors by providing a 64-bit data path to main memory.
Though initially considered non-upgradable, third-party CPU upgrades became available that overrode the soldered CPU via the L2 cache slot.
Processor Specifications
Component Specification
CPU PowerPC 603ev @ 180 or 200 MHz
FPU Integrated
L1 Cache 32 KB
L2 Cache 256 KB (optional)
System Bus 40 MHz
Data Path 64-bit
Memory and Storage
RAM Configuration
The Performa 6400 includes 8 MB of RAM soldered to the motherboard, with two 168-pin DIMM slots supporting 70 ns memory modules. Maximum RAM capacity is 136 MB.
Specification Details
RAM Type 168-pin DIMM
RAM Speed 70 ns
Standard RAM 16 MB (32 MB on Video Editing Edition)
Maximum RAM 136 MB
Motherboard RAM 8 MB
RAM Slots 2
ROM and System Software
The Performa 6400 uses a 4 MB Macintosh ROM. It shipped with System 7.5.3 Revision 2.1, a release specific to these machines due to stability issues with the standard System 7.5.3 Release 2 on the new hardware, especially regarding the video card and LocalTalk file transfers.
Supported operating systems range from System 7.5.3 to Mac OS 9.1. With a PowerPC G3 processor upgrade, Mac OS 9.2.2 can be used.
Storage Systems
Hard Drive Interface IDE
Standard Hard Drive 1.6 GB (180 MHz) or 2.4 GB (200 MHz)
Optical Drive 8X CD-ROM
Floppy Drive 1.44 MB 3.5" (manual inject)
Display and Graphics
Video memory is integrated, with 1 MB of system RAM dedicated to video functions. This allocation persists regardless of total system RAM installed.
Resolution Color Depth
640×480 16-bit (Thousands)
800×600 16-bit (Thousands)
832×624 8-bit (256 colors)
1024×768 8-bit (256 colors)
A second display can be supported with the addition of a PCI video card.
Audio Capabilities
The Performa 6400's "InstaTower" case includes an integrated subwoofer speaker and supports SRS 3D surround sound. A bass level control knob on the rear of the case adjusts subwoofer output when external speakers are connected; without external speakers, the internal speaker provides full-range audio.
Two audio output jacks are provided—one on the front panel and one on the rear. Connecting headphones to the front jack disables the internal speaker and rear output.
Input/Output and Expansion
Port Configuration
Port Quantity Notes
Serial (GeoPort) 2 One printer, one modem
SCSI 1 External only
ADB 1 Apple Desktop Bus
Audio Out 2 Front and rear jacks
Audio In 1
Video Out 1 DB-15 monitor port
Expansion Slots
Slot Type Quantity Notes
PCI 2 Standard expansion
Communications Slot 1 Supports AAUI, Ethernet, modem cards (not compatible with other Mac comm slots)
TV Tuner Slot 1
Video Input Slot 1 Occupied on Video Editing Edition
10Base-T Ethernet was available as an optional upgrade.
For detailed maintenance practices including cleaning, PRAM battery management, connector corrosion prevention, and general upkeep, refer to the dedicated Macintosh Performa 6400 General Maintenance page.
Detailed capacitor replacement guidelines for the logic board can be found on the Macintosh Performa 6400 Capacitor Replacement Guide page.
A comprehensive troubleshooting guide addressing power issues, startup problems, video issues, and other common problems is available on the Macintosh Performa 6400 Troubleshooting page.
Sub-system Specification (Macintosh Performa 6400, 1996)
CPU PowerPC 603ev @ 180/200 MHz
Bus width 64-bit data path
ROM 4 MB
RAM 16 MB (expandable to 136 MB)
Video Up to 1024×768 @ 8-bit
Sound SRS 3D surround with subwoofer
Storage 1.6–2.4 GB IDE HDD, 8X CD-ROM
Ports ADB, Serial × 2, SCSI, Audio I/O
Power Specifications
Specification Value
Input Voltage 100V–125V or 200V–240V AC
Frequency 47–63 Hz
Maximum Power 220 W
  1. ↑ Macintosh Performa 6400/180: Technical Specifications, Apple—link(accessed 2026-02-10)
  2. ↑ Apple Macintosh Performa 6400/200 Specs, EveryMac.com—link(accessed 2026-02-10)
  3. ↑ Power Macintosh 6400, Wikipedia—link(accessed 2026-02-10)
