Power Macintosh 6100 Specifications
Revision as of 13:43, 10 February 2026 by Josh (talk | contribs) (Created Specifications for Power Macintosh 6100)
This page contains detailed technical specifications for the Power Macintosh 6100 series.
Model Configurations
Power Macintosh 6100 Model Configurations
Model Order Number Processor Bus Speed L2 Cache RAM Hard Drive CD-ROM Price
6100/60 M2197LL/A 60 MHz 30 MHz Optional 256k 8 MB 160 MB None $1,820
6100/60 M1878LL/A 60 MHz 30 MHz Optional 256k 8 MB 160 MB 2X $2,000
6100/60 M3078LL/A 60 MHz 30 MHz Optional 256k 16 MB 250 MB 2X $2,350
6100/66 M3631LL/A 66 MHz 33 MHz 256k 8 MB 350 MB None $1,750
6100/66 M3632LL/A 66 MHz 33 MHz 256k 8 MB 350 MB 2X $1,950
6100/66 (PC) M3972LL/A 66 MHz 33 MHz 256k 8 MB 500 MB 2X $2,150
Model Number: M1596 | Gestalt ID: 75 (6100/60), 100 (6100/66)
Processor Specifications
CPU Specifications
Specification 6100/60 6100/66
Processor PowerPC 601 PowerPC 601
Clock Speed 60 MHz 66 MHz
Architecture 32-bit RISC 32-bit RISC
Data Path 64-bit 64-bit
FPU Integrated Integrated
System Bus 30 MHz 33 MHz
L1 Cache 32 KB 32 KB
L2 Cache Optional 256 KB 256 KB (standard)
Memory Specifications
RAM Specifications
Specification Value
RAM Type 72-pin SIMM
Minimum Speed 80 ns
RAM Slots 2
Onboard RAM 8 MB
Standard RAM 8โ€“16 MB (varies by model)
Official Maximum 72 MB
Actual Maximum 136 MB (with 2ร— 64 MB SIMMs + onboard)
Interleaving Requires matched pairs
ROM Specifications
Specification Value
ROM Type Macintosh ROM
ROM Size 4 MB
Video Specifications
Specification Value
Video Type Integrated (shared RAM)
Video RAM 640 KB (from system RAM)
VRAM Upgradeable No
Maximum Resolution (16-bit) 640ร—480
Maximum Resolution (8-bit) 832ร—624
Second Display Supported with NuBus video card (requires adapter)
Supported Display Modes
Resolution Color Depth
512ร—384 16-bit (thousands)
640ร—480 16-bit (thousands)
832ร—624 8-bit (256 colors)
Storage Specifications
Component Specification
Hard Drive Interface SCSI
Hard Drive Capacity 160, 250, 350, or 500 MB (varies by model)
Floppy Drive 1.44 MB 3.5" (manual eject)
CD-ROM 2X (optional or standard depending on model)
Audio Specifications
Specification Value
Audio Output Stereo 16-bit
Audio Input Stereo 16-bit
Sample Rate 22.05 kHz, 44.1 kHz
Expansion and Ports
Expansion Slots
Slot Type Quantity Notes
601 PDS 1 Processor Direct Slot
NuBus 1 (via adapter) Requires M1402LL/A PDS-to-NuBus adapter
Drive Bay 1 Front-facing 5.25" (if no CD-ROM installed)
Ports
Port Quantity Notes
Serial (Geoport) 2 Printer and modem ports
ADB 1 Apple Desktop Bus (keyboard/mouse)
SCSI 1 External HDI-30 connector
Video Out 1 DB-15 monitor connector
Audio In 1 Stereo 3.5mm jack
Audio Out 1 Stereo 3.5mm jack
Ethernet 1 AAUI-15
Physical Specifications
Physical Dimensions
Specification Imperial Metric
Height 3.4 inches 8.6 cm
Width 16.3 inches 41.4 cm
Depth 15.6 inches 39.6 cm
Weight 14.0 lbs 6.4 kg
Power Specifications
Power Requirements
Specification Value
Input Voltage 100Vโ€“240V AC
Frequency 50โ€“60 Hz
Maximum Power 210 Watts
Operating System Support
Software Compatibility
Specification Value
Original OS System 7.1.2
Maximum OS Mac OS 9.1
Supported Range System 7.1.2โ€“7.5.1, 7.5.3โ€“9.1
Note Mac OS 7.5.2 not supported
Timeline
Product Timeline
Event Date
6100/60 Introduction March 14, 1994
6100/60 Discontinued January 3, 1995
6100/66 Introduction January 3, 1995
6100/66 Discontinued October 14, 1995
DOS Compatible Card Specifications
PC Compatibility Card (Optional)
Specification Value
Processor Intel 486DX2
Clock Speed 66 MHz
Maximum RAM 32 MB (dedicated)
Interface NuBus
Operating System MS-DOS, Windows 3.1
