This page contains detailed technical specifications for the Power Macintosh 6100 series.
Power Macintosh 6100 Model Configurations
| Model |
Order Number |
Processor |
Bus Speed |
L2 Cache |
RAM |
Hard Drive |
CD-ROM |
Price
| 6100/60 |
M2197LL/A |
60 MHz |
30 MHz |
Optional 256k |
8 MB |
160 MB |
None |
$1,820
| 6100/60 |
M1878LL/A |
60 MHz |
30 MHz |
Optional 256k |
8 MB |
160 MB |
2X |
$2,000
| 6100/60 |
M3078LL/A |
60 MHz |
30 MHz |
Optional 256k |
16 MB |
250 MB |
2X |
$2,350
| 6100/66 |
M3631LL/A |
66 MHz |
33 MHz |
256k |
8 MB |
350 MB |
None |
$1,750
| 6100/66 |
M3632LL/A |
66 MHz |
33 MHz |
256k |
8 MB |
350 MB |
2X |
$1,950
| 6100/66 (PC) |
M3972LL/A |
66 MHz |
33 MHz |
256k |
8 MB |
500 MB |
2X |
$2,150
Model Number: M1596 | Gestalt ID: 75 (6100/60), 100 (6100/66)
CPU Specifications
| Specification |
6100/60 |
6100/66
| Processor |
PowerPC 601 |
PowerPC 601
| Clock Speed |
60 MHz |
66 MHz
| Architecture |
32-bit RISC |
32-bit RISC
| Data Path |
64-bit |
64-bit
| FPU |
Integrated |
Integrated
| System Bus |
30 MHz |
33 MHz
| L1 Cache |
32 KB |
32 KB
| L2 Cache |
Optional 256 KB |
256 KB (standard)
RAM Specifications
| Specification |
Value
| RAM Type |
72-pin SIMM
| Minimum Speed |
80 ns
| RAM Slots |
2
| Onboard RAM |
8 MB
| Standard RAM |
8โ16 MB (varies by model)
| Official Maximum |
72 MB
| Actual Maximum |
136 MB (with 2ร 64 MB SIMMs + onboard)
| Interleaving |
Requires matched pairs
ROM Specifications
| Specification |
Value
| ROM Type |
Macintosh ROM
| ROM Size |
4 MB
Video Specifications
| Specification |
Value
| Video Type |
Integrated (shared RAM)
| Video RAM |
640 KB (from system RAM)
| VRAM Upgradeable |
No
| Maximum Resolution (16-bit) |
640ร480
| Maximum Resolution (8-bit) |
832ร624
| Second Display |
Supported with NuBus video card (requires adapter)
| Resolution |
Color Depth
| 512ร384 |
16-bit (thousands)
| 640ร480 |
16-bit (thousands)
| 832ร624 |
8-bit (256 colors)
Storage Specifications
| Component |
Specification
| Hard Drive Interface |
SCSI
| Hard Drive Capacity |
160, 250, 350, or 500 MB (varies by model)
| Floppy Drive |
1.44 MB 3.5" (manual eject)
| CD-ROM |
2X (optional or standard depending on model)
Audio Specifications
| Specification |
Value
| Audio Output |
Stereo 16-bit
| Audio Input |
Stereo 16-bit
| Sample Rate |
22.05 kHz, 44.1 kHz
Expansion Slots
| Slot Type |
Quantity |
Notes
| 601 PDS |
1 |
Processor Direct Slot
| NuBus |
1 (via adapter) |
Requires M1402LL/A PDS-to-NuBus adapter
| Drive Bay |
1 |
Front-facing 5.25" (if no CD-ROM installed)
Ports
| Port |
Quantity |
Notes
| Serial (Geoport) |
2 |
Printer and modem ports
| ADB |
1 |
Apple Desktop Bus (keyboard/mouse)
| SCSI |
1 |
External HDI-30 connector
| Video Out |
1 |
DB-15 monitor connector
| Audio In |
1 |
Stereo 3.5mm jack
| Audio Out |
1 |
Stereo 3.5mm jack
| Ethernet |
1 |
AAUI-15
Physical Dimensions
| Specification |
Imperial |
Metric
| Height |
3.4 inches |
8.6 cm
| Width |
16.3 inches |
41.4 cm
| Depth |
15.6 inches |
39.6 cm
| Weight |
14.0 lbs |
6.4 kg
Power Requirements
| Specification |
Value
| Input Voltage |
100Vโ240V AC
| Frequency |
50โ60 Hz
| Maximum Power |
210 Watts
Software Compatibility
| Specification |
Value
| Original OS |
System 7.1.2
| Maximum OS |
Mac OS 9.1
| Supported Range |
System 7.1.2โ7.5.1, 7.5.3โ9.1
| Note |
Mac OS 7.5.2 not supported
Product Timeline
| Event |
Date
| 6100/60 Introduction |
March 14, 1994
| 6100/60 Discontinued |
January 3, 1995
| 6100/66 Introduction |
January 3, 1995
| 6100/66 Discontinued |
October 14, 1995
PC Compatibility Card (Optional)
| Specification |
Value
| Processor |
Intel 486DX2
| Clock Speed |
66 MHz
| Maximum RAM |
32 MB (dedicated)
| Interface |
NuBus
| Operating System |
MS-DOS, Windows 3.1
