Macintosh Performa 6260CD
Macintosh Performa 6260 on display in Japan (photo Tokumeigakarinoaoshima, CC0)
TypeDesktop personal computer
Released19 June 1996
Discontinued1 December 1996
CPUPowerPC 603e at 100 MHz, 40 MHz bus
Memory8 MB as shipped, in two 72-pin SIMM slots (80 ns); 64 MB maximum; none soldered
Storage800 MB internal IDE hard drive
Display—
Sound16-bit stereo output; mono input
Graphics1 MB DRAM frame buffer on the logic board; DB-15 port
ROM4 MB
FPU / coprocessorBuilt into the PowerPC 603e
Media1.4 MB SuperDrive (manual-inject); CD-ROM drive
Ports / interfaceOne ADB, two RS-232/RS-422 serial (mini DIN-8), SCSI (DB-25), DB-15 video, sound in and out
ExpansionLC processor-direct slot; communications slot; video-in slot; TV tuner connector
Power100-240 V AC, 47-63 Hz, 125 W
Dimensions4.3 × 16.5 × 12.6 in (10.95 × 41.95 × 32 cm)
Weight19 lb (8.6 kg) with CD-ROM drive
OS / FirmwareKanjiTalk 7.5.1 to Mac OS 9.1
Model no.M3076 (Gestalt ID 42)
The Macintosh Performa 6260CD is a model in Apple's Performa 6200 series of desktop Macintoshes. Apple's specification sheet gives it a 100 MHz PowerPC 603e, 8 MB of RAM and a 800 MB IDE hard drive, with an introduction date of 19 June 1996. Apple notes that it was not sold in the United States, and gives Japanese system software as shipped.[1] EveryMac lists it as sold in Asia and Europe, with Japanese order number M5144J/A, until 1 December 1996.[2]
It uses the 100 MHz PowerPC 603e board of the 6290CD and 6300CD; Apple's repair parts list gives that logic board as 661-1041.[3] The Macintosh Performa 6200CD page has the model table for the series, the full specification, Apple's repair extension procedure and a selection of Apple's symptom charts.
Performa 6260CD specifications (Apple)
Item Specification
Processor PowerPC 603e at 100 MHz; 32K level 1 and 256K level 2 cache[1][3]
RAM 8 MB as shipped; two 72-pin SIMM slots, 80 ns or faster; 64 MB maximum; no memory soldered to the board[1][3]
Video 1 MB DRAM frame buffer on the logic board, separate from system memory; 640 × 480 at 16 bits per pixel, 800 × 600 and 832 × 624 at 8[3]
Drives 1.4 MB SuperDrive, manual insert; 800 MB IDE hard drive; internal CD-ROM drive[1][3]
Slots 96/114-pin LC processor-direct slot; 112-pin communications slot; 60-pin video-in slot; 10-pin TV tuner port[3]
Electrical 100-240 V AC, 47-63 Hz; 125 W[3]
Battery and repair extension
The battery is a 4.5 V alkaline pack.[1] Apple's test is to measure it on the 10 V DC range with the logic board out and replace it below 3.0 V.[3] Neutralise alkaline leakage with a weak acid such as vinegar; see Battery Explosion, Capacitor or Corrosion Damage.
Apple's repair extension programme for system freezes and sudden changes in video colour hue covers the Performa 62xx and 63xx except the 6320 and 6360, but its list of covered models does not name the 6260. The procedure, which checks the clock chip at U10 and the cache/ROM DIMM, is on the Performa 6200CD page.[3]
Maintenance and repair
The wiki's guides for this logic board family are written for the all-in-one Performa 5200CD: Macintosh Performa 5200CD General Maintenance, Macintosh Performa 5200CD Troubleshooting and Macintosh Performa 5200CD Capacitor Replacement Guide.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 Macintosh Performa 6260CD: Technical Specifications, Apple—link(accessed 2026-09-30) PowerPC 603e at 100 MHz, 64-bit data path, 40 MHz bus; 32K L1, 256K L2; slots LC, comm, TV, video in/out; DB-15 video; battery type 4.5 V alkaline; no RAM on the logic board, two 72-pin SIMM slots, 8-64 MB; introduced 19 June 1996; "This system is not sold in the U.S."; Gestalt ID 42; original system software J-7.5.1 with System Enabler 406; 800 MB IDE.
  2. ↑ Apple Macintosh Performa 6260CD Specs, EveryMac—link(accessed 2026-09-30) 100 MHz 603e; 8 MB; 800 MB; 4X CD-ROM; sold in Asia and Europe, not North America; introduced 19 June 1996, discontinued 1 December 1996; order number M5144J/A in Japan. Model M3076; supported system software to Mac OS 9.1.
  3. ↑ 3.00 3.01 3.02 3.03 3.04 3.05 3.06 3.07 3.08 3.09 Apple Computer, Performa 6200/6300 Series Service Source, File:Performa 6200.6300.pdf; see Performa 6200/6300 Series Service Source. PDF page numbers: title p. 1; Open Transport p. 8; Video-In Card and TV Tuner pp. 11-12; Processor p. 26; Memory pp. 27-28; Disk Storage p. 29; I/O Interfaces pp. 30-34; Video Resolution p. 38; Electrical pp. 40-41; Symptom Charts pp. 46-67; Battery Verification pp. 164-165; REA Procedures pp. 175-206.
