Macintosh Performa 405
Macintosh Performa 400, which uses the same case as the 405 with a different badge. Photo: Akbkuku, Wikimedia Commons, CC BY 4.0
TypeDesktop personal computer
ReleasedApril 12, 1993
DiscontinuedNovember 1, 1993
Intro priceUS$1,300
CPUMotorola 68030 at 16 MHz
Memory4 MB on board, expandable to 10 MB
Storage80 MB SCSI hard drive; 1.4 MB SuperDrive
DisplayExternal; 256 KB VRAM SIMM
Sound8-bit mono
Dimensions7.7 × 31.0 × 38.2 cm (3.0 × 12.2 × 15.0 in)
Weight4.0 kg (8.8 lb)
OS / FirmwareSystem 7.0.1P – Mac OS 7.6.1
PredecessorPerforma 400
SuccessorPerforma 410
Model no.M1700
The Macintosh Performa 405 is a desktop Macintosh sold by Apple through consumer retail shops. Apple gives its introduction date as April 12, 1993.[1] It is the Macintosh LC II under a Performa name, with bundled software; the Performa 400, 405, 410 and 430 are the same hardware.[2]
EveryMac gives the US price as US$1,300 and the discontinuation date as November 1, 1993.[3] Apple order numbers: M1719LL/A and M1742LL/A, which differed only in the software bundle.[3]
Apple's figures
Item Figure
Processor Motorola 68030 at 16 MHz; 16-bit data path; no FPU socket
RAM 4 MB on board; two 30-pin SIMM sockets, filled in pairs with 100 ns 1, 2 or 4 MB SIMMs; 10 MB maximum
ROM 512K
VRAM One VRAM SIMM socket: 256K gives 512 × 384 at 8-bit and 640 × 480 at 4-bit; 512K gives 16-bit and 8-bit
Floppy drive Apple SuperDrive (auto-inject)
Hard drive at introduction 80 MB
Ports One ADB, two serial (printer and modem), SCSI DB-25, DB-15 video, sound in and out
Expansion One 96-pin LC processor-direct slot
Electrical 100–240 VAC, 50–60 Hz, automatically configured; 50 W maximum excluding monitor
Sources: Apple's technical specifications and the Performa 400 Series Service Source, pp. 3–14.[1][4] Apple's technical specifications give the input range as 90–240 V; the Service Source gives 100–240 VAC.
The machine accepts 12 MB (4 MB on board plus two 4 MB SIMMs) but addresses only 10 MB. Apple explains that with 4 MB SIMMs in both sockets the lower 2 MB of the on-board RAM cannot be addressed.[1][4]
EveryMac says the 405 shipped with a 256 KB VRAM SIMM, where the 400 and 410 had 512 KB, and describes it as bundled with a 12-inch Apple colour monitor; Apple's manual lists the Performa Display.[3][4]
The PRAM battery is a 3.6 V lithium cell, Apple part 742-0011; Apple says to replace it below 3.0 V. The power supply is part 661-1733, shared with the whole LC family.[1][4]
Known faults
  • Leaking surface-mount electrolytic capacitors on the logic board and in the power supply. The LC II board list is on Macintosh LC II Capacitor Replacement Guide.
  • A flat PRAM battery: Apple's charts for this family put "Check batteries" first for "No video" and in the no-power entries.[4]
  • The 10 MB ceiling above is normal behaviour, not a memory fault.
See Macintosh Performa 405 Troubleshooting and Macintosh LC II Troubleshooting.
Service documentation
Apple covers the Performa 405 in the Macintosh Performa 400 Series Service Source, and the same board under its LC II name in the Macintosh LC Series/Quadra 605 Service Source.[4]
  1. ↑ 1.0 1.1 1.2 1.3 Apple, "Macintosh Performa 405: Technical Specifications".
  2. ↑ Low End Mac, "Apple's Performa Line, 1992 to 1997".
  3. ↑ 3.0 3.1 3.2 EveryMac, "Macintosh Performa 405 Specs".
  4. ↑ 4.0 4.1 4.2 4.3 4.4 4.5 Apple Computer, Service Source: Macintosh Performa 400 Series (1995), File:Performa 400 series.pdf; see Macintosh Performa 400 Series Service Source. Page numbers are PDF pages.
