Macintosh IIx
Macintosh IIx
Macintosh IIx
TypePersonal computer
ReleasedSeptember 19, 1988
DiscontinuedOctober 15, 1990
Intro priceUS$7,769 – $9,369 (with 40 MB HD)
CPUMotorola 68030 @ 16 MHz
Memory1 MB or 4 MB standard, expandable to 128 MB
StorageOptional 40 MB or 80 MB SCSI hard drive
DisplayNone built-in (requires NuBus graphics card)
Sound8-bit stereo, 22.254 kHz sampling
Dimensions5.5" H × 18.5" W × 14.4" D (140 × 470 × 365 mm)
Weight24 lbs (10.9 kg)
OS / FirmwareSystem 6.0.2 – Mac OS 8.1 (with Mode32)
PredecessorMacintosh II
SuccessorMacintosh IIfx
CodenameSpock, Stratos
Model no.M5810 (1 MB), M5820 (4 MB)
The Macintosh IIx was introduced on September 19, 1988, as an incremental upgrade to the Macintosh II. The IIx replaced the 16 MHz Motorola 68020 processor with a 68030 running at the same clock speed, added the 68882 FPU as standard, and introduced the 1.44 MB SuperDrive (FDHD) floppy drive. The IIx maintained the same six-slot NuBus architecture and modular case design as its predecessor while adding integrated PMMU support and 256 bytes each of instruction and data cache.
Development & Market Position
Apple developed the IIx under the codenames "Spock" and "Stratos" as a straightforward evolution of the Macintosh II architecture. The "x" suffix indicated the presence of the 68030 CPU, a naming convention Apple used across multiple models including the Macintosh IIcx and Macintosh IIvx.
Released at $7,769 for a base configuration or $9,369 with a 40 MB hard drive, the IIx targeted professional users requiring expandability and performance. The machine competed directly with workstations from Sun Microsystems, Silicon Graphics, and Hewlett-Packard. Apple increased the Macintosh II's price by approximately 20% just before the IIx introduction, positioning the new model as a modest upgrade cost.
Model Configurations
The IIx was available in several standard configurations:
Base Models
  • Macintosh IIx 1/0 – 1 MB RAM, dual 1.44 MB floppy drives, no hard drive
  • Macintosh IIx 4/0 – 4 MB RAM, dual 1.44 MB floppy drives, no hard drive
  • Macintosh IIx 1/40 – 1 MB RAM, one 1.44 MB floppy, 40 MB hard drive
  • Macintosh IIx 4/40 – 4 MB RAM, one 1.44 MB floppy, 40 MB hard drive
  • Macintosh IIx 4/80 – 4 MB RAM, one 1.44 MB floppy, 80 MB hard drive
All configurations required at least one NuBus graphics card for video output, as the IIx had no built-in video capability.
Power-on circuit repair, battery replacement, capacitor inspection, and cleaning procedures are documented in Macintosh IIx General Maintenance.
PCB Architecture & Service Documentation
The IIx consists of a large logic board with integrated I/O and expansion, plus a separate power supply unit:
Logic Board
The IIx logic board features:
  • Motorola 68030 processor at 16 MHz with integrated MMU
  • Motorola 68882 FPU at 16 MHz
  • ROM SIMM slot containing required 256 KB ROM
  • Eight 30-pin SIMM slots in two banks of four
  • Six NuBus slots for expansion cards
  • SWIM chip for SuperDrive support
Power Supply
The power supply provides:
  • +5V, +12V, -12V regulated outputs
  • 230W maximum output
  • Soft power control via ADB
  • Pass-through AC outlet
Apple Service Manual
Service documentation is available on the Apple Service Source page.
Surface-mount electrolytic capacitors on the IIx logic board are prone to leakage after 30+ years. Replacement procedures and specifications are documented on the Macintosh IIx Capacitor Replacement Guide page.
Power-on failures, chimes of death, NuBus issues, and memory problems are covered in the Macintosh IIx Troubleshooting guide.
System Architecture
Sub-system Specification (Macintosh IIx, September 1988)
CPU Motorola 68030 @ 16 MHz • Integrated PMMU • 256 bytes I-cache + 256 bytes D-cache
Bus width 32-bit data • 32-bit address (4 GB theoretical, 128 MB actual limit)
ROM 256 KB ROM SIMM • "Dirty" ROMs require Mode32 for >8 MB RAM
RAM 1-128 MB via 30-pin SIMMs • Two banks of four slots • 120ns or faster
Video None built-in • Requires NuBus graphics card
Sound Apple Sound Chip (ASC) • 4-voice stereo • 22.254 kHz sampling
Storage 1.44 MB SuperDrive standard • Optional 40/80 MB SCSI hard drive
I/O Ports ADB × 2 • Mini-DIN-8 serial × 2 • DB-25 SCSI • DB-19 floppy
Expansion Six NuBus slots • 10 MHz bus speed • 10-40 MB/s bandwidth
Memory Configuration
The IIx uses eight 30-pin SIMM slots arranged in two banks of four. Both banks must be populated with identical SIMMs within each bank.
Memory Configurations
Bank A Bank B Total RAM Notes
4 × 256 KB Empty 1 MB Minimum configuration
4 × 256 KB 4 × 256 KB 2 MB
4 × 1 MB Empty 4 MB
4 × 1 MB 4 × 1 MB 8 MB Maximum without Mode32
4 × 4 MB PAL Empty 16 MB Requires Mode32
4 × 4 MB PAL 4 × 1 MB 20 MB Requires Mode32
4 × 4 MB PAL 4 × 4 MB PAL 32 MB Requires Mode32
4 × 16 MB PAL 4 × 16 MB PAL 128 MB Maximum, requires Mode32
Important notes:
  • 4 MB and 16 MB SIMMs must be PAL (Presence Detect) type
  • Mode32 or 32-bit System Enabler required for >8 MB configurations
  • Bank A must be populated before Bank B can be used
ROM Specifications
The IIx requires a ROM SIMM in the dedicated ROM slot. The ROM is "32-bit dirty," containing 24-bit addressing code that limits RAM access to 8 MB without software patches.
ROM Details
Version Size Features Limitations
IIx ROM 256 KB SWIM support, 68030 optimizations 32-bit dirty, 8 MB limit without Mode32
IIfx ROM 512 KB 32-bit clean alternative Not officially supported but functional
NuBus Architecture
The six NuBus slots provide the primary expansion capability:
NuBus Specifications
Parameter Specification
Bus speed 10 MHz
Data width 32-bit
Address space 256 MB per slot
Bandwidth 10-40 MB/s (theoretical)
Slot numbering 9, A, B, C, D, E (hexadecimal)
Power per slot +5V @ 2A, +12V @ 0.3A, -12V @ 0.3A
Common NuBus cards:
  • Graphics cards – Apple 8•24, Radius DirectColor/GX
  • Accelerators – DayStar Digital PowerCache, Radius Rocket
  • Network cards – Ethernet, Token Ring adapters
  • Video capture – Media Time, VideoSpigot
  • Additional I/O – Serial/parallel expansion cards
SuperDrive (FDHD) System
The IIx was the first Macintosh II series computer with built-in SuperDrive support:
Technical Specifications
  • Controller: SWIM (Super Wozniak Integrated Machine) chip
  • Capacity: 1.44 MB (high density), 800 KB (double density), 400 KB (single density)
  • Encoding: MFM for 1.44 MB, GCR for 400/800 KB
  • Compatibility: Mac, ProDOS, MS-DOS formats (with software)
  • Transfer rate: Up to 62.5 KB/s
Drive Support Matrix
Drive Type Internal Support External Support
400 KB Read only Read only
800 KB Full support Full support
1.44 MB Full support Full support
MS-DOS 720 KB With Apple File Exchange With Apple File Exchange
MS-DOS 1.44 MB With Apple File Exchange With Apple File Exchange
SCSI Subsystem
The IIx uses the NCR 5380 SCSI controller providing:
  • SCSI-1 interface (5 MB/s maximum)
  • Seven device support (ID 0-6, Mac is ID 7)
  • DB-25 external connector
  • 50-pin internal connector
  • Asynchronous transfers only
Real-world SCSI performance typically achieves 1.4 MB/s with appropriate drives and proper termination.
Audio System
The Apple Sound Chip (ASC) provides enhanced audio capabilities:
  • Four-voice wavetable synthesis
  • Stereo output via dual 8-bit DACs
  • 22.254 kHz standard sampling rate
  • 11.127 kHz and 7.418 kHz alternate rates
  • 512-byte FIFO buffer per channel
Power Specifications
  • Input: 100-132V or 198-264V AC, 47-63 Hz (switch selectable)
  • Maximum power: 230W
  • BTU/hr: 786.6
  • Power distribution:
    • +5V @ 14.0A
    • +12V @ 1.8A
    • -12V @ 0.25A
    • -5V @ 0.1A
Power-On Circuit
The IIx features a complex power-on circuit that requires functioning batteries:
Power-On Circuit Components
Component Function Common Failure Mode
Dual 3.6V batteries Provide 7V for power-on circuit Dead batteries prevent power-on
UB1, UB2 transistors Switch power supply control Capacitor leakage damages transistors
C5, C6 capacitors Filter power-on circuit Leakage breaks nearby traces
R3, R18 resistors Current limiting Corrosion from capacitor leakage
Without functioning batteries or with damaged power-on components, the IIx cannot start via the rear power button or ADB power key.
32-bit Addressing & Mode32
The IIx ships with "32-bit dirty" ROMs containing residual 24-bit code. This limits usable RAM to 8 MB regardless of physical installation. To access more than 8 MB:
Software Solutions
  • Mode32 1.2 – For System 7.0/7.1
  • Mode32 7.5 – For System 7.5.x
  • 32-bit System Enabler – Apple's solution (less stable than Mode32)
  • System 7.6 – Requires 32-bit clean ROMs (not compatible)
Installation Process
  1. Install physical RAM beyond 8 MB
  2. Install Mode32 in System Folder
  3. Open Memory control panel
  4. Check "32-bit Addressing"
  5. Restart
Known Issues & Solutions
Power-On Failures
  • No response to power button – Dead batteries or damaged power-on circuit
  • Powers on via ADB only – UB1/UB2 transistor failure
  • Clicking/ticking sound – Power supply protection, check for shorts
Memory Issues
  • Only recognizes 8 MB – Install Mode32 and enable 32-bit addressing
  • Chimes of death – Reseat SIMMs, verify matched sets
  • Random crashes – Replace PAL SIMMs with correct type
Video Problems
  • No video output – Verify NuBus card seated properly
  • Grayscale only – Check monitor sense pins on video cable
  • Distorted display – Clean NuBus contacts with contact cleaner
SCSI Issues
  • Devices not recognized – Check termination and cable quality
  • Slow performance – Verify proper termination at chain ends
  • System hangs at startup – Remove all SCSI devices, test individually
Upgrade Paths
Processor Upgrades
  • DayStar Digital PowerCache – 33/40/50 MHz 68030 accelerators
  • Radius Rocket – 68040-based NuBus coprocessor cards
Video Upgrades
  • Apple 8•24 GC – Accelerated 24-bit graphics
  • Radius DirectColor/GX – High-performance graphics
  • SuperMac Thunder/24 – 24-bit accelerated video
Storage Upgrades
  • Larger SCSI drives – Up to 2 GB supported natively
  • SCSI-2 cards – DayStar Digital SCSI PowerCard for faster transfers
Historical Context
The IIx served as Apple's high-end workstation from September 1988 until the Macintosh IIfx introduction in March 1990. Notable uses included:
  • Industrial Light & Magic for "The Abyss" image processing
  • Publishing industry for early desktop publishing
  • Scientific computing with FPU-intensive applications
  • CAD/CAM workstation applications
Production ceased October 15, 1990, after approximately 80,000 units sold. Support and spare parts were discontinued August 31, 1998.
Maintenance Resources
