Macintosh Performa 580CD
(Redirected from Macintosh Performa 580)
Macintosh Performa 580CD (National Library of New Zealand, CC BY 3.0 NZ)
TypeAll-in-one personal computer
Released1 May 1995
Discontinued1 February 1996
Intro priceUS$1,500
CPUMotorola 68LC040 at 33 MHz, no FPU
Memory4 MB on the logic board; two 72-pin SIMM sockets; 52 MB maximum
Storage500 MB internal IDE hard disk
DisplayBuilt-in 14-inch shadow-mask CRT, 11.5-inch viewable, 640 × 480 at 66.7 Hz
Sound8-bit stereo output and headphone jack; mono input; built-in microphone
Graphics1 MB of DRAM on the logic board; thousands of colours at 640 × 480
ROM1 MB
Media1.4 MB SuperDrive (manual-inject); double-speed tray-loading CD-ROM drive
Ports / interfaceOne ADB, two serial (modem 9-pin, printer 8-pin mini-DIN), SCSI (DB-25), sound in and out
Expansion114-pin processor-direct slot; communications slot; video-in slot; external video connector slot
Power90-264 V rms, 50-60 Hz, 120 W maximum
Dimensions17.9 × 13.5 × 16.5 in (45.5 × 34.4 × 42.0 cm)
Weight40.5 lb (18.4 kg)
OS / FirmwareSystem 7.5 to Mac OS 8.1
Model no.M3872 (Gestalt ID 99)
The Macintosh Performa 580CD is the Performa version of the Macintosh LC 580, an all-in-one Macintosh with a 33 MHz 68LC040 and a built-in 14-inch colour screen. Apple introduced it on 1 May 1995.[1] Apple's service manual covers it together with the LC 580 and says the Performa 580CD is bundled with a 500 MB IDE hard drive and a tray-loading double-speed CD-ROM drive; otherwise the manual applies to both machines.[2] EveryMac records it as sold in Canada, Asia and Australia until 1 February 1996, at US$1,500, and also lists 5 MB and 250 MB configurations.[3]
Apple describes the LC 580 and Performa 580CD as higher-performance versions of the Macintosh LC 575.[2] The case looks the same as the Performa 575-578's, but the logic board is new, with an IDE hard disk interface and video input and output expansion, and the screen is a shadow-mask tube in place of a Trinitron.[3]
Macintosh LC 580/Performa 580CD specifications (Apple)
Item Specification
Processor Motorola 68LC040 at 33 MHz, built-in MMU, no FPU[2][1]
RAM 4 MB on the logic board; two 72-pin SIMM connectors, fast-page mode, 80 ns; 52 MB maximum. The second slot takes only 1, 4 or 16 MB SIMMs[2][1]
ROM and PRAM 1 MB ROM; 256 bytes of parameter memory[2]
Video memory 1 MB of DRAM soldered to the logic board; thousands of colours (16-bit)[2]
Display 14-inch diagonal, 11.5-inch viewable; 0.28 mm dot-pitch shadow mask; 640 × 480 at 66.67 Hz; active raster 240 × 180 mm; white point 9300 K[2]
External video Optional external video connector mirrors the screen at 640 × 480 on Apple 12-inch, 14-inch, Performa Plus and Multiple Scan 15/17/20 displays, and at 800 × 600 on the Multiple Scan 15/17/20 and SVGA monitors[2]
Sound Records and plays at 11 or 22 kHz; mono sound input; 8-bit stereo output port and headphone jack; built-in microphone and two speakers[2]
Serial Two RS-232/RS-422 ports: modem port 9-pin mini-DIN, printer port 8-pin mini-DIN[2]
SCSI and ADB One SCSI port, up to six external devices; one ADB port, 500 mA maximum[2]
Slots 114-pin processor-direct slot; 112-pin communications slot (fax modem or Ethernet); 60-pin video-in slot; 22-pin external video connector slot[2]
Power supply 90-264 V rms, 50-60 Hz ± 3 Hz; 300 V rms surge for 100 ms; 40 A peak inrush; 2.0 A and 120 W maximum[2]
Size and weight 45.5 × 34.4 × 42.0 cm (17.9 × 13.5 × 16.5 in); 18.4 kg (40.5 lb)[2]
Battery
Apple's specification sheet lists the battery as a 4.5 V alkaline type, while the Service Source's specification page says only "long-life lithium battery" and names no part.[1][2] Apple's test: remove the I/O door and logic board, disconnect the battery, measure it on the 10 V DC range and replace it below 3.0 V.[2] Check the markings on the pack before buying a replacement. Neutralise alkaline leakage with a weak acid such as vinegar, and lithium leakage with bicarbonate of soda; see Battery Explosion, Capacitor or Corrosion Damage.
Maintenance and repair
The Performa 580CD is serviced as an LC 580. The Macintosh LC 580 page covers the logic board and its capacitors, the analog board and CRT, Apple's take-apart and display adjustments, and Apple's symptom charts, including a Performa 580CD modem fault ("current port is busy") cured with the GlobalFax 2.5.2P update. The analog board and CRT carry high voltage and hold a charge after the machine is unplugged; see CRT Discharge Procedure.
  1. ↑ 1.0 1.1 1.2 1.3 Macintosh Performa 580CD: Technical Specifications, Apple—link(accessed 2026-09-30) Introduced 5/1/1995; 68LC040, no FPU; 8 MB minimum, 52 MB maximum, second SIMM slot takes only 1, 4 or 16 MB SIMMs; 1 MB DRAM video, 640 × 480 at 16-bit; 500 MB IDE; 2x CD-ROM; Gestalt ID 99; battery type 4.5 V alkaline; 90-264 V.
  2. ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 2.10 2.11 2.12 2.13 2.14 2.15 2.16 Apple Computer, Macintosh LC 580/Performa 580CD Service Source (1995), File:Lc 580.performa 580cd.pdf; see Macintosh LC 580/Performa 580CD Service Source. PDF page numbers: General Information pp. 3-4; Specifications pp. 8-20; Battery Verification pp. 109-110.
  3. ↑ 3.0 3.1 Apple Macintosh Performa 580CD Specs, EveryMac—link(accessed 2026-09-30) Introduced 1 May 1995, discontinued 1 February 1996; sold in Canada, Asia and Australia; 5 MB or 8 MB RAM; 250 MB or 500 MB IDE hard drive; order number M3872LL/A; US$1,500.
