Macintosh Performa 638CDV
Apple Macintosh Performa 630
Performa 630 with a CD-ROM drive; the 638CD uses the same case (Hellis, Italian Wikipedia, CC BY-SA 3.0)
TypeDesktop personal computer
Released1 July 1994 (Apple); 18 July 1994 (EveryMac)
Discontinued1 July 1995
Intro priceUS$2,300 (EveryMac)
CPUMotorola 68LC040 at 33 MHz, no FPU
Memory8 MB (4 MB on the logic board plus a SIMM); one 72-pin SIMM socket (80 ns); 36 MB maximum
Storage250 MB (Service Source) or 350 MB (Apple specification sheet) internal IDE hard drive
Display—
Sound8-bit mono input; 8-bit stereo output (16-bit in CD mode)
Graphics1 MB DRAM frame buffer, not expandable; DB-15 port
ROM1 MB
Media1.4 MB Apple SuperDrive (manual insert); AppleCD 300i Plus double-speed CD-ROM drive
Ports / interfaceOne ADB, two RS-232/RS-422 serial (mini DIN-8), SCSI (DB-25), DB-15 video, sound in, sound out front and rear
Expansion114-pin LC processor-direct slot, 112-pin communications slot, 60-pin video-in slot, 10-pin TV tuner connector
Power100-240 V AC, 50-60 Hz, 45 W maximum
Dimensions4.3 × 16.5 × 12.6 in (10.95 × 41.95 × 32 cm)
Weight19 lb (8.6 kg)
OS / FirmwareSystem 7.1.2P to Mac OS 8.1
Model no.M3076 (Gestalt ID 98)
The Macintosh Performa 638CDV is the name Low End Mac and Wikipedia use for a TV-equipped configuration of the Macintosh Performa 638CD, a model in Apple's Performa 630 series with a 33 MHz 68LC040. Apple's own documents call the machine the Performa 638CD. Its specification sheet gives it 8 MB of RAM as the minimum, a 350 MB IDE hard drive and a double-speed CD-ROM drive, introduced 1 July 1994.[1] Low End Mac lists a 638CD without a display but with the TV tuner and video input card, and a 638CD/V with the TV tuner and a multiscan display.[2] EveryMac describes the 638CD as the 637CD with TV and video input/output cards and no monitor, at US$2,300 (order number M3599LL/A).[3]
The Macintosh Performa 630 page has the configuration table for the series, the full specification and a selection of Apple's symptom charts.
Configuration
Apple's service manual lists the Performa 638CD with 8 MB of RAM, a 1.4 MB SuperDrive, a 250 MB IDE hard drive, an internal AppleCD 300i Plus CD-ROM drive, a 15-inch Apple Performa Display, a TelePort send-fax/data modem, and the TV tuner and video-in cards installed: the same list it gives for the 637CD.[4] Apple's specification sheet gives 350 MB as the minimum hard drive.[1]
The logic board has a 60-pin video-in slot for real-time video display, capture and overlay, and a ribbon connector for an optional TV tuner card that takes NTSC or PAL from an aerial or cable.[4] The front panel has a receiver for Apple's optional infrared remote control.[4] Apple's symptom charts cover one fault on these cards: if some UHF channels cannot be tuned, replace a revision A video-in card (661-0159) with revision B (661-1073).[4]
Performa 630 series specifications (Apple)
Item Specification
Processor Motorola 68LC040 at 33 MHz, no FPU[4][1]
RAM 4 MB on the logic board; one 72-pin SIMM socket, 80 ns; 36 MB maximum[1][4]
Video 1 MB DRAM frame buffer, not expandable; up to 16 bits per pixel at 640 × 480, 8 bits at 800 × 600[4]
Drives 1.4 MB SuperDrive, manual insert; IDE hard drive; AppleCD 300i Plus double-speed CD-ROM drive. Internal SCSI hard drives are not supported[4]
Sound 8-bit mono input; 8-bit stereo output, 16-bit in CD mode, 0.5 V RMS into 39 ohms[4]
Electrical 100-240 V AC, 50-60 Hz; 45 W maximum, not including the monitor[1][5]
The Performa 630 Series volume prints the maximum power as "5 W"; Apple's specification sheet and the LC 630/Quadra 630/Performa 640 volume give 45 W.[4][1][5]
Battery
Apple's specification sheet gives the battery as 4.5 V alkaline.[1] The Service Source gives no test voltage; its symptom charts print "Unplug 5.4 battery" for the 20-second battery-unplug step, a misprint for 4.5, which the LC 630 volume prints for the same step.[4][5] Neutralise alkaline leakage with a weak acid such as vinegar; see Battery Explosion, Capacitor or Corrosion Damage.
Maintenance and repair
The Performa 638CD has the LC 630's case and logic board family, and the LC 630 guides apply: Macintosh LC 630 General Maintenance, Macintosh LC 630 Troubleshooting and Macintosh LC 630 Capacitor Replacement Guide.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Macintosh Performa 638CD: Technical Specifications, Apple—link(accessed 2026-09-30) Introduced 7/1/1994; RAM 8-36 MB; minimum hard drive 350 MB. 68LC040 at 33 MHz, no FPU; data path 32-bit, 33 MHz; slots LC, comm, TV, video in; one ADB; DB-15 video; 45 W maximum, 100-240 V, 50-60 Hz; battery type 4.5 V alkaline; 4 MB on the logic board, one 72-pin SIMM slot, 80 ns; 1 MB video DRAM; Gestalt ID 98; System 7.1.2P with System Enabler 405; 1 MB ROM; 2x CD-ROM.
  2. ↑ Performa 630 and LC 630, Low End Mac—link(accessed 2026-09-30) Model list: 635CD same as 630CD with 5 MB, bundled with modem and display; 636 same as 635CD but no CD-ROM or display, 8 MB; 636CD same as 636 with CD-ROM, higher education only; 637CD same as 636CD bundled with display, higher education only; 638CD same as 637CD without display, includes TV tuner/video input card; 638CD/V same as 638CD with TV tuner and multiscan display. PRAM battery 4.5 V alkaline. The IDE controller supports a single device; Macs with IDE drives do not supply SCSI termination power.
  3. ↑ Apple Macintosh Performa 638CD Specs, EveryMac—link(accessed 2026-09-30) Introduced 18 July 1994, discontinued 1 July 1995; 8 MB (4 MB on board); 350 MB IDE; 2X CD-ROM; 14.4k external modem; identical to the 637CD but shipped with TV and video input/output cards and without a monitor; order number M3599LL/A; model M3076; US$2,300.
  4. ↑ 4.00 4.01 4.02 4.03 4.04 4.05 4.06 4.07 4.08 4.09 4.10 4.11 Apple Computer, Macintosh Performa 630 Series Service Source (1995), File:Performa 630 series.pdf; see Macintosh Performa 630 Series Service Source. PDF page numbers: title p. 1; General Information pp. 3-6; Product Configuration pp. 7-12; Processor p. 18; Memory pp. 19-20; Disk Storage p. 21; I/O Interfaces pp. 22-24; Sound and Video p. 26; Electrical p. 27; Physical p. 28; Symptom Charts pp. 31-46 (battery step pp. 36, 43; video-in card p. 37; CD-ROM p. 41); Logic Board take-apart p. 70; Exploded View p. 120.
  5. ↑ 5.0 5.1 5.2 5.3 Apple Computer, LC 630/Quadra 630/Performa 640 Service Source, File:Quadra.lc 630.performa 640.pdf; see LC 630/Quadra 630/ Performa 640 Service Source. Electrical, PDF p. 27 (45 W); symptom chart, PDF p. 37 ("Unplug 4.5 battery").
