Macintosh Performa 6320CD
The Macintosh Performa 6320CD is the 120 MHz model of Apple's Performa 6300 series of desktop Macintoshes, introduced on 22 April 1996.[1] Apple's service manual says it supersedes the Performa 6300CD and differs from it only in having a 120 MHz PowerPC 603e in place of the 100 MHz part.[2] EveryMac lists it at US$2,600 with a TV/video system and a 15-inch Apple colour monitor, with the TV tuner slot occupied as shipped, and names the Power Macintosh 6300/120, sold only in Asia, as its business version.[3]
The Macintosh Performa 6300CD page has the model table for the series, the full specification, the hardware notes and a selection of Apple's symptom charts.
| Processor | PowerPC 603e at 120 MHz on a 64-bit, 40 MHz bus; 32K level 1 and 256K level 2 cache[1][2] |
| RAM | 16 MB as shipped; two 72-pin SIMM slots, 80 ns or faster; 64 MB maximum; no memory soldered to the board[1][2] |
| Video | 1 MB DRAM frame buffer on the logic board, separate from system memory; 640 × 480 at 16 bits per pixel, 800 × 600 and 832 × 624 at 8[2] |
| Drives | 1.4 MB SuperDrive, manual insert; 1.2 GB IDE hard drive; quadruple-speed CD-ROM drive[1][2] |
| Slots | 96/114-pin LC processor-direct slot; 112-pin communications slot; 60-pin video-in slot; 10-pin TV tuner port[2] |
| Electrical | 100-240 V AC, 47-63 Hz; 125 W (Apple's specification sheet gives 55 W maximum)[2][1] |
Differences from the 6300CD board
[edit | edit source]Apple's parts list gives the 6320 its own versions of several parts, shared with the Performa 6360:[2]
| Part | 6300CD | 6320CD |
| Logic board | 661-1041 (100 MHz) | 661-1175 (120 MHz) |
| Power supply | 661-0170 | 661-1053 |
| Fan/video card bracket | 922-1160 | 922-2202 |
| I/O door | 922-1565 | 922-2434 |
| Speaker | 922-1175 | 922-2294 |
The 6320 logic board has a reset button, which Apple calls the Cuda reset button; the Service Source has a diagram of its position, which differs from the 6360's. Apple's logic board reset for this model is: take out the logic board, unplug the battery from the board, wait five to ten minutes, refit the battery, then press the reset button with a flat plastic tool before sliding the board back in at an upward angle to clear the EMI clips. Afterwards, check the date, time and other parameter RAM settings.[2] Try zapping the parameter RAM first by holding Command-Option-P-R at start-up.[2]
Battery and repair notes
[edit | edit source]The battery is a 4.5 V alkaline pack.[1] Apple's test is to measure it on the 10 V DC range with the logic board out and replace it below 3.0 V.[2] Neutralise alkaline leakage with a weak acid such as vinegar; see Battery Explosion, Capacitor or Corrosion Damage.
Apple's repair extension programme for freezes and colour-hue changes on the Performa 6200 and 6300 series excludes the 6320.[2] The general symptom charts in the same manual still apply to it.
Maintenance and repair
[edit | edit source]The wiki's guides for this logic board family are written for the all-in-one Performa 5200CD: Macintosh Performa 5200CD General Maintenance, Macintosh Performa 5200CD Troubleshooting and Macintosh Performa 5200CD Capacitor Replacement Guide.
[edit | edit source]- Performa 6200/6300 Series Service Source: Apple's service manual for the 6200 and 6300 series.[2]
[edit | edit source]- Macintosh Performa 6300CD and the rest of the Performa 6300 series
- Macintosh Performa 6310CD
- Power Macintosh 6300
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 Macintosh Performa 6320CD: Technical Specifications, Apple—link(accessed 2026-09-30) PowerPC 603e at 120 MHz; data path 64-bit, 40 MHz; 32K L1, 256K L2; slots LC, comm, TV, video in/out; one ADB; DB-15 video; 55 max watts, 110-240 V; battery type 4.5 V alkaline; no RAM on the logic board, two 72-pin SIMM slots, 16-64 MB, 80 ns; introduced 4/22/1996; Gestalt ID 42; System 7.5.1 with System Enabler 406; 4 MB ROM; 1.2 GB IDE; 4x CD-ROM.
- ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 2.10 2.11 2.12 Apple Computer, Performa 6200/6300 Series Service Source, File:Performa 6200.6300.pdf; see Performa 6200/6300 Series Service Source. PDF page numbers: title p. 1 (lists the 6320 and 6320CD); Performa 6320CD and 6300CD p. 6; Processor p. 26; Memory pp. 27-28; Disk Storage p. 29; I/O Interfaces pp. 30-34; Video Resolution p. 38; Electrical pp. 40-41; Battery Verification pp. 164-165; Reset Button (6320, 6360) pp. 168-169; Reset Logic Board pp. 170-173; REA Procedures p. 175; Exploded View p. 208.
- ↑ Apple Macintosh Performa 6320CD Specs, EveryMac—link(accessed 2026-09-30) 120 MHz 603e, 40 MHz bus; 16 MB; 1.2 GB IDE; 4X CD-ROM; TV/video system and 15-inch Apple colour monitor; TV tuner slot occupied as shipped; business version Power Macintosh 6300/120 sold only in Asia; introduced 22 April 1996, discontinued 1 September 1996; order number M4957LL/A; model M3076; Gestalt ID 42; US$2,600.
